Problem: Hard Start .26 - Need Some Help...
NY
I have a basically brand new .26 SportWerks on a Mayhem RTR. I must have not put the piston close enough to its BDC position during heat-cycling, because today it was unusually hard to turn over past TDC (even with the glow plug out it was tough).
That being said, I pulled off the head and removed the piston sleeve. I used a little 600 grit, and polished just a touch - the engine still has plenty of compression, but at least now it doesn't have any stuck-spot.
The engine does not want to start. Again, i KNOW it has compression, and I know its getting fuel. I just threw in a new o.s. #8 - I have to recharge my plug igniter, but can you guys recomend anything before I start screwing around again - should I remove carb and inspect???
This is really killing me- she just will NOT start... I haven't tried starting with the new plug, but I checked the old plug- it wasn't fouled and looked fine- it also lit up par-usual with the glow plug igniter, when I inspected the plug after I removed it. (I stuck the new os in anyway)....
please help.
thanks
scud
please help.
thanks
scud
RE: Problem: Hard Start .26 - Need Some Help...
Prime it carefully and not much.Put the glow driver on,take throttle to high idling position and backflip it.Be careful not to overprimed it.
