ST 2300 bent crank
ST 2300 bent crank
Hello,
Due to a careless rookie turning on his radio, my Great Planes G202 1/4 arf is dead. Along with my Futaba pcm receiver, etc. But, my Tigre has a bent crankshaft, and my local hobby shop says he can`t locate one. He suggested I
ask you wonderfull people! If you could help, whether sourcing one, or othe options, I would really appreciate it. I want to at least use the engine again, and it flew the Giles just great!
Thank you for your time.
Kerry McAllister
Abbotsford, B.C.,
Canada v2t 5l8
Kerry McAllister
Abbotsford, B.C.,
Canada v2t 5l8
ST 2300 bent crank
Try Just Engines in the UK he might have a new cankshaft: www.justengines.unseen.org/
It appears Tower has very few ST parts now.
Also try contacting www.RCIgnition.com
Ralph Cunningham does a lot of this type of work on gassers and may be able to do the same for your big ST.
bent crank
Hello there I have a small machine shop in my basement. I may be able to put it between centers on my lathe and tap it back into shape. Let me know if i can help!
Ken
Ken
