Club Enya
Reply
Old 09-19-2012, 12:42 PM
  #1676
1QwkSport2.5r
1QwkSport2.5r's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Club Enya
Quote:
ORIGINAL: rrengineer
Ebay item number 290618529766. $18.99 plus $2.75 shipping. I bought 4 to try them out.
Thanks for the info, but like I said. If the Enya #3 plugs don't help the engine behave better, it's going on the shelf for display. I've already spent enough time and money to get this engine running reliably. It runs well on top, and idles okay. No explanation on the 7,300rpm lean out, and the slow/stumble transition. It's so rich on the low end that on throttle up you can see oil spraying from the exhaust. It's only getting 20%oil.
There is no carbon on the piston or in the exhaust.
1QwkSport2.5r is offline
Old 09-19-2012, 12:46 PM
  #1677
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: earlwb
I typically use Fox Miracle glow plugs in my 4 stroke engines. It works well for me. If I remember right they sell for around $7.95 each maybe less.
But when glow plugs cost about $20 each with $275 shipping, it is too rich for my blood.
I remember last year when Horizon accidentally listed Saito glow plugs for $34.95 each plus shipping.
Of course they corrected it fairly fast, I hope no one got ripped off at the time though.
I tried a few plugs, a miracle plug being one of them. I have a thread in the tach forum for my 60-4C. Miracle plug was the worst performing of all tested. My 860 foot elevation may have something to do with that, but it ran no different using 15 or 20% nitro. So far it runs best on the idlebar or MC4C. I'll try the #3 Enya plug when they arrive. I use the miracle plug in my ST S90K instead.
Old 09-19-2012, 12:53 PM
  #1678
earlwb
earlwb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I know you probably have done it already, but have you tried test running the engine on a engine test stand instead of your airboat (I assume)?
When something isn't behaving, I pull the engine out of whatever it was in and put it on the test stand. If it runs good there, then I know where to look for the problem.  I have had engines before have running problems in a airplane, but I didn't see anything wrong. So I test run the engine on a test stand and it runs good again. So then I know there is a problem with the fuel system somewhere.  I had this happen once and when I pulled out the fuel tank and got to looking at everything I discovered the fuel tubing was partially blocked off with a chunk of silicon tubing inside. Apparently when they were extruding the tubing or something, a glob came off and went on down the line like that. It was very difficult to see too.  I have also bought fuel tubing in bulk before and found tiny bits of styrofoam inside the tubing too. Then one time I found a little bug wedged inside the tubing too.
Someone else had no end of trouble with a engine and they discovered the fuel tubing wasn't hollow at all, but solid, but the ends were hollow though. That sure makes for some frustrating issues.
One other thought is the carb might have a issue with it. Wrong needle valve for the engine maybe, or a partially clogged or obstructed passage or something. It isn't common with the Japanese engines but every once in a blue moon they mess up a carb somehow at the factory.
earlwb is offline
Old 09-19-2012, 02:23 PM
  #1679
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Earl - I did indeed have it on my test stand for quite awhile. 1 hour break-in time and another hour or so getting a feel for the carburetor and learning the engines quirks. I noted that it cut out on transition on the stand and learned of the need to have it burbly on the low end. It ran o.k. This way, transitioning slowly because it was so rich. On the craft, I had it set up the same way, same prop, and put an OS f plug in it. If its not obscenely rich, it cuts out on transition even with a slow servo. So back to the sloppy rich idle (airbleed nearly closed) and slow transition. It is not very smooth, and the weird 7300rpm lean-out has me bothered. The tank is an 8oz Hayes, medium Dubro tubing which is all new, no muffler so tank is vented. I even went so far as to open the 3rd port on the tank so it has two vents, no change.
No air bubbles in the fuel line, either. Crankcase vent has about 4" of tubing coming off of it, it runs no different without any tubing attached.
