.46 LA Help
IL
.46 LA Help
Hye guys,
Can't seem to get my LA to idle good on my voyager. is it because of the fact its mounted upside down? i know LA sux but it should idle yes? any help would be good
~Matt
~Matt
Banned
RE: .46 LA Help
I've never had much luck getting an inverted engine to idle as well as an upright or side-mounted one.
I think the problem may be associated with the very high levels of oil we run in our fuel. It could be that a small amount of unburnt oil begins to pool in the head and cools the plug or stops it reacting with the methanol so attempts to get a low/steady idle usually end up in the engine slowing and stopping -- regardless of what you do with the low-speed needle.
I've seen a few folks solve this problem by using an onboard glowplug battery that is switched in as the throttle is reduced. That approach seems to work very well.
RE: .46 LA Help
I too had this problem with a .46 LA running inverted. Switching to a hotter glow plug did the trick. As XJet mentioned, the unburnt oil cools the plug causing poor idle / stalling.
I was running an OS#8 plug and switched to an OS#A3 which solved all my problems.
Hope this helps.
Hope this helps.
