OS 70 surpass 4 cycle
I need help to correct a problem with this engine. I'm using 15/20 fuel, after 2 gal of use and running a little on the rich side, after 5 minutes into the flight, engine seams to lean out and overheat. I bring it in right away. This is new to the engine. I'm getting plenty of smoke with a full tank of fuel, so I know I'm starting out on the rich side, what can I look for? A club member said I might need a valve adjustment. What say you? Thanks for any help. Ken
My Feedback: (10)
RE: OS 70 surpass 4 cycle
Funny, but I was just wondering the other day if our small carbs would ice up just like our full-scale brethren. Same physics, I guess
It definitely sounds like you're overheating, otherwise you would have a problem right at startup, and not after flying for 5 minutes. Is your engine cowled, and if so are you sure that your inlet/outlet cutouts are correct in size and placement for good cooling?
I'm Running a 14x6 prop on my O.S. 70 Ultimate, and while that may be pushing it a little bit, she still tachs out at 7800 and runs very consistantly-all day long in a fully cowled setup- so I would not think that the prop was the first culprit (*unless you're running bigger than that??!!)
What plane is the motor in?
Also, you cannot tell how rich your four-stroker is by the quantity of smoke- you must use a tach. It is quite possible that you are running lean and overheating- maybe the needle got bumped?
WI
I would deffinatly check the valve lash, espiaslly the exaust valve as when it heats up after a few minites the valves might be getting tight and starting to hold open and lose power. I have had this same thing happen to me and went the longest time tearing my hair out before someone suggested to open up the valve lash a bit.I have found that the exhaust needs to be a little looser than the intake, still within the tolerance window.
Thanks for the tip. Several people asked about the cowl. And a few asked about the prop size. I did not change anything.
Another club member said what you said, but I did not want to suggest that. Thanks again. Ken
