Ys 120 FZ smoke pressure
CT
Is it possible to use the fuel line tank pressure from a 3 line system to pressurize an other tank for smoke oil? With a check valve in the connecting line Good or bad? thanks
Yes. This is what was done on may Ultimates in the past. Put a tee in between the check valve and the fuel tank. Now put another check vlave in on the way to the smoke tank. Change you tubing now. Add a tee and some fuel line between the smoke tank and the check valve to vent the smoke tank while filling.
Run the smoke line to the muffler through a good shut off valve. Works great lots of pressure. I recommend a needle valve somewhere to adjust the flow.
If you run the smoke tank out, you will depressure the whole fuel system. Thats why you need a good shut off valve to keep the whole system from depressuring.
Carl Golberg used to sell a whole kit to do this when Dave Patrick worked for them. I bought one once. I will see if I can find the installation diagram.
Mark
Mark
I think that putting a muffler pressure line to your smoke tank makes more sense. Mixing the smoke oil and pressure systems of the YS is probably not too good an idea.
Good Flying,
Dave
Good Flying,
Dave
