Club FOX!
Old 01-18-2016, 12:29 AM
  #4451
the pope
Hi there Tim , I used to be a sheetmetal worker so I have a little experience with working with metal . If it were mine and had nothing to lose I would try and make the smaller piece smaller and the larger piece larger . Try sticking a piece of waterpipe ( a make do pipe stake ) in a vice and with a small hammer try and stretch and shrink the 2 pieces over the pipe .Being gentle is the key . If need be cut a couple of slots in the tail section if it wont shrink to your satisfaction .I dont think it would take much but I havent got them in front of me either . Even taping the end in with a hammer should help unless Im missing something in the pics . U could then screw or pop rivet them together with some high temp silicon . I wouldn't try and weld them unless all else fails as it could turn into a nightmare . Good luck from the pope.
Old 01-18-2016, 05:49 AM
  #4452
1QwkSport2.5r
1QwkSport2.5r's Avatar
Originally Posted by hsukaria
My experience with the larger MVVS muffler was that the second chamber (the rear can) came loose and the rivet holes enlarged somewhat. I tried JB Weld, but that broke loose again. I finally left it off, there was not much difference except maybe a little more noise. If you want to, you can run it without the second chamber and see if you like it (it gives a unique sound). Otherwise, Earl's suggestion would be the ultimate solution. I suspect tapping the holes and screwing the can back on might cause the holes in the can to elongate like what happened on mine.
BTW, sometime after I bought my MVVS muffler from Pe Reivers (RIP), I noticed that his website was showing a newer design that might have addressed this issue with the rear chamber coming off.
The rivets never came loose. The lip on the outer shell must have been rather shallow or broke causing it to come loose and fall off. There wasn't any of the lip broken off under the collar that held it on. I have some alumaweld rods that work pretty well, but I am Leary of trying to solder such a thin piece of aluminum. I'll try the pop can trick Earl suggested and see if I can make that work. If I can, I'll try it on the muffler. I want to try to fix the muffler because it was a fair bit quieter with the back shell in place.
Old 01-18-2016, 05:53 AM
  #4453
1QwkSport2.5r
I thought about expanding the rear shell also - but being aluminum, I worry it would crack when I try to stretch it enough to fit over the collar the rivets went into. What's worse is the end of the outer shell where the stinger (exhaust outlet) is, the metal is very thin and not very strong. Tapping on it would be bad news I think. I'm going back and forth between trying to solder it together and just drilling some holes and bolting the back section on just aft of where the rivets originally went in to hold the collar in place.
Old 01-18-2016, 11:19 AM
  #4454
hsukaria
It would look ugly, but how about clamping it down? You can use a metal wire and twist it at the ends to make it tight. Hey, I've seen uglier setups with the old strap-on mufflers...
Old 01-18-2016, 01:50 PM
  #4455
spaceworm
...back section on just aft of where the rivets originally went in to hold the collar in place.
Sorry, not a solution to the problem, but a question. Was it that the rear stinger was swagged by spinning it internally to the collar, and the collar was then riveted to the front section? Just very curious as to how this was assembled. Thanks and good luck.
Old 01-18-2016, 02:15 PM
  #4456
1QwkSport2.5r
I think the rear shell was crimped where the open end met with the cast section and the collar was put over the two sections and then crimped around both pieces and riveted. It looks like the crimped lip on the rear shell just had too shallow of a lip and the bit of vibration just broke it loose. I just broke the collar off since it's useless anyway, and I may just go the easy route and bolt the rear shell on with three machine screws and locktite them and seal the seam with RTV. This can't be any more "agricultural" than the engine itself. When this Arctic front moves out, I'll run the Fox .50 on the repaired muffler and see what happens. I put a Bowman ring into that engine and fixed some blocked ports in the case among a few other things and run it up on glow to fit the new ring in and see if the muffler stays together. If everything works out, I will put the diesel head back on it and see if it runs any better. Last time I ran the .50 on diesel, it was down almost 1,000rpm compared to other Diesel Fox .50s.
