If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 112 of 197 FirstFirst ... 1262102110111112113114122162 ... LastLast
Results 2,776 to 2,800 of 4910
Thread: Club FOX!
  1. #2776
    Join Date
    Feb 2007
    joutseno, FINLAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club FOX!
    plane was my old "workhorse" 1:12 seiran aces combat plane, os.25fx and asp.25 work perfectly,but fox not want to work.[:'(]
    ithink that proplem might be too low pressure in tank? fox muffler exit hole is much bigger than os or asp??
  2. #2777
    Cougar429's Avatar
    Join Date
    Apr 2008
    Tecumseh, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club FOX!
    The exit hole is a factor of exhaust gas volume. If the muffler is much larger the gas has time to cool and reduce in volume. This would require a smaller outlet. Sometimes pressure outlet position on the muffler body can make a difference in how well the tank is pressurized by the exhaust pulses, but I found a much greater effect on baffled mufflers when that baffle is removed.
    Have you broken in the motor? Have you then installed a new glow plug? By its very nature break in produces microscopic metal particles, (often indicated by the black exhaust residue) and that can compromise the glow element. It will heat fine when under external power, but the catalytic fuel action will not work very well, if at all. I can vouch for this by what I reported recently with my new Eagle IV.
    I still suspect a fuel starvation issue. The other engines just may not have been so sensitive, (and most new motors are this way) so the Fox simply may need more running time. As with many posts here, Fox motors usually require a MUCH longer break in procedure, but if done properly that also contributes to longevity. From my own experience my Fox cylinders outlast just about anything else I've owned.
    Club Saito Member # 787
    Club WACO Member # 243
    FA65, 82, 3 X 91, 2 X 100, 2 X 125a
  3. #2778
    Sport_Pilot's Avatar
    Join Date
    Jan 2002
    Acworth, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club FOX!
    tomorrow i try 20%castor/10%nitro fuel.
    Good Idea. Lapped iron piston engines need all castor oil for a good seal and lube. They will act like they are leaning out when they run for a while if using synthetic fuel.
    Glow Head Brotherhood #15
  4. #2779
    Cougar429's Avatar
    Join Date
    Apr 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club FOX!
    NIB Eagle IV 60 showed up today. Motor would not turn over due to storage for a LONG time. Still had the acceptance tag on the prop shaft, so assume the goop was from their test runs.
    Popped the top and cylinder off and worked in some air tool oil to loosen everything up and freed up the ring. Smooth as silk now and along with the Perry carb it has one of the new head buttons installed.
    Some other projects on the build table right now, but I will get to mounting and firing this one up as soon as possible.
    Should be looking to send the first motor back to Fox soon. Still waiting for a reply on how much they want included.
  5. #2780
    Join Date
    Feb 2002
    Hervey Bay Queensland, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club FOX!
    I have acquired a FOX .35 Stunt engine.
    It is in good shape but needs a Needle Valve Assembly. Any suggestions of a good place to pick one up?
    Are there after market assemblies that may be better?
    No idea how old it is, but it has great compression, no doubt from being fed correct fuel. I also seems the muffler is held on with an ENYA clamp brace.
    For nostalgia ... I also include some pages from a 1962 FOX product manual I was given. It is almost "as new".
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1788651   Click image for larger version.
ID:	1788652   Click image for larger version.
ID:	1788653   Click image for larger version.
ID:	1788654   Click image for larger version.
ID:	1788656   Click image for larger version.
ID:	1788657   Click image for larger version.
ID:	1788658   Click image for larger version.
ID:	1788659   Click image for larger version.
  6. #2781
    earlwb's Avatar
    Join Date
    Aug 2009
    Grapevine, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club FOX!
    You can get parts for it from Fox Manufacturing directly. Fox has made the .35's for like a jillion years now, so parts are easy to get for most of the engines, even when years old.
    They have a new needle valve assembly too.
    http://www.foxmanufacturing.com/inde...oducts_id=1508
    If all you need is a needle, they sell them too.
    But one could use most any needle valve assembly they wanted to for the most part. The Enya one would work, but you might have to enlarge the holes on the engine though.
