Club Enya
#1726
MI
RE: Club Enya
ORIGINAL: 1QwkSport2.5r
Here's one I've never seen before.. Very odd looking.
http://www.ebay.com/itm/Outrageous-l...item35bfe08035
Very interesting crarburetor. I'll bet it's early 50s. A .10 for $125.00. A-bit to rich for my blood. I'm happy to have my littler .09.
Cheers,
Bill
#1727
RE: Club Enya
Forgive me if the answer is buried somewhere, but this is a biggggg thread to search.
I need to buy a new piston ring for a .53 4-cycle, because I spazzed out disassembling the engine . Is there a good domestic source, US or Canada?
#1728
RE: Club Enya
#1729
RE: Club Enya
ORIGINAL: MJD
If you want the list of rings he has on-hand, PM me your email address and I'll forward the list to you.
#1730
MI
RE: Club Enya
ORIGINAL: MJD
I suggest that you get an oversize ring and gap it to your specs. About .001" up to a 1.00 engine and .0015 above that. Those are Franks specs. He will also sell you one that is ready to install. His prices are VERY reasonable.
Cheers,
Bill
#1731
MI
RE: Club Enya
ORIGINAL: captinjohn
I wonder how many of these engines (sold too a new owner) go right back on the shelf. A guy up by Ludington Michigan has rows and rows of Old Glow Engines just setting there.
I have Australian friend I met here who has nearly 100 engines in his collection. He big into Enyas too.
Cheers,
Bill
#1732
MI
RE: Club Enya
Frank Bowman is THE source for piston rings of nearly any model engine ever made. [email protected]
ORIGINAL: MJD
Ditto.
Bill
#1733
NC
RE: Club Enya
"captinjohn, I wonder how many of these engines (sold too a new owner) go right back on the shelf. A guy up by Ludington Michigan has rows and rows of Old Glow Engines just setting there. "
Heck took stock of my giant scale plans collection.
I'm in trouble!
2 years to build a big one.
I'm 41 years old
60 year life span. Probably more like 50 something with my bacon cheeseburger addiction!
19 years left to build
That's 9 planes.
I have over 100 sets of plans!
I'm in trouble!
I'm 41 years old
That's 9 planes.
#1734
RE: Club Enya
ORIGINAL: AmishWarlord
''captinjohn, I wonder how many of these engines (sold too a new owner) go right back on the shelf. A guy up by Ludington Michigan has rows and rows of Old Glow Engines just setting there. ''
I'm in trouble!
I'm 41 years old
That's 9 planes.
I'm in trouble!
I'm 41 years old
That's 9 planes.
Kidding aside, you better get building...
#1736
CA
RE: Club Enya
Enya's are truly fabulous engines. I have an Enya SS45 used briefly back in the 1970s. Then I left the hobby for twenty years. When I came back, I found this Enya in a bottom drawer in my garage (I had moved twice). It was cruddy, nasty, fully involved in filthy oil, and god knows what else. Well I cleaned the outside of it only, and discovered that it still turned over. So, building a new ARF I decided to try and use this Enya but figured I better put it on a test stand first.
I did this, primed it two or three times, and flipped it over. Incredibly it started right up and ran smooth like a clock. So I put it in my Hanger 9 Toledo Special and have been flying it ever since. Oh, I forget to mention, I used the same glow plug that was in it 20 years ago. Nowadays I give this baby some after run oil and take a lot better care of her. I have since acquired about 15 Enya's since then. They are tier one engines without question.
#1737
MI
RE: Club Enya
ORIGINAL: jot1003
With the exeption of two Cox .049 TDs I haven't purchased any serious engines other than Enyas. I don't even consider another brand. My Enya collection runs from an .09 to a 1.55. I NEED a VT240 -just cuz.
Cheers,
Bill
#1738
RE: Club Enya
ORIGINAL: Ram Jet
Cheers,
Bill
ORIGINAL: jot1003
Cheers,
Bill
#1739
MI
RE: Club Enya
I do like my Enyas, still getting used to the 60-4C (now with an Enya #3 plug!) but I am partial to my SuperTigres and K&B Sportsters. Enya really is first rate. The fit and finish is just phenomenal.
ORIGINAL: Ram Jet
OK, inqureing minds want to know. Is life better in Enyaland with a #3 plug?