Edit: The carb is clean. Been through it 4 times now. The metering grooves in the barrel were checked for crud and debris, and there was none found. took a Xacto blade to the groove just to make sure its clean, and it is. The needle assembly was removed, blown through with compressed air. Replaced all tubing again. I changed back to the 12x6 APC prop and kept the new McCoy MC4C plug in it. With the 12x6 prop on it, it behaves better. The lean spot in the upper part of the rpm is up to about 8200rpm but doesnt cut out quite as bad. I didnt leave the throttle there for very long to see if it would quit, but I think it still would. Maybe its just not ready for higher prop loads?
When the video is done uploading, I'll post a link.
Old 09-19-2012, 02:57 PM
  #1680
Ram Jet
Ram Jet's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: 1QwkSport2.5r
Quote:
ORIGINAL: Ram Jet
I was going to suggest the Enya #3 plug to you. Over the years I have read over and over again on this forum that the #3 is what two and four cycle Enyas like. Myself i don't mind buying Enya plugs regardless of the cost. Why, because the poor SOBs at Enya have never gotten a dime from me. I bought my .09, 2-.19s, .40BB, .46, 1.55 all on eBay. I feel a-little guilty. Especially when I contacted Ken Enya yesterday and asked for the PDFs of the specs and instruction shetts for my .46 and 1.55. They were in my E-mail box inside of two hours. Great support from a great company and I buy my engines on eBay. I hang my head. Buy the GD #3s from Enya direct. They are great plugs and how much effort have you put into your engines thus far? What's a couple of bucks for what I think are the finest model engines you can buy?
Cheers,
Bill
The last time I went looking for Enya #3 plugs, I couldn't find any nearby. Most of the online shops that sell them were either out of stock or wanted $12 each PLUS shipping. I just came across a new shop I hadn't seen before that has them for $6 each plus $6 for shipping, and I get a first time buyer 10% discount. I ordered three plugs. When they show up, I will promptly try one.
Good move!
Cheers,
Bill
Ram Jet is offline
Old 09-19-2012, 03:01 PM
  #1681
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Ram Jet
Good move!
Cheers,
Bill
I dont think it will be the magic cure, but perhaps it might make it run better. Here's a link to a short video I just took. Swapped props, kept the McCoy 4C plug in it, normal 5/20 fuel. It runs far better on the 12x6 than it does on the 11x9 or 13x6. I forgot to get the lean spot up around 8200rpm on tape, but you should be able to hear the rough off-idle stumbling and the hanging rpm going back to idle.
http://youtu.be/In_pGCyAQsE
This is the best I can get it to run, period.
Old 09-19-2012, 11:12 PM
  #1682
NM2K
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: earlwb
And there is part of your problem (15 to 20% nitro in fuel).
This was one of the first glow four-stroke engines ever made. In those days, most of the world was still running no or very little nitromethane in the fuel. If the timing is advanced too far by running too much nitromethane in the fuel of a glow engine, how do you retard the timing? The smartest way is by reducing the amount of nitromethane.
When I first bought my new Enya 80-4C, I was curious as to how it would run on 5% nitro fuel. It ran great. One of the local four-stroke experts, Jim Garrahan (May he rest in peace) advised me that the Enya four-strokes of the days needed to run a bit juicy at idle, when compared to contemporary two-strokes. It turned out that he was right.
The Enya 60 & 80 4C engines will never throttle as well as a modern Saito or OS four-stroke. They will stay running when many modern engines would have quit. If you're looking for an engine with snappy throttle response, the Enya engines' designs are too old to bring you any joy. On the other hand, if you want reliable running engines that will run a long, long time, then they will make you quite happy.
Ed Cregger
NM2K is offline
Old 09-19-2012, 11:56 PM
  #1683
Ram Jet
Ram Jet's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: NM2K
Quote:
ORIGINAL: earlwb
Ed Cregger
As usual Ed you are right on it. You make a ton of sense. Maybe things I should keep in mind when I first fire-up my .46 4-C and my 1.55 4-C. I have read over and over again here the the Enya four cycles like 5% nitro.
