3 Blade prop for Sai .72
RE: 3 Blade prop for Sai .72
Hi
I've used the Master Airscrew 12x6 for my OS.70, works well and looks great. Though you can feel that it has a bit less power than an 13x6 two blade APC.
I think u must use 13X5 3bale instead of 12X6, if using 13X6 3 blade, cause when i used 13X8 MA 3blade, it had same thrust as 13X8 2blade, and more speed. if u remove 1 pitch and will use 13X5, u will have bittttt more speed and same thrust, if not more
