If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 46 of 108 FirstFirst ... 3644454647485696 ... LastLast
Results 1,126 to 1,150 of 2685
Thread: Club Enya
  1. #1126
    smithcreek's Avatar
    Join Date
    Jun 2008
    Westerly, RI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club Enya
    Flight report. A 16lb BUSA Phaeton 90 on floats flies just fine on an Enya 120-4C with a 15 x 7 APC prop. I picked up the plane on Craigslist, my first ARF and after a refurbishing, re-maidened it yesterday. Here's a picture as it's pulling back in to shore.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    For a kit you are, and to a kit you shall return.
  2. #1127
    smithcreek's Avatar
    Join Date
    Jun 2008
    Westerly, RI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club Enya
    Does anyone know the size of the carb/intake manifold o-ring on the 120-4c (not R). I have the manual but it only gives a part number, not an actual size. My is shot and needs replacement.
  3. #1128
    CustomPC's Avatar
    Join Date
    Apr 2004
    SydneyNSW, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club Enya
    Hi,
    Is a pumped Enya 60XF II Al-Chro a decent engine?
    Is it a revver or a torquer?
    Would the pump be likely to cause issues on an brand new engine that's been in storage for many years?
    Would it power a Great Planes Escapade .61 adequately?
  4. #1129
    Join Date
    Aug 2002
    Santa Ana, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club Enya
    I think they only made six or so, but I sure could use an Enya .11 if you happen to have a spare one.
    eloym@dslextreme.com
  5. #1130
    Kostas1's Avatar
    Join Date
    Dec 2005
    AthensAthens, GREECE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club Enya
    Looking good....
    **Check my gallery for more pictures**
    http://www.rcuniverse.com/community/...y&memid=222042
    Club Saito member #706
  6. #1131
    Mr Cox's Avatar
    Join Date
    Jul 2007
    Karlstad, SWEDEN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club Enya
    ORIGINAL: rrengineer
    Well, no replies for instructions for an Quicky .09, so does anyone know what size prop for break-in/flying for this engine?
    I little late I guess but a 7x4-7x5 should be good, as the piston and cylinder are common to the other 09 engines as far as I know.
    The Enya 11CX are still being made too, and then you get ABC technology.
  7. #1132
    earlwb's Avatar
    Join Date
    Aug 2009
    Grapevine, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club Enya
    ORIGINAL: EloyM
    They show up on ebay from time to time.
    But shtterman who specializes in Enya control line stuff can get the engine for you.
    he has a store onEbay. www.ebay.com/itm/ENYA-09-IV-R-C-NIB-CURRENT-MODEL-/290514256539
    I had bought parts to rebuild several engines from him already myself.
    You can also buy direct from Enya if you like too.
    Club Saito #722, Sig Kadet Brotherhood #80, GlowHead Brotherhood #14,
    AMA # 928076
  8. #1133
    downunder's Avatar
    Join Date
    Oct 2002
    Adelaide, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club Enya
    ORIGINAL: CustomPC
    No, terrible engine, not worth having, leave it alone, I wanna BID on it!
    Just kidding, but if you're looking at what I saw it's actually an XF-III, it's just the instruction sheet that says XF-II. If you look carefully at the LH engine mount you can make out the III stamped there. Just for your peace of mind, I've already got one so don't really need another . Go for it, they're magnificent.
  9. #1134
    Join Date
    Jan 2002
    Ringgold, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club Enya
    ORIGINAL: CustomPC
    Hi,
    Enya fuel pumps are gear type mechanical fuel pumps and they do not rely upon fragile, time sensitive mylar or silicone diaphragms, as do OS and other manufacturers' pumps. Other than haviing to replace a common metric o-ring, no, it should not be problematic.
    This is one of the strongest 10cc engines available and it is a revver. You might be surprised at just how much low end torque can be generated using this engine with a stretched tuned pipe.
    Ed Cregger
    \"Practice makes prefect\"
    Saito Club Member #52
  10. #1135
    CustomPC's Avatar
    Join Date
    Apr 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club Enya
    ORIGINAL: downunder
    Drats! You saw right through me
    Truth be told i don't need it either, but every once in a while a rare gem appears on fleabay amongst all the chinese crap.
  11. #1136
    Join Date
    Feb 2002
    Hervey Bay Queensland, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club Enya
    I acquired a 60's .29 TV-IV Special from an elderly gent, complete with additional high compression head, muffler assy, all paperwork and a box that still looked new. It is in very good cosmetic order, unmarked and unmolested, but the P/L fit is gone.
    After 35 years I am thinking of getting back into stunt.
    I emailed Ken Enya today ... two hours later ... reply, and yes, he can supply a new piston and liner set ... for under $30! Astonishing.
    I have a lot of time for the engines and the people who make them. Can't wait to run it in again, the slow, patient way, using full castor lube fuel.
  12. #1137
    Join Date
    Apr 2009
    Oberschoena, GERMANY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club Enya
    ..good to know :-)
    I got an 29-IV RC special (Model 5224) some weeks before. It was totally gummed up.
    After som cleaning it appered as near new shiny engine, compression is very good too.
    I only have one head, can you tell the difference of the high compression head to the normal
    (in mm), I don't know what is mounted...
    Kind Regards,
    Holm
  13. #1138
    controlliner's Avatar
    Join Date
    Mar 2009
    Ontario
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club Enya
    I have two of the same 5224 .29's and when you lay both heads along side of each other (off the engine) you can see the difference in the depth of the combustion chamber. The HCH rests deeper into the liner than the LCH does.