Cheers,
Bill
Ram Jet is offline
Old 09-20-2012, 01:09 AM
  #1684
Ram Jet
Ram Jet's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thats good to know, Bill. I'll make a note of that if/when I have to replace the bearings in my 60-4C. I found another bearing joint on the internet, AvidRC.com. These guys sell a huge assortment of bearings, all for $1 each. I bought a bunch of their bearings for my RC cars axles and transmissions, and so far they seem smooth and work well. I dont know if they carry engine bearings or not. I'll have to look into it.
Since I'm thinking about it, I have to ask the Enya folks here... My 60-4C has about a gallon through it now, tried several different glow plugs. I can get satisfactory performance from it, but it will not transition smoothly from idle. Either its lean and cuts out slightly on transition, or its burpy and smokey and transition is slow. Sounds as though its going to quit. If I set it between these two ''extremes'' it will still burp and gurgle. Will this engine ever transition smoothly? I've read a number of articles and reviews of this engine when it came out (the last article was a review by Peter Chinn) and they've all said that these engines ran well, transitioned good, and ran on straight FAI fuel for break-in.
I've tried several plugs, OS F, Fox Idlebar, Fox Miracle, McCoy 59. Fuel I've tried is 5% nitro / 20% castor, 15% nitro / 18% oil (80/20) byrons gen2, 20% nitro / 20% oil (50/50 cas/klotz). Props I've ran are 12x6 and 13x6 APC, both fully balanced (blades and hub). On the 12x6 it transitions rich, but it sounds better than when running on the 13x6. After revving up and back down to idle, it hangs a high idle for a moment, then drops to the burbly rich idle it seems to like. If you try throttling it before this ''high idle'' drops, it cuts out. I have the engine idling between 2700-3000rpm per the Enya instruction leaflet. The airbleed is about 2/3 closed, and to get it to idle at this setting, the throttle barrel is open about 1/4-1/3 of its travel. Any thoughts? Am I beating a dead horse expecting a relatively smooth transition? I expect some burbles, but the other day while running the engine it quit on me in an inconvenient spot. I've been running it about 300rpm rich of peak RPM.
Just FYI. Thers a complete bearing set on eBay for and .80 4-C for a buy it now of $42.00 on Ebay. Any chance the .80 bearings will fit your .60? If so I'll give you the item number.
Cheers,
Bill
Ram Jet is offline
Old 09-20-2012, 03:01 AM
  #1685
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: NM2K
Quote:
ORIGINAL: earlwb
Ed Cregger
I need to start being very very very specific and drawing pictures. I quit bothering with using more nitro in the 4C because it doesnt make it run any different. I only tried 15% and 20% once, several months ago. I only run 5% nitro in all of my engines, any more is a waste, period.
I dont care if its not snappy and ultra smooth, I dont want it to quit. It quit on me last weekend in a bad place and that has me concerned. I don't trust it yet. I'll put the proper glow plug in it, run the normal fuel I normally use (5% nitro 20% castor) and try again.
The only engines I run on 20% nitro on a regular basis is my r/c car engines because thats what they're designed to run on. All of my Aero engines except my TT .46 are designed for little or no nitro so I use very little 99.9% of the time.
Quote:
ORIGINAL: Ram Jet
Cheers,
Bill
Thanks for the info, though I'll buy my bearings from Paul at RC-Bearings. I avoid Ebay if at all possible. I do not know if the bearings for the .80 fits the .60, but I shouldn't need bearings for quite awhile.
