Magnum 90 4-stroke won't shut off
PA
Both myself and a fellow club member are experiencing the same problem with our Magnum 90 4-strokes. They both have full RPM range, but will only idle down to a certain point then actually increase in RPM. Neither will actually shut off with the kill switch. High end is set properly (just a tad rich). We do not think it is a mechanical issues as adjusting it seems to make situation worse. We were thinking that the low end is too lean thus increasing RPMs. After adjusting the low end to make it more rich, the problem still exists.
Any thoughts??
Any thoughts??
PA
RE: Magnum 90 4-stroke won't shut off
It does idle although it is a little fast (not too bad though). When the kill switch is pressed, the RPM drops and then quickly raises to faster than the original idle.
My Feedback: (27)
NV
Or, possibly and intake manifold leaking..like he says ge it on the bench and check for the carb operation, when the carb is pulled on to close the barrel...........cheers........John
My Feedback: (27)
NV
Last thing and I will get out of your hair, beings I am old and can`t think of all these things at once======possibility of air leaks around the seals on the 2 needle valves........I`m out of here........good luck again.........
PA
Okay, is there any trick to finding the leak. Can it be heard or seen? Is this something that the manufacture should fix?
Thanks for the help.
Hope all get to enjoy a Newyear's Freeze Fly.
ON, CANADA
Take the carb off. Put a piece of fuel line on the fuel inlet. Put the carb under water. Blow on the fuel line. Bubbles will show where the air leak is.
My Feedback: (23)
GA
Before you go through all that, take the cowl off and look down the barrel of the carb to see what's happening when you hit your kill switch. You may be surprised to find that the barrel of the carb is rotating the wrong direction (opening rather than closing). Do what you want but I'd verify that before disassembling the engine and putting my carb under water. I have many Magnum engines and have seen this before and every time it happened to me it was something in my radio setup/mechanical linkage. Just my $0.02 worth. Good luck and let us know what you find.
