proper way to get pipe length correct
My Feedback: (38)
On my YS.45 two stroker.
It seems like after half throttle it loses RPM, anyone know what the proper length of the pipe and header would be? I run 15% nitro byrons in it, it runs great right now, just think there may be more at full throttle, its got the blade type carb.
pipe length
I don't have much experience with tuned pipes but from what I have, I have made a few applications for some funfly planes.
what I do is after I have determined which prop I will use, I work the pipe to that application. I believe that a different prop will change how much a pipe will give back.
Once I have the engine and prop on a test stand I start testing.
all adjustments are made on the header cutting off piece by piece usually 1/4-1/3 inch at a time until I reach a max rpm. At some point the rpm's stop increasing as the header gets shorter. then another 1/4 inch or so and they decrease. that's the mark. now to get back the last decrease you extend the distance 1/4 between the header and the pipe using the silicone connecter.
what I like to do is but up the header and the pipe inside the silicone tube so that when I hit the mark I can easily back it out to get the rpms back by leaving some space inside the silicone connecter.
besides the cost of the header, I can make a home made pipe for under 5 dollars..
on my 32sx i gained 1500 rpm's
on my 46fx i gained 800 rpm's