Old 02-13-2016, 01:04 PM
  #4457
Glowgeek
Just wanted to say this is a great thread for Fox Engines. Too bad they're no longer made and new parts are no longer available. I'll admit, I've only read the last 50 or so pages but I've learned enough to tear apart a used .40 and try to put it back in service. It's gummed up pretty bad and needs a thorough cleaning, compression check and sealed back up. I'll post some pics to see if anyone here can date stamp it.
Old 02-15-2016, 06:42 AM
  #4458
hsukaria
So what is the reason that a glow engine has to be broken in using glow fuel before converting to diesel? Is it because the diesel fuel is so oily that the engine will take too long to break in?
Old 02-15-2016, 10:30 AM
  #4459
1QwkSport2.5r
It's mainly due to heat (or the lack of) and engine speed I believe. Most conversions don't like to run as fast as they would on glow, so they take forever to break in that way and also they don't heat up nearly as much. Purpose built diesels take a long time to break-in.
Remember though; I'm technically inept and don't know anything, so take what I say with a grain of salt and consult a higher power.
Old 02-15-2016, 10:45 AM
  #4460
hsukaria
I considered getting a model diesel engine a few years ago, but the cost of the fuel (and smell) killed it. My first ever engine as a kid was a diesel for control line flying.
Old 02-15-2016, 11:53 AM
  #4461
1QwkSport2.5r
I mix my own diesel fuel, but even doing that it's still twice as expensive as glow fuel. It has a steeper learning curve as well - the typical tuning method for glow is fairly different than diesel. I agree there is a strong smell to it, but the ability to swing a much bigger prop with less noise is enough of a bonus to make it worthwhile IMO. It's not for everyone though.
Old 02-15-2016, 12:15 PM
  #4462
hsukaria
It is also nice that you don't need a big muffler and that you can attach a hose to the muffler output and divert the exhaust away from the plane without any power loss. I think the cost and hassle of getting ether is what makes it a hassle for me. When I was a kid, I could walk into a pharmacy and buy the ether with no hassles.
Old 02-15-2016, 12:56 PM
  #4463
1QwkSport2.5r
I just use John Deere ether I get from my local JD dealer. It's about $4.50 a can. It's a bit of a pain, but it's the easiest way to do it. Davis fuel is roughly $15/qt and I can make it for about $6/qt. I have an ST .45 that will turn a 13x6 at just shy of 11k on diesel. My K&B .65 will do about the same rpm on glow fuel. I find that pretty impressive.
Old 02-15-2016, 01:00 PM
  #4464
hsukaria
Where do you get the castor oil? From the LHS? I wish I could get it cheaper. Can you also use Klotz Benol instead of the straight castor?
Old 02-15-2016, 01:10 PM
  #4465
1QwkSport2.5r
The last couple gallons of castor I bought, I ordered from S&W fuels for $25/gal. I found another source through a specialty oil company for $18/gal. People that make their own soap use castor oil. American Specialty Oil company is the name of the place. They don't list pricing on their website, I had to email them.
You can use Benol, but it's a lot more expensive and isn't virgin castor. It's been polymerized I think, so it will mix with gasoline. Virgin castor is a better bet as it is cheaper, but Benol will work. It just doesn't have all the same properties as regular castor does.
Old 02-15-2016, 02:29 PM
  #4466
hsukaria
Yep, Benol was the preferred choice for the NV engines gasser. I was looking for cheaper though. Thanks.
Old 02-15-2016, 02:40 PM
  #4467
earlwb
earlwb's Avatar
One other alternative is to use a Dubro Snuffler Muffler. You mount it onto the front half of the muffler. I flew a Fox .45 for ages with a Snuffler muffler bolted onto the front half. It does sort of reduce the noise some, but it doesn't make it worse either. Muffler pressure was about the same as well. Come to think of it, one could probably just use a lawn mower muffler instead of the Dubro one too. I have done that too. The Fox 45 with the shorty lawn mower muffler is a example in the second pic. Now then the shorty muffler worked but that is about all one can say for it.