Bill
Cheers,
Bill
ORIGINAL: jot1003
Bill
Cheers,
Bill
#1740
CA
RE: Club Enya
You're right..Enyas are not being imported to the US any longer, but you can do two things. 1. Google enya metal products and you will find the site in Japan. YOu can by direct if the engines you want are in stock. 2. You have a GOOD chance of finding the engines you want on Ebay. New and used. If you get a used one take good looks at the pictures and be prepare to disassembly and clean up the engine. You can even find new spare parts for enya engines if you need.
#1741
RE: Club Enya
ORIGINAL: Ram Jet
OK, inquring minds want to know. Is life better in Enyaland with a #3 plug?
Bill
Bill
Once I got the low end adjusted, it ran fine. I was running a 12x6 prop at 9600rpm (peak is 10k) but I'm going to try my MAS 12x8 and APC 13x7 the next time I'm out.
Is it normal for these Enya 4-strokes to be rather "spitty" around the carb? My engine mount on my airboat was heavily sprayed with oil/fuel from the carb.
edit: I forgot to mention, I put the Enya plug in with one washer and made my own remote glow driver connector so the plug is in as far as it can be. I can tell the base of the plug is not flush with the inside of the combustion chamber as I expected it to be, I think its 1 thread short. Nonetheless, Its got an Enya plug and I'll keep that one in there and save my other 4-cycle plugs for the SuperTigres. They really seem to like hot plugs. My Enya SS30 has a McCoy MC59 with two washers and it loves it; Broke it in on the same plug thats in it, 2 gallons now. It also really likes 5N/25C fuel too.
#1742
CO
RE: Club Enya
ORIGINAL: Ram Jet
Just a tad off topic here. My motorcycle guru is (was R.I.P.) a guy named Gordon Jennings. He said that you get the most power out of a two cycle engine by feeding it as much oil and fuel as it can ingest. I run everything, two and four cycle) on 20% lubricant. The caged ball bearings like fumes for oil but the piston, ring and cylinder love lots of oil. My neighbor is a motocross semi pro rascer and runs two cycles. He runs scarey fuel/oil ratios like 80:1. I think he's nuts but I don't tell him so.
Cheers,
Bill
ORIGINAL: NM2K
My Enya four-strokes seldom quit running, if ever, unless out of fuel, BUT that is after break-in. Break-in times vary considerably, depending on ambient temperature, fuel type, prop size, glow plug brand, etc. As Jim Garrahan used to tell me, keep it rich and you won't hurt a thing.
Ed Cregger
Ed Cregger
Cheers,
Bill
#1743
MI
RE: Club Enya
ORIGINAL: RC-Bearings
The ratio of oil you run depends on what type of oil it is. When Gordon Jennings wrote his book, Two Stroke Tuners Handbook, he was referring to the bean oils and petroleum based oils available at that time. I raced at that time as well and used 20:1 Castrol R 40. Most of the newer synthetics run very well at 30-50:1. Amsoil has a couple of blends that will run at 100:1. I used their original two stroke oil at 120:1 in my Yamaha roadracing engine and it was still a little rich on oil. Gasoline blends run very different than alcohol fuels.
ORIGINAL: Ram Jet
Cheers,
Bill
ORIGINAL: NM2K
Ed Cregger
Ed Cregger
Cheers,
Bill
Oh, you ought to take phone orders again. You didn't list the bearings for my Enya .46 4C and I couldn't talk to anyone so . . . I do still use the Amsoil litheum grease you recommended for the lower unit of my K&B 3.5 outboard though.
Cheers,
Bill
#1745
RE: Club Enya
ORIGINAL: jot1003
ENYA METAL PRODUCTS
Ken Enya is a very nice gentleman to deal with. His service is second to none.
We have a Enya agent here in Australia but they only offer about 1/4 of the range that Enya make so we deal direct with Ken.
Cheers
Fredo
#1746
RE: Club Enya
Only some kind of nut would use internal combustion engines when we have brushless electric motors today.
Fredo
#1747
MI
RE: Club Enya
Says he with a photo of an Enya VT240 next to his comments. What's your hobby? Flying or maintaining batteries? I have a soft spot for electrics too.
Cheers,
Bill
#1748
MI
RE: Club Enya
ORIGINAL: PWF63
I'm a late commer to this thread but I'd like to sing the praises of purshasing Enyas direct from Enya. URL bellow
ENYA METAL PRODUCTS
Cheers
Fredo
ORIGINAL: jot1003
ENYA METAL PRODUCTS
Cheers
Fredo
I only purchase Enyas. I just bought a new/old stock Enya .40 T.V. marine on eBay. Old technology but built like a brick outhouse. It did come with a ring with a .012" end gap. Frank Bowman fixed that problem. Ken is a wonderful guy.
Cheers,
Bill