Old 09-20-2012, 03:39 AM
  #1686
Ram Jet
Ram Jet's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: NM2K
Quote:
ORIGINAL: earlwb
Ed Cregger
Quote:
ORIGINAL: Ram Jet
I went to the RC Bearing website yesterday and was disappointed. They did not have bearings for my .46 listed on their site and there was a statement that they no longer took phone orders. Bye bye RC Bearings. Then I went to Boca Bearings website and they only had 3 of the four bearings I needed but the three they did have were in stainless steel. Then I found all four bearingsd from one seller on eBay for $40.00. I'm waiting to hear back from the seller about some specifics. I too am nervous bout buying bearings on eBay. We'll see. I should probably just contact Ken Enya and buy them direct. I'll keep you posted.
Cheers,
Bill
Cheers,
Bill
Ram Jet is offline
Old 09-20-2012, 08:03 AM
  #1687
NM2K
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My Enya four-strokes seldom quit running, if ever, unless out of fuel, BUT that is after break-in. Break-in times vary considerably, depending on ambient temperature, fuel type, prop size, glow plug brand, etc. As Jim Garrahan used to tell me, keep it rich and you won't hurt a thing.
Ed Cregger
NM2K is offline
Old 09-20-2012, 08:11 AM
  #1688
NM2K
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Ram Jet
Cheers,
Bill
As long as your engine hasn't taken to shedding bits and pieces internally, the Enya #3 glow plug should last a good long time. Just keep that fuel mixture a bit on the rich side. Even the best glow plug in the world can be melted into obliviion with a lean run. I know that you know better, but there may be some folks reading this that haven't thought about it before.
Ed Cregger
NM2K is offline
Old 09-20-2012, 08:13 AM
  #1689
Ram Jet
Ram Jet's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: NM2K
Ed Cregger
Just a tad off topic here. My motorcycle guru is (was R.I.P.) a guy named Gordon Jennings. He said that you get the most power out of a two cycle engine by feeding it as much oil and fuel as it can ingest. I run everything, two and four cycle) on 20% lubricant. The caged ball bearings like fumes for oil but the piston, ring and cylinder love lots of oil. My neighbor is a motocross semi pro rascer and runs two cycles. He runs scarey fuel/oil ratios like 80:1. I think he's nuts but I don't tell him so.
Cheers,
Bill
Ram Jet is offline
Old 09-20-2012, 08:27 AM
  #1690
NM2K
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Ram Jet
Quote:
ORIGINAL: NM2K
Ed Cregger
Cheers,
Bill
Wow! Gordon Jennings as a mentor! It doesn't get any better than that.
And I agree with the statement about never having too much oil. Well, almost never having too much oil. Some of the larger glow engines don't care much for it, but I've often thought that that was just a symptom of h aving the engine a little too tight.
Ed Cregger
NM2K is offline
  #1691
Ram Jet
Ram Jet's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Ram Jet
I'll let you know what RC Bearing charges. I think about half or less than the prices you mentioned and you can be sure of the quality from RC Bearings. I'll post the prices - promise.
Cheers,
Bill
As promised here is where my search for bearings has taken me. I visited the RC Bearings website and they didn't list the bearings I needed and no longer accept phone orders. So bye, bye RC Bearings. I then went to Boca bearings and they had only three of the four bearings I needed - in stainless. Bye bye Boca. Then this morning I got (from my eBay "saved search' feature) an E-mail with a .46 4-C rebuild kit which included a Frank Bowan ring. for $40.00. I passed on the ring because I just ordered two from F.Bowman so he offered me the four bearings I need for $24.00. You guys might want to contact this fellow Noel, at nubs@mybluelight.com the next time you need Enya parts. By the way the bearings are genuine Enya replacement parts.
See that! You don't have to spend $80.00 for freakin' bearings.
Cheers,
Bill
Ram Jet is offline
Old 09-20-2012, 08:31 AM
  #1692
Ram Jet
Ram Jet's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: NM2K
Quote:
ORIGINAL: Ram Jet
Cheers,
Bill
Ed Cregger
I never thought about it but then I always run my engines a-bit rich anyway. Good to know though. Thanks Ed.