ID:	2147464   Click image for larger version
Name:	Fox 45 on StarFire 02.jpg
Old 02-15-2016, 03:03 PM
  #4468
the pope
That cowl looks disgusting in the 2nd pic there Earl . The pope is impressed , a bit fancier than some of the pope's planes that dont even have a cowl . Cheers
Old 02-15-2016, 04:28 PM
  #4469
Glowgeek
Your .45 looks identical to my .40 Earl. Is there a manual available or tuning instructions for this series of Fox engines? I have my .40 all cleaned up after 8yrs dormancy and need some tuning tips.
Old 02-15-2016, 05:14 PM
  #4470
aspeed
aspeed's Avatar
I may have mentioned it before, but a Mousse can pipe is a great option. Just replace the back section completely with that method, and get more power too. http://www.spadtothebone.net/SPAD/Mu.../norvel_1.html
Old 02-15-2016, 06:01 PM
  #4471
hsukaria
The muffler that Tim is dealing with is the MVVS 2-chamber muffler, with the second chamber fallen off. So the ideas of snuffler or mousse can, as good as they are, don't fit what he is working with. The muffler without the second chamber is a complete muffler by itself, but just a bit louder than without the secondary chamber. I had the same thing happen with my MVVS 77 muffler. I tried JB Weld and that also broke loose. I ended up running it without the secondary chamber although it was a bit louder. However, even without the secondary chamber, it was considerably quieter than a gas engine or a Fox stock muffler.
Old 02-15-2016, 06:07 PM
  #4472
1QwkSport2.5r
I'm gonna shorten the stinger of the inner chamber and grind down the collar in the center so the outer rear shell will fit over the collar and just tap/screw it together. I'll JB Weld the screws in.
Hsukaria is correct. No bolting a back half of some other muffler on this thing.
Old 02-15-2016, 06:58 PM
  #4473
earlwb
earlwb's Avatar
The plane was a Hobbico Starfire from many years ago. I was going to fly the plane until it fell apart. I flew the engine with a tuned pipe and then with a few different mufflers over the years. The cowl was slowly disintegrating over time. The plane came with a cheap plastic cowl and cheap plastic top for the fuselage. It was slowly breaking down over time. The plane still worked fine up until a colony of Harvester Ants moved in. I couldn't get them out of the wing easily. Then after I did manage to kill them off, I was worried that they ate the glue inside. So I pulled my gear out and disposed of it. But it was still working though. Heck I even flew it for a weekend with the ants inside. I still wonder what they thought of that though. The engine is now in my Combat Airmadillo. It still runs fine. I did clean it up some to remove the old castor oil stains though. It was getting pretty grungy looking.
Old 02-15-2016, 07:02 PM
  #4474
earlwb
earlwb's Avatar
This instruction sheet attached here uses the MK-X carb on the engines.
[ATTACH]2147516[/IMG]
There is instruction sheet here is maybe for the old butterfly valve carb:
https://www.google.com/url?sa=t&rct=...14195076,d.amc
and maybe this would be of interest too:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwj29NuopfvKAhXklIMKHZO4DJoQrAIIIygAMAA&url=http%3A%2F%2Fwww.rcgroups.com%2Fforums%2Fshowa tt.php%3Fattachmentid%3D4435609&usg=AFQjCNExvUaSSLdrmYBb6YvqGXM0S6mhRA&sig2=oQiYuwxk89vTytwYgRWzFw&bvm=bv.114195076,d.amc
The engine may need a good break in. It depends on how much it was used before it got set aside. But other than needing patience for breaking them in, the carburetor adjustments are straightforward. Duke Fox mentions the carb adjustments in the manual referenced above.
File Type: pdf
Old 02-16-2016, 04:25 AM
  #4475
Glowgeek
Thanks Earl, hopefully the idle screw mods to richen/lean the midrange for the 45/50's applies to the 40/45's as well? Have you tried the idle screw mod to dial in midrange?