    Club Saito #722, Sig Kadet Brotherhood #80, GlowHead Brotherhood #14,
    AMA # 928076
  7. #2782
    Cougar429's Avatar
    Join Date
    Apr 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club FOX!
    I just received a box of engines today and there were a pair of Fox stunt engines in there. I believe one may be the 35.
    I was planning to bake them in the crock pot and post pics this weekend.
  8. #2783
    Cougar429's Avatar
    Join Date
    Apr 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club FOX!
    Done cooking. Unfortunately the red paint on the 35 head started to come off and I just pulled a Homer and erased one of the pics. DOH!.
    Here are the two. One on left is the 29 and the right is a 35. The 35 has a removable sleeve with 3 of the screws long enough to reach through to the case.
    This brings up a question I do not know has been answered before; Why did Fox have such a penchant for philips screws? I would think as with all my other motors a better and more consistent tightening could be achieved with allan head cap screws. I use them for all critical fastener apps.
  9. #2784
    Join Date
    Jan 2002
    Minersville, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club FOX!
    ORIGINAL: fiery
    For nostalgia ... I also include some pages from a 1962 FOX product manual I was given. It is almost ''as new''.
    One of the problems with the Fox 35 is the NVA. It is too coarse a thread and settings are never consistant because it leaks and it breaks even if you hit it while flipping it. They have a new assembly that is expensive and with typical Fox engineering you have to remove it to get the engine bolt into or out of the mount. still a good thing is that you can replace every part of the engine as all of the new parts are interchangable.
    There is another problem in that the Fox has a very small spraybar diameter in th choke and if you use another manufacturers set up besides having to ream the holes it will be too thick and effectively choke the engine robbing it of power it cannot afford to lose. After all the 35 is not a real power house and hasn't improved since it was introduced in 1948.
    The best replacement needle valve is the Super tigre unit that is used for the 34 and the 51. It fits in and only needs a small washer to centre it. It can be turned down to the Fox spraybar diameter to keep the power level at normal. Even better is to get one From Randy Smith at Aero Products and it will be perfect for it and it also has a nylon insert in the cap to seal it and even better it holds the needle and it doesn't creep.
    I'm sure that you know that the case is fragile and using a clamp to hold the muffler on is really iffy if not done right. Too tight and you can reall have a bad running engine. There are better ways to mount a muffler on that old engine.
    did the MVVS 09'yet.
    Dennis
  10. #2785
    earlwb's Avatar
    Join Date
    Aug 2009
    Grapevine, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club FOX!
    That is odd, I do not remember ever having a problem with the needle valve or assembly before when I flew CL years ago. I do remember breaking off the needle in a crash though. But I didn't break any when I flipped the prop. My engines used the flat blade needle valve and it didn't have any false needle setting effects like one gets with a round tapered needle. But I would agree that they should have used a more fine thread or a different needle taper so it had a more fine adjustment to it. I remember as a kid using a piece of aluminum bent over to form a Vee and I used a screw and nut to make a crude remote needle for one of my engines when I had a broken needle. I left the broken needle in the engine and used the remote clamp to fine tune it. It worked pretty good and I flew it like that for quite a while too.
    AMA # 928076
  11. #2786
    kamakazi's Avatar
    Join Date
    May 2004
    Branch, AR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club FOX!
    I have asked a couple of Fox employees about the Phillips screws, they told me hex head screws were about 3 times as expensive as the Phillips head screws. When I had to disassemble a Fox engine, I always went back with hex head screws. It was hard to tighten up a Phillips screw after a couple of times loosening it. If you replace nothing else, make it the head part. Then you can be sure to get them torqued down enough to prevent the head from leaking.
  12. #2787
    Join Date
    Feb 2007
    Dearborn, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club FOX!
    I got to fly my plane with the Fox 74 Eagle IV today. But I switched the prop from 13x6 to 12x8. I still ran 0% nitro. Ran beautifully. It seems to run smoother, more power, and even more vertical with the 12x8 compared to the 13x6. It did look goofy with the smaller prop while parked, but flew better.
    Content, but not Complacent.
  13. #2788
    Join Date
    Nov 2007
    Sandy Springs, GA GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club FOX!