Cheers,
Bill
Ram Jet is offline
Old 09-20-2012, 08:47 AM
  #1693
Ram Jet
Ram Jet's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: NM2K
Quote:
ORIGINAL: Ram Jet
Quote:
ORIGINAL: NM2K
Ed Cregger
Cheers,
Bill
Ed Cregger
Stock Enya ring are't tight. The brand new stock ring I took out of my nerver run 1.55 had an end gap of .0095", My bowman ring is gapped at .0015 by myself. I purposely bought an over size ring.
Cheers,
Bill
Ram Jet is offline
Old 09-20-2012, 09:05 AM
  #1694
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ed and Bill; thanks for all of your wisdom and advice. It is well received. I always run my engines a bit rich, usually 300-400rpm at least. None of mine get airborne yet so they never unload. This will change, but not for awhile. Got a little boy on the way so hobby time will get limited next year. Nonetheless, I will be patient with my 4C, and it will always get a castor diet. My SS30bb runs fabulous on 25% castor.
Old 09-20-2012, 09:16 AM
  #1695
Ram Jet
Ram Jet's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a brand new .40BB I'm going to install in a Brodak ARF Oriental C/L plane. Would you recommend 25% nitro in the .40? 25% scares me a-little.
Cheers,
Bill
Ram Jet is offline
Old 09-20-2012, 10:52 AM
  #1696
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Ram Jet
Cheers,
Bill
Re-read what I wrote. A few posts back I said my normal fuel is 5% nitro 20% castor. Some of my engines get 25% castor - my SS30bb, and my K&B Sportsters. I only use more nitro if the engine a) will handle it and b) if it needs it. Nitro is expensive, I wont use more than whats needed.
Old 09-20-2012, 11:09 AM
  #1697
Ram Jet
Ram Jet's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Ram Jet
Cheers,
Bill
I have a little K&B 3.5 out board engine. It was my eBay screw Job. All new bearings, con rod, cranshaft. I added a cetrifugal clutch. I've installed a Prather exhaust throttle also. I'm thinking about installing a Perry 3701 carb. The K&B carb is a full throttle affair and I don't believe you can get a decent idle out of it. The Perry should idle down nicely which is ideal with a clutch. There will be no fire it up and toss it. It'll be fire it up and place it in the water - then hit the throttle. Would you recommend 25% nitro fpr my 3.5?
Cheers,
Bi
Ram Jet is offline
Old 09-20-2012, 11:16 AM
  #1698
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Ram Jet
Quote:
ORIGINAL: Ram Jet
Cheers,
Bill
Cheers,
Bi
Some boat guys run as much as 40-50% nitro in the water cooled K&B .21 O/B's. Shim the head a little if needed, but the water cooling keeps the cylinder cool enough with the high nitro. If it were me, I'd drop the head and run 5-10% nitro. No need to burn $50 a gallon glow fuel IMVHO. If using a tuned pipe, I would defintely keep the nitro down, or else plan on keeping plenty of glow plugs on hand. I have no experience with any water cooled engines, so dont take my advice as gospel. If you need more information, hit the Nitro speed boat forum here on RCU. Those guys are K&B 3.5 NUTS. The AMPS outboards are pretty neat too. They used a Fox Hawk .60 in an AMPS outboard, even.
Old 09-20-2012, 12:14 PM
  #1699
Ram Jet
Ram Jet's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Ram Jet
Quote:
ORIGINAL: Ram Jet
Cheers,
Bill
I like the idea of 5 - 10% nitro. Probably 10%. I'm not planning on racing my 3.5 it's going on a Top Speed tunnel and I just want it to run nice, not crazy.
Cheers,
Bill
Cheers,
Bi
Ram Jet is offline
Old 09-20-2012, 01:00 PM
  #1700
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bill - start with 10% nitro and 20% oil. Boats are loaded like airplanes so run plenty of oil. If you find the engine doggy, add nitro or drop the head. I'm not sure how compressed those engines are.
Reply
Display Modes
