T-80 Webra
RE: T-80 Webra
Hi Jugmaker, i has same engine as you, but are your engine charged with crankcase as compressor and carburator mounted to crankcase or carburator mounted direct to cylinderhead?
My engine has carburator mounted to crankcase and run best with 14x6 and, i am using 10 % nitro + pure 18-20% castoroil then the engine will last long life. The engine like best to be started in same way as clockwise (bounched starting) and fire easy after priming. Use OS F glowplug.
Jens Eirik
Jens Eirik
GA
RE: T-80 Webra
Hi Motorboy, Sorry it has taken me this long to reply( I am just lazy sometimes). My Webra is a T4-80 and has the carb mounted on the head. I put my GK .65 on a 180 Cessna so the T-80 is going on my 1/5 Cub. It may be more motor than the Cub needs but going to try it anyway.
Thanks for the reply
jugmaker
jugmaker
