Club Enya
Reply
Old 09-01-2017, 11:46 AM
  #2751
tamanduarj
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Naaa it original all right
Comparing both carb. Noticed that when the barrel is completely open, or closed, no air gets by. It seems to work only when the barrel is beginning to open and is half open.
tamanduarj is offline
Old 09-02-2017, 06:53 AM
  #2752
1QwkSport2.5r
1QwkSport2.5r's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If it's a metered airbleed like many larger Enya carbs are - the airbleed is only a trim!. Not uncommon for a little tiny bit of air to get by the screw - but I wonder why you need the airbleed screw set that rich? Remember an airbleed trim works opposite as an idle needle valve works. Blocking the hole makes it richer. And yes, the airbleed hole is covered by the barrel as the barrel opens.
1QwkSport2.5r is offline
Old 09-02-2017, 11:42 AM
  #2753
mchandrayan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't think this carb has the metered air bleed like the 120 four stroke
mchandrayan is offline
Old 09-02-2017, 12:40 PM
  #2754
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Whether it's metered or not - I've never had an Enya that required the airbleed completely closed (full rich); or for that matter, full open.
Old 09-02-2017, 01:52 PM
  #2755
GallopingGhostler
GallopingGhostler's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If spray bar isn't properly aligned across throttle opening can affect things. Also any air leaks in back plate, bolt on crank nose, carburetor base, etc. can affect things.
GallopingGhostler is online now
Old 09-02-2017, 03:07 PM
  #2756
Hobbsy
My Feedback: (100)
Hobbsy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If the carb barrel doesn't move in and out it is a metered carb, this applies only to Enya's, Saito and OS both MFR small carbs that are not metered, like on the OS .26 and the Saito .30. In both cases they throttle cleanly. I guess being that small,the airfow velocity/fuel draw can do,the metering. That's only a guess.
Hobbsy is offline
Old 09-02-2017, 03:27 PM
  #2757
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is probably the same carburetor. Maybe not. Barrel doesn't move in and out anyway. NON-metered.
ID:	2230295   Click image for larger version
ID:	2230296   Click image for larger version
ID:	2230297   Click image for larger version
Old 09-02-2017, 03:34 PM
  #2758
Hobbsy
My Feedback: (100)
Hobbsy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If I have the correct picture it should have a slot like this if it's a metered carb.
Hobbsy is offline
Old 09-02-2017, 03:36 PM
  #2759
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Old 09-02-2017, 03:39 PM
  #2760
Hobbsy
My Feedback: (100)
Hobbsy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is that carb from a .40 or smaller econo engine, thanks.
Hobbsy is offline
Old 09-02-2017, 04:19 PM
  #2761
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The carb I pictured is from a .35 I think. The carb on my SS40 is larger all around and a bigger neck size as well as a metered idle circuit. I have three or four of the pictured carbs and none are metered. I'm guessing from some old cross scavenged .35s.
Old 09-02-2017, 06:13 PM
  #2762
tamanduarj
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just changed the carb and tomorrow will be flying day.... So I will be back with some news. By the way, it comes from a .40 X 6101. It is not leaking from any place at all. Used some water, soap and a hose to push some air in.. No bubbles . Just love Enya engines.. Have 15 of then hehehehe
Old 09-02-2017, 06:31 PM
  #2763
GallopingGhostler
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't love them as much as you, only have 11.
Old 09-02-2017, 10:29 PM
  #2764
Mr Cox
Mr Cox's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by tamanduarj View Post
Have the carb in the photo and as much as I screw the slow mixture the blending hole steel lets some air in. In doing so I get a lean mixture. Even removing the screw spring and tightening is to the bottom air gets by. Is that the norm?
Yes, that is the norm. All engines will need this airbleed function at low throttle, otherwise they would run too rich. There are other ways to solve it too, like an asymmetrically positioned bore in the carb, or a notch in the barrel etc.
If you engine runs too lean with the airbleed fully closed, it indicates an airleak somewhere else. Or a fuel-draw problem, perhaps a too low tank, etc.
Mr Cox is offline
Old 09-03-2017, 12:18 AM
  #2765
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think I'm still holding steady at 13 Enya engines even though I am probably forgetting one or two.
(5) - 15-IVs (ferrous)
SS30bb (ferrous)
SS35bb (converted Heli engine, ringed)
SS40 (ferrous)
40CX (AAC)
.45 (twin ringed) (model 6001)
46-4C
60-4C
R120-4C
Old 09-03-2017, 06:55 AM
  #2766
Hobbsy
My Feedback: (100)
Hobbsy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There are three Enya's for sale in the MarketPlace, one is an aluminum Chrome .60 a really great engine.
Hobbsy is offline
Old 09-03-2017, 06:58 AM
  #2767
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've read they're barn burners. I want one, but have to wait awhile for funds to come available.
Old 09-03-2017, 12:16 PM
  #2768
Hobbsy
My Feedback: (100)
Hobbsy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
They were NIB and all that's left is the SS 40.
Hobbsy is offline
Old 09-04-2017, 09:36 AM
  #2769
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've got an SS40. Sweetheart of an engine as is the SS30. The 40CX runs pretty nicely as well, but not a powerhouse. A tiny bit stronger than the SS30 and nearly the same power as the SS40.
Old 09-04-2017, 09:40 AM
  #2770
pipek
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It is new
Enya 49 X - Edi's Modellbauparadies
which silencer would it need?
pipek is offline
Old 09-04-2017, 09:57 AM
  #2771
Hobbsy
My Feedback: (100)
Hobbsy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
M401X40X,45X,49X
http://www.enya-engine.com/accessories_E.html
Go to Enya Metal Works, Accessories, about the middle of the page
Hobbsy is offline
Old 09-04-2017, 10:01 AM
  #2772
pipek
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Hobbsy
pipek is offline
Old 09-04-2017, 10:02 AM
  #2773
Hobbsy
My Feedback: (100)
Hobbsy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You're very welcome.
Hobbsy is offline
Old 12-02-2017, 11:39 PM
  #2774
rrengineer
rrengineer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default VT 240 And New Big Stik
Do you guys think a VT 240 is enough engine for the new Giant Big Stik XL?
rrengineer is offline
Old 12-03-2017, 03:25 AM
  #2775
Hobbsy
My Feedback: (100)
Hobbsy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There are four variations of the 2.40, no deal breaker differences.
Big Stick XL engine recommendations==55 to 61 cc, equaling 3.355 to 3.721 cubic inches.
Enya 240 displacement===2.488 cubic inches, it would be iffy in my opinion.
Hobbsy is offline