    I have a problem with my Fox .74 Eagle IV. First general information:
    1. The engine is mounted in a GP Escapade 61. It is mounted upright with the entire engine cylinder sticking out of the cowling. The standard Fox tilt up muffler is used. It came with the new style carb.
    2. The prop is an APC 12x7 sport prop.
    3. Omega 10% fuel is used.
    4. A 14 ounce tank is used with the spray bar about a 1/2 inch above the the center line of the tank. The tank is about 2 inches behind the engine.
    5. Two 14 ounce tanks of fuel were run through the engine on the test stand for initial break in.
    6. The plane has 20 flights on it averaging 8 minutes per flight. The first 6 were a rich two cycle just flying the pattern and figure eights. I have found that Fox engines take longer to break in.
    7. I am using a Fox long RC plug with idle bar. The original glow plug is still in use.
    8. The engine has never caused a deadstick in flight.
    Now the problem. With the engine still set fairly rich it will sag at the top of loops and during rolls but has always come back when the plane is level again. Upon landing, the engine is very hot, much hotter than I have experienced with other engines.
    I have check all of the fuel tubing, both in side and out side the tank. I even replaced it after 10 flights. The fuel pick up tube has a brass tube in the center to prevent the clunk from moving to the front of the tank.
    I talked to Fox about using 10% nitro fuel and they said it would not be a problem. In fact that it is what they use to test run each engine.
    Any thoughts on what is causing the saging and over heating? I have been using Fox engines since the mid '50s and have never run into a problem like this.
    Bruce
    Bruce L. AMA# 54227
    Ultra Sport Brotherhood #15
  14. #2789
    Join Date
    Jan 2002
    Acworth, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club FOX!
    I would start with using either lower nitro fuel or a colder plug.  Sounds like overheating from detonation to me.  Assuming that you are not running too lean.  The Fox idle bar is not the correct plug.  With 10% nitro I would use the Fox #8, with FAI fuel the Fox RC long without idle bar would be good.
    Might try raising the tank level a bit.  Maybe with the centerline 1/4" below the spray bar or even.  But I doubt it would get rid of your problem though it may help.
  15. #2790
    earlwb's Avatar
    Join Date
    Aug 2009
    Grapevine, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club FOX!
    It sounds like it is still being set a little too lean on the needle, and as the fuel tank drains it leans out a little too much and overheats.
    You can try filling the fuel tank about 1/4 to 1/3 full and adjust the needle for the engine to run good like that, then fill up the fuel tank and see how it does.
    AMA # 928076
  16. #2791
    Join Date
    Jan 2002
    Acworth, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club FOX!
    My Fox 50 runs hot on 10% fuel, even with a cold plug. This and other FAI fuel engines run fine on a test stand with 10% fuel, but need 5% or even FAI fuel in the air. The Fox person he talked to probably has never flown one, just run them on a test stand. They are more sensitive to leaning out on the top of the loop and rolls when hot from detonation. So it could be that or both.
  17. #2792
    Join Date
    Feb 2007
    Dearborn, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club FOX!
    That has been my experience with my Fox .74. It could run great with 15% nitro on the bench, but would heat up and quit in the air, even without an engine cowl installed. I switched to 0 or 5% nitro, I use Fox #8 plug (cooler), and tuned it like Earl mentioned, at 1/4 tank to make sure no leaning occurs as the tank empties. Mine is older than Landeck's, so I started out with the old head button. After switching to the new head button, it made it easier to not lean out and overheat. This engine has so much compression, you have to make sure it is set rich or else it will heat up fast.
    Some may consider this engine more work to break in, but I see it as an opportunity to run without nitro and save $$$ while still maintaining power, low idle, and good throttle response.
  18. #2793
    Join Date
    Nov 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club FOX!
    Guys, thanks for your comments. The one thing I know () is that the needle valve is not set to lean. Right now it is set 3/4 of a turn rich below peak rpm. At this setting the engine pitch is significantly lower and the volume of oil in the exhaust is much greater than when set slightly below peak. The glow plug is the original one and its element shows no distortion like you see when an engine has been run lean. Also the engine sag occures with a full tank at the beginning of the flight as well as later in the flight. Level flight is fine for the whole tank.
