POR-20 Anyone use as muffler gasket
NJ
Hello, I'm going to use this to seal the muffler to my new engine. I do not plan on putting that little paper gasket. Does anyone have any positive or negative experiences with Aluminum Pain used this way ?
""This Aluminum high temperature paint is capable of withstanding temperatures up to 1400°F, POR-20® is also extremely weather, salt and moisture resistant. Helps prevent cracking, chipping, and peeling. Can be brushed or sprayed. ""
Thanks for any input.
NJF72
NJF72
RE: POR-20 Anyone use as muffler gasket
Hi!
What kind of engine do you have that need a sealent ????
Al modern engines I know of are perfectly tight engine to exhaust without using silicon or any other sealant.
Regards!
Jan K
Sweden
Regards!
Jan K
Sweden
