Exhaust Deflectors for 4-stroke Advise
I have a Saito FA 56 with a deflector on the muffler....it stays on but the heat kinda gets to it and it bursts after about 12 flights or so.
I also have a Saito FA 100 with exhaust deflector attached......doesn't stay on at all. Falls off in flight. I've lost about 4 this way. The costs adds up.
tied it on with tie wraps after cutting a groove in the muffler lip for grip. Fell off in flight
used heat sealant silicone with tie wraps again. Fell off in flight
used tie wraps + wire tied onto the muffler nut. Fell off in flight.
The Saito FA 100 vibrates a lot though....it's mounted on an anti-vibration mount.
Does anyone know of another method to hold the Exhaust Deflecto onto the muffler? Helps keep the oil off the plane.
Thanks.
Thanks.
My Feedback: (85)
RE: Exhaust Deflectors for 4-stroke Advise
ORIGINAL: Kaz
Thanks.
Thanks.
Pete
CA
I use soft aluminum tube from hardware stores, they have different ID dimentions, you may need to slit the end so the clamp will hold better. They never come off and you can use a cheap spring bender to customize the look.
If it will not stay on I just drill the exhaust stinger so that I can attact a screw to it. The when you add the deflector you use a cable tie in front and behind the screw, holds on very well. Another good alternative is to use the hose clips that you see on your car airconditioning pipes ... they kinda look like the fuel line clips we use on our planes. You squeeze it to release the clip.
My Feedback: (26)
I have never been able to keep the silicone extensions on either. I was chatting with one of the fellows at the field, and he suggested the same thing as mentorman, except he used brass. I would think that if you wanted to make some angled bends, that copper might even work better as it is softer. Either way, sounds like metal tube, slit to allow compression, with a hose clamp is the way to go. Good luck.
Pilgrim
Pilgrim
