Prop for MDS .58
Prop for MDS .58
I bought a MDS .58 yesterday and broke it in today with an APC 11 x 6. It is running great and I got in a few flights with it on my TT profile Extra. I can hover the rather heavy plane at a little less than WOT with the 11 x 6 and its still very rich (just lean of 4-cycling). What prop will be good for this engine? I'm asking because I will need to order the props since my lhs has a limited selection. I was thinking 12-12.5 x 4 or 13 x 4.
BTW - The engine does run great. Perfect idle, and starts with one back flip. Only drawback is it won't die. I have to hold my finger on the carb for 5+ seconds before it quits. Does anyone know where the leak is that causes this?
Prop for MDS .58
the leak?
you mean all the leaks....
step one, remove main neddel and place 1/4 of fuel tubing over it, screw back in and slide 1/2 the tubing over the needle body.
step two, remove the pinch bolt, smear gasket sealent around the carb body, and on the pinch bolt hole.
if you can remove the idle needle and smear some gsealent on the threads,.
this should cure enough of the leaks to cut the engine.
failing all that, fit a 6x4 prop and laugh as it blows up as we did ( vid on www.rcflyers.fsnet.co.uk )