    My plan of attack at this point is:
    1. First, change to an OS #8 plug which is the coolest plug I have but is between mid and hot range.
    2. If that has no effect, I will get some 5% fuel and try that.
    3. If both of those have ne effect, I am going to put an OS 75 AX in the plane. If that works then I know the fuel system is not the problem.
    I will let you know how it goes. Thursday is the earliest I can get back out to the field.
    Again, thanks for the comments and suggestions.
    Bruce
    Bruce L. AMA# 54227
  19. #2794
    Join Date
    Jan 2002
    Acworth, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club FOX!
    That is a medium hot plug, what you want is a cool plug such as a Fox #8 which is cooler than a OS #8. I don't know why Fox did that their Gold plug is closer to an OS #8, just confusing.
    I would switch to the lower nitro fuel first. This engine has more power than most with higher nitro fuel. I suspect, with no nitro,it will out run an OS 75 with10% nitro. The 60 did so about a decade ago.
  20. #2795
    Cougar429's Avatar
    Join Date
    Apr 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club FOX!
    Sorry to take so long, but mill problems and dealing with rebuilding Rare Bear had this one on the back burner.
    I finally fired up the new 60 this afternoon and after tweaking have some numbers to post. To be truthful I must add the caveat that since this is the first tankful this has not even started breaking in yet.
    However, I can list some differences found with the three modified heads.
    Graupner 11 X 7 three bladed prop, 15% nitro, 18% oil
    Single dome higher compression head peaked out at 8580 RPM
    Double domed head of slightly lower compression was 8780
    Lowest compression straight dome surprised me by hitting 9240 RPM
    I went on a hunch and reinstalled head #1 and it peaked at 9200, so obviously even the short runs and cool downs were loosening it up. I did find the lowest compression head was also the least problematical, less sensitive to both LS and HS mixtures.
    I need to ask if break in at this lower RPM will be adequate or should I unload the motor with a standard 2-blade prop for now?
  21. #2796
    earlwb's Avatar
    Join Date
    Aug 2009
    Grapevine, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club FOX!
    I don't think it really matters that much, but usually I run a regular 11x7 two blade prop to keep from loading the engine down too much.
    I suspect with a higher load provided by your three blade prop, that the lower compression head would work better. The higher compression heads would make the engine prefer to run faster, as it advances the ignition timing more. Plus the higher compression heads may cause the engine to not like too much nitro (if any) in the glow fuel too.
    AMA # 928076
  22. #2797
    Cougar429's Avatar
    Join Date
    Apr 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club FOX!
    Thanks. As you can tell from my earlier posts I found out about too much nitro on the first 60. The damage to the piston makes a lot more sense when referencing your point regarding timing. I likely would still have ended with a burnt piston, but higher RPM running a 2-blade prop may have delayed the progress.
    I should have added that I wondered if the 3-blade prevented me from getting into tune with the new muffler. I also want to ask if anyone has run the older gen Fox carb supplied by a Perry VP-30 pulse pump.
  23. #2798
    earlwb's Avatar
    Join Date
    Aug 2009
    Grapevine, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club FOX!
    I had mixed results using a Perry Pump on a Fox engine. Usually everything would work OK, but the mid range would wind up too rich due to the pump providing more fuel. I ran one on a Fox .74 with a MK-X carb on it years ago. I also ran one on a Fox .45 with a MK-X carb too. I stopped using them as the engine/carbs would be too rich through the mid range like that. The special Perry pump carbs were setup with a more lean mid-range on them for that reason. I think the Perry Pumps changed over the years from what I used back then though.So maybe it is better now,I don't know.
    AMA # 928076
  24. #2799
    Cougar429's Avatar
    Join Date
    Apr 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club FOX!
    Thanks. I'll keep running fuel through it and check how it behaves. I'll retain the lowest comp head on it for now.
  25. #2800
    earlwb's Avatar
    Join Date
    Aug 2009
    Grapevine, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Club FOX!
    Here is a video I took of me flying my old Airplane Factory Combat Airmadillo .40 RC plane this last weekend. I am using a 22 year old Fox .45 engine, with a MK-X carb, that has been on several airplanes so far and a Combat Airmadillo plane too.
    So here we go.
    [youtube]http://www.youtube.com/watch?v=4Uvy0j5aKzQ[/youtube]
    AMA # 928076
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
