HELP ASP Engine Parts
Reply
Old 06-05-2005, 08:57 AM
t6texan.aus
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default HELP ASP Engine Parts
Help needed in locating either a retailer for ASP carby spares or the thread size of the carby barrel retainer screw on an ASP .75 as I have lost mine
This is the screw in the top of the carby that goes into the cam slot on the internal barrel not the end stop screw.
Any help from retailers manufacturer's or knowledgeable persons is gratefully appreciated.
t6texan.aus is offline
Old 06-05-2005, 11:32 AM
AMB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: HELP ASP Engine Parts
Just engines UK you will have the parts in 5 or 6 days and Paul can answer your questions martin
WHOOPS see you are down under might take an other week-- One of the guys here has gotten stuff from Modelflight down there and it only a week to US air mail, so maybe an other week added on should do it
They still think you folks and the the US are still the " Colonies" but thats the Brits
On a more serious note it appears the Aussies and Brits are the only true Allies we have in Iraq and we are grateful here for it
here is the site Justengines@enterprise.net
AMB is offline
Old 06-05-2005, 01:52 PM
w8ye
Moderator
w8ye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
SC engines are the same as the ASP if you can find SC around there anywhere. Seems as though Perkins has a lot to do with distributing Perkins?
Also you can get some ASP parts from Horizon Hobby in the states.
http://www.horizonhobby.com/Search/D...ion=ASC&Page=1
Magnum engines are also the same. They are distributed by www.hobbypeople.net in the USA
The carb has been changed from these companies. The carb no longer has the rubber boot on the throttle arm side and the
46825 Magnum Carburetor Rotor Bolt is now short and screws completely tight into the carb body. There's no longer any adjusting nut around its base. The part seems to fit OK.
Enjoy,
Jim
w8ye is online now
Old 06-05-2005, 07:02 PM
t6texan.aus
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks guys thats good info so i now have a good starting point.
Very much appreciated.
Modelers Unite[8D]
Old 06-05-2005, 11:20 PM
Flyboy Dave
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Why not make one out of a screw and a nut ?
FBD.
ID:	280974   Click image for larger version
Flyboy Dave is offline
Old 06-06-2005, 09:09 AM
t6texan.aus
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Flyboy yes i thought of that and tried a bolt of similar size thread but it would only go in about half way into the threaded section.
I would need the correct size thread ...... Anyone?????
Old 06-06-2005, 11:45 AM
Flyboy Dave
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
See if you can get a tap for the "known quantity" thread, and re-tap it.
The screw I show in the pic is out of a Magnum .46 carb, this first pic.
The second pic is a biger magnum carb. Is it like the second pic ? All the
Magnum carbs are the same from the .61, all the way up through the 1.20.
The ASP carb are similar.
Dave.
ID:	281145   Click image for larger version
Old 06-06-2005, 12:45 PM
Flyboy Dave
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's the litte booger....
http://www.horizonhobby.com/Shop/ByC...ProdID=ASP6127
It's just a screw and a spring.
FBD.
Old 06-06-2005, 07:19 PM
t6texan.aus
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's more like the second picture.
I believe that it was a bolt and nut arrangement and the idle stop screw is the one on the left with a simple screw/spring setup.
Horizon hobbies list the parts( ASP65/80 Rotor Stopscrew/Nut )
but have not yet replied as to shipping outside the US
And just engines want a min order of 10gbp.....hmmm 10 pounds = A$30 compared to A$3+ post from horizon
Old 06-06-2005, 10:14 PM
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Guys...On the ASP engines. What mufflers will fit the .60 or 61 size engine? What other brands will work? Thanks Capt,n[:-]
captinjohn is offline
Old 06-06-2005, 10:58 PM
t6texan.aus
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry captinjohn i can't answer that one as i built the exhaust for my 75 as i needed a pitts style muffler
Old 06-06-2005, 11:06 PM
t6texan.aus
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guys thanks for all your input it has been most helpful
I regret to say that impatience got the the better of me and i cracked the ****s and went out to the drill press with a hex socket bolt and file in hand
End result after 3-4 goes on the 1 bolt I turned the end down and shortened it to size and length.
With a small o-ring between the case and head and some locktite and brute force(to cut the thread with the bolt) I have managed to resolve the problem........
(till it all goes south next time)
Old 06-07-2005, 12:14 AM
Flyboy Dave
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good deal........I would have hacked something out as well.
[sm=thumbup.gif][sm=thumbup.gif]
FBD.
Old 06-08-2005, 05:02 PM
Andy McC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
T6texan, I have used Justengines in the UK, great service and the parts have arrived at my door in Sydney within 5 days. I was inpressed to day the least.
Andy McC is offline
Old 06-08-2005, 08:15 PM
t6texan.aus
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
AndyMcC thats all well and good but to spend $30 + for a $3 item and thats a minimum purchase, I couldn't justify the cost
Old 06-08-2005, 09:13 PM
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How about it Guys...... What other brands of mufflers will fit on a .60 ASP engine. Thanks Capt,n
Old 06-08-2005, 09:39 PM
t6texan.aus
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
captinjohn as i said b4 i made mine but i would suggest that you ask this as a topic in itself. I'm only new to RC Universe but i already get the feelling that you need to shout to be heard.[]
Old 06-09-2005, 07:00 AM
w8ye
Moderator
w8ye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There's more than one model of them. The magnum XL version was mighty close to a OS 61 SF engine. This would be the one with the one piece crankcase.
Enjoy,
Jim
w8ye is online now
Old 06-09-2005, 11:38 AM
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK Thanks W8YE. I think it would be neat to start a forum or thread for interchange parts know to work!!! Regards Capt,n,
Old 06-29-2005, 07:31 PM
abozzie
abozzie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good day,
I also have a Magnum 46XL "B" type carburator which is missing the stop screw assembly. There seems to be several possible replacements from a simple screw and spring to a screwnut and finally a threaded insert/screw. Wonder if they all fit the "B" carb? I tried every spare bolt in my inventory and can't match the thread size. Does anyone out there have a similar engine and gauge to check the thread size?
Also looking for a needle for an "old" Super Tigre 71, or the thread size...
Al
abozzie is offline
Old 06-30-2005, 12:27 AM
Flyboy Dave
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Super Tiger only had one needle valve that fit all the engines....c/l and r/c
all the way back to the early '70's.
It was the plain tapered one with the bent end.
FBD.
Old 06-30-2005, 09:14 AM
MrMotor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Flyboy Dave is correct about the high speed needle. They are still available and used on the Supertigre 51 C/L engine today. The low speed needle is almost impossible to find.
MrMotor is offline
Old 07-04-2005, 05:46 AM
abozzie
abozzie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great, thanks guys. The needle is the plain taper type with the bent end. I see it in the G51 parts list at the SuperTigre site and that should make it easy to track one down.
abozzie is offline
Old 07-04-2005, 04:34 PM
Bodge
Bodge's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On the ASP 61 two stroke all the ASP 61 and 91 silencers fit along with the OS 61 and 91 pipes. I believe Magnum and SC pipes also fit.
Bodge is offline
Old 07-04-2005, 10:34 PM
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bodge: Thanks for the reply. I have head that the ASP is kinda a clone of OS MAX....not sure. Capt,n
Reply
Display Modes
