K&B 3.5 Outboard
My Feedback: (12)
SC
RE: K&B 3.5 Outboard
ORIGINAL: Sport_Pilot
I have more experiance than you could shake a stick at. You took that out of context of this thread. I explained why I made that recommendation. That post was a near lie.
Without any experience operating these engines, you just asserted that 30% could cause detonation and that 15% was a better choice.
Meanwhile, the OP has posted the same question at another site, where those of us who DO RUN MARINE engines hang out, and none of them has an issue with running high nitro in this engine.
If they're rusted from being stored with fuel in them it's usually pretty easy to feel the roughness.
I suggest you pause and consider that perhaps not all engines are created equal and that you're not the only one with "more experience than you could shake a stick at".
My Feedback: (12)
SC
Ok, what is differant about this engine that makes it so differant from model aircraft engines?
While some of the parts on the outboard (water or air cooled), inboard, aero, and ducted fan versions of the K&B 3.5 may be interchangable, that does not mean they are the same.
Suggesting that the results of that person's very limited testing would apply to other, and significantly more expensive, engines puts peoples engines at risk. It's kind of scary that you so casually give such advice to beginners. It's way better to follow the directions of the manufacturer and people who have experience with these engines.
#31
Timing, head clearance, shaft, lots of possibilities. What matters is the engine parts are different. I can't help that you assumed otherwise and were wrong. Any further discussion does nothing to get the OP's engine running right.
#32
My Feedback: (12)
SC
Of which I have probably worked with every combination at one time. I assumed nothing. I asked the question. Could it be from detonation from overheating? I have had overheating problems runnning a K&B .40 that usually ran fine on high nitro (35%), caaused it to detonate. Ran fine after lowering the nitro. I opened up the cowling exit, ran fine on high nitro after that. Any high nitro engine can detonate when overheated. Using low nitro just eliminates that possibility and the possiblility of frying it from running lean till you are used to the engine.
#33
My Feedback: (12)
SC
Well I have seen several engines broken in that way without any problems. The only possible problem is with very tight ABC engines, if run too rich they could cool enough that they grab at the top and possibly throw a rod. Makes no dif as far as wearing in the piston to sleeve fit. In fact they best engines will have no noticible pinch left.
#34
Hi!
20-25 years ago we used the K&B 3,5cc R/C ABC engine in Quarter Midget pylonracing here Sweden. We used 80/20 castor fuel, and 7x5 wood or carbon props and got around 20000-23000rpm with magic mufflers silencers.
I raced several different models then, one being the Little Toni Formula 1 racer and also my own construction of the famous "Tsunami" racer build by Sandberg which he sadly crashed in -1991(?).
If I remember correctly the K&B 3,5cc engine was very tight and squealed when turned over cold.
It ran good though on just 80/20 fuel and the throttle response was very good even when using small 7x5 props. Carb used in those days was the black alumium K&B, airbleed carb which I think is mounted on your boat version too.
I think I used the K&B 1 plug then or the Rossi 2-4 plug.
I seldom used anything but the original shim and thus seem to indicate that the engine was set up to run on non or low percentages of nitro.
It is always good to try 0-5% nitro when an engine behaves funny on larger percentages of nitro and everything else is according to plans. Too much nitro in an engine set up for non or low nitro could play havoc to an engine and make it very sensitive on needle settings.
As for changing ballbearings...I would say this is a must according to my personal racing background. Especially so if the engine in question has been run on Castor oil fuel and sitting for as long two years.
But bad ballberaings is not the reson for the engine running bad.
Regards!
Jan K
Sweden
Regards!
Jan K
Sweden
#35
My Feedback: (12)
SC
ORIGINAL: jaka
Hi!
Hi!
