Club MAGNUM !
#1726
RE: Club MAGNUM !
I had a very similar engine to Fiery's , a Magnum Pro 45 which ran like crazy , but regrettably was totalled in a crash.
I eventually drew a blank on getting a spare crankcase and built all the undamaged parts over into
an old OS FSR 40 crankcase. It took an evening of machining, but now it's my "cheat" engine, packing way more punch than a standard FSR 40.
#1727
My Feedback: (15)
IL
RE: Club MAGNUM !
Hi Guys,
Just purchased my 1st Magnum, a XL-91RFS . Brand New in Box. Really got a good deal on it 120.00 shipped to my house. Have you had good luck with this motor? I`v owned Saito`s and YS in the past, but for 120.00 could`nt past it up!
Frank
Frank
#1731
RE: Club MAGNUM !
Hi Everyone,
Someone donated a NIB Magnum GP-44 2S engineto our Club for use in a trainer. All of the parts are there except for the Needle Valve.
Can someone point me into the direction of where I could find one, or if you have one you'd like to sell, could you let me know? I'd like to get this engine into one of our trainers to replace its aging OS 40FP.
I presume that a 10x6 or a 11x5 is the go-to prop for this engine on 10% nitro??
Thanks a lot,
Bob
Thanks a lot,
Bob
#1732
RE: Club MAGNUM !
ORIGINAL: Jerrybl
I have a mag. 91 four stroke I would like the instructions for setting the cam timing. Had the instruction placed them in safe place where?
#1733
RE: Club MAGNUM !
ORIGINAL: N1EDM
Hi Everyone,
Thanks a lot,
Bob
Hi Everyone,
Thanks a lot,
Bob
#1734
RE: Club MAGNUM !
Thanks for that, Raven, but this is a 2-Stroke. I see the similarities between OS and Magnum and I also see differences. I am not comfortable using the needle from one manufacturer into the carb of the other. The two needles have different tapers which could lead to problems.
I wonder if I used a OS carb that had the right throat diameter???
Still and all, I'd prefer to use an original needle valve for this magnum GP-44 if one could be found.
Bob
Bob
#1735
RE: Club MAGNUM !
ORIGINAL: N1EDM
Bob
Bob
I understand you're concern about different tapers etc, but believe me they do swap and will work fine. Provided you can tune the engine adequately, a slightly different taper (if it exists) isn't going to hurt anything.
Most engine manufacturers use an industry standard angle because it simply suits the machining processes. Who's going to spec an specific odd taper?
Using different carbs may work, but if you think the needle makes such a huge difference why consider swapping a whole carb?
Yes, I'd like to use an original needle (like you) but I wouldn't get carried away hunting one down if a common OS part fits.
#1736
RE: Club MAGNUM !
Thanks for that, Raven.
As far as the carb swap is concerned, if I have a OS carb that has mounting dims that will fit the Magnum, then the it won't hurt anything - the engine will either run great or poorly.
My worry is that with a HSN that isn't the same taper as the socket on the spraybar, things could gall up. But it bears consideration.
Thanks for that,
Bob
Thanks for that,
Bob
#1737
RE: Club MAGNUM !
ORIGINAL: N1EDM
Thanks for that,
Bob
Thanks for that,
Bob
#1738
NY
I have recently gotten a mag 1.20 2-stroke on an ultimate120. During break-in it seems it will not hold pressure in the tank, and on the low end the engine will quit due to no back pressure in the tank thus no fuel to the engine. Does this engine requires a fuel pump to eliminate this problem? the tank has been rechecked and is not leaking.
#1739
If you have the engine set up so that the pressure line is running to the tank directly from the muffler, then the tank will not hold pressure when the engine is not running. This is normal. I don't know if I've answered your question or not, or if you had something else in mind for that 120.....
Just my $.02
Bob
Just my $.02
Bob
#1740
NY
Yes the pressure line is from the muffler to the tank. when the engine is running at full throttle it runs fine, but when I chop to low throttle the engine runs for less than a minute and quits with plenty of fuel still in the tank.
#1741
Thanks Airborne... my point was that unless you had a check valve in line, your tank is not going to hold pressure when the engine shuts down. It will just vent out to the muffler. Or, did I read your post wrong and just make a complete idiot of myself by answering the wrong question....
Bob
Bob
#1742
NY
My question is that the engine will not idle. It runs fine at full throttle, but when you go to low throttle to idle speed it quits like there is no back pressure in the tank. The tank is not leaking and the tank cap is on properly. Also, each time I go to start the engine I have to place my hand over the muffler exhaust so the engine will start up. I heard about opening the Low speed end cause new engines may have been closed more than normal, and the use of a check valve on the exhaust line, which I have never seen done before.
Your thoughts and thanks
#1743
I am thinking that the low speed needle (aka LSN) is just not adjusted correctly. If you can keep the engine running for a few seconds at low throttle (before it quits) perhaps you could pinch the fuel line going into the carb. If the engine speeds up, then the LSN is too rich. If the engine dies immediately without speeding up, then you are too lean and need to richen it up a little.
Low Speed Needles are a little tricky to adjust in that you should only adjust it about 1/8 turn at a time. It just takes a little patience and a little time. Give this a try and let us know how you make out.
Bob
Bob
#1746
Hi everyone, it's me again...
I'm rebuilding a Magnum XL-91 2-Stroke engine. I'm having a helluva time finding head gaskets for it (p/n S91112). I tried an OS 91FX head gasket just for fun but it's much thicker than the two S91112's that are called for and slightly larger in diameter.
Also, can anyone verify that the Magnum woodruff key (Magnum p/n S91218) is the same as the woodruff key that's used on the 91FX?
I just can't seem to find anyone with stocking parts any more. I found a woodruff key at Hobby People but no gaskets (which are what I need mostly).
Bob
Bob
#1747
My Feedback: (26)
TX
Harbor Freight has a complete selection of Woodruff Keys for a few bucks, and an ASP Brand motor's parts will work as well, they are the same engines... I found these links in 10 seconds...
http://www.gravesrc.com/category_s/247.htm
http://globalservices.globalhobby.com/part/210970.asp
I believe you have an XLS-91...
http://www.amazon.com/Magnum-Parts-G.../dp/B001AETNG2
http://www.globalhobby.com/public/mfr/MAGXLP24.asp
