Saito-100 Needle
NB, CANADA
Saito-100 Needle
I did a search here but couldn't find a concise answer. I have a fairly new Saito 100 and am interested in "typical" settings for the high-speed needle. I know it will be a function of fuel, altitude and temperature but I was wondering where others are setting them. I am using 10% nitro fuel and find that the best setting (according to tach) is around 1.5 turns out (slightly rich compared to peak). I would expect that higher nitro would require a slightly richer setting. (How much more for 20%?) I am getting a great idle just over 2,000 and around 10,000 on a 15 x 6.
Ross
Ross
RE: Saito-100 Needle
mine is set at1.75 out at 70 deg and 1.5 at 105deg, these are two settings that i have noticed here lately and in no way are reccomending these settings, yoou need to peak tune yours at the beginning of each session and in between if you get changes in the weather or notice it not running right
NB, CANADA
Thanks for the info. I was not looking for recommendations but I had read somewhere that a user had theirs out 2.5 turns which concerned me a little. I feel a little better with my 1.5 turns on 10% nitro fuel. Ambient conditions as well as machining variations would be expected to make a difference but I would be surprised to see that much difference.
Ross
Ross
ORIGINAL: Ross Kean
Ross
Ross