    \"Keep it clean and not too lean\" Duke Fox
  14. #1139
    Join Date
    Apr 2009
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club Enya
    You made my day!
    How should it be done then, when you only have one head?
    Regards,
    Holm
  15. #1140
    earlwb's Avatar
    Join Date
    Aug 2009
    Grapevine, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club Enya
    ORIGINAL: tiffitech
    You made my day!
    Regards,
    Holm
    I looked through my stuff, but I didn't find my high compression head. But a standard head goes about 2.5mm deep into the cylinder.
    The high compression head is more obvious that it goes in a little more deeply.
    here is a pic of a standard compression head from one of myEnya .35 engines, the pic didn't quite show the 2.5mm depth very well.
    AMA # 928076
  16. #1141
    downunder's Avatar
    Join Date
    Oct 2002
    Adelaide, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club Enya
    The low compression head projects about 2.2mm into the cylinder while the HC head projects from 3.1 to 3.5mm depending on whether it's the plain bearing or the BB Special. The BB Special used the 3.5mm projection to give 9.5:1 compression as against 9:1 for the plain bearing. Low compression head was 7.5:1 compression.
  17. #1142
    Join Date
    Feb 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club Enya
    Brian, like yourself I tend not to use Nitro in sports glow engines.
    It seems logical for it to be preferable (in that case) to use the high compression head?
  18. #1143
    Join Date
    Apr 2009
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club Enya
    I've measured the head that's on my .29BB, it is approx 3.4 mm so it seems to be the HC Variant, Thanks Earl and downunder..
    Kind Regards,
    Holm
  19. #1144
    downunder's Avatar
    Join Date
    Oct 2002
    Adelaide, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club Enya
    ORIGINAL: fiery
    Yep, I'd definitely use the high compression head and I'd think it'd just as good for fuels up to maybe 10-15% nitro (for those who like to use nitro ). One day I have to get myself one of those Specials just so I can say I've got one .
  20. #1145
    1QwkSport2.5r's Avatar
    Join Date
    Oct 2006
    Cottage Grove, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club Enya
    So I wanted to join the club, and bought this Enya 30SS (BB) engine. It is new and un-run. It came with 3 documents and what look like stickers in the original box. The casting work looks quite nice. It looks to have the airbleed carb on it, so this will be a first for me. I've only dealt with 2-needle automix carbs.
    This was said to have been purchased at a hobby shop that was going out of business 5 years ago. I think it was a display piece since the outside is a little dusty.
    The engine seems to be well oiled, and the bearings are silky smooth. Being that the engine isnt brand new off the shelf, I popped the head off to make sure the piston and liner are clean. I'm glad I did because I found some sort of debris stuck to the top of the piston. (there was no glow plug in it) I'll clean this out before running it. I snugged the head back down (I went light on the torque as to ensure the case doesnt get distorted) and checked the front housing screws. 3 were snug and 1 had stripped threads in the hole. I also found the supplied screws for the muffler were both bent. I want to replace the bent muffler screws and I suppose tapping the stripped hole one size bigger should be done. The bad screw is the bottom left looking at it from the front. So, my questions are: What is the size and pitch of the muffler screws and front cover screws? (They are socket head screws) Also, can anyone estimate when this engine was made?
    I'm going to clean it up really nice and re-oil it and if the weather behaves, break it in sometime in the next week or two. Overall, I am really happy to have this engine. I look forward to hearing its song.
    GlowHead Brotherhood #3
    Real engines use glow plugs.
    R.i.P Jacob Wetterling #11 10/22/1989
  21. #1146
    earlwb's Avatar
    Join Date
    Aug 2009
    Grapevine, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club Enya
    That looks like a excellent runner to me. it is just itching to be used on something.
    AMA # 928076
  22. #1147
    Join Date
    Oct 2006
    Cottage Grove, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club Enya
    ORIGINAL: earlwb
    I pulled the front cover off and found some dried up crusty reddish-brown oil all over the crank and inside of the crankcase. I'm soaking some of the engine parts in fuel right now to get that dried oily slime out and seal it up.
    The piston to liner fit isnt as tight as I thought it was going to be. Thats okay though, this baby is gonna run real nice. I can feel it.
    I think when I get the money to do it, I'm going to order 2 kits. 1- Bridie Krafty .60 (with TT .46 power) to learn on and a Sig Kobra (SS30) to go fast with. Chances are the Kobra will stay in the box until I can fly without crashing.. Just gotta work on convincing the wife I need them.
  23. #1148
    CustomPC's Avatar
    Join Date
    Apr 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club Enya
    ORIGINAL: 1QwkSport2.5r
    It will get better with some running after a build up of castor lines the cylinder sleeve.
    The Enya SS engines with steel sleeve and cast iron piston are designed in a way that castor forms an integral part of the operation.
  24. #1149
    Join Date
    Oct 2006
    Cottage Grove, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club Enya
    ORIGINAL: CustomPC
    I am certainly not complaining about the fit. I have some car engines that you can see light between the piston and liner at BDC with light shining through backplate (these engines are less than 2 gallons in and are asian sport engines). The Enya isnt like this. There is definitely a "snugness" to it 1/2 way towards TDC but its not one of those "so tight I need a heat gun to start it" sort of things.
    I need to fix the front cover (stripped screw) and mount it on my test stand.
  25. #1150
    Join Date
    Apr 2007
    Wollongong, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club Enya
    ORIGINAL: downunder
    Like this? http://www.ebay.com.au/itm/vintage-E...d#ht_614wt_907
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
