OS engines users Club
Reply
Old 03-08-2018, 09:02 AM
  #776
lleach1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jim, Thanks for the reply. It did help. LEL
lleach1 is offline
Old 03-08-2018, 09:24 AM
  #777
the Wasp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cool !!!
Jim
the Wasp is offline
Old 03-12-2018, 11:09 AM
  #778
RichardGee
My Feedback: (156)
RichardGee's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default O.S. H80 engine
Sorry if this has been discussed, but I Searched all of RCU and this thread and nothing comes up for "H80" in any form.
I just acquired an O.S. H80 engine (rear carb) and it has a broken throttle stop/barrel retention screw. I would like to obtain the replacement screw and need a parts break down or simply the part number?
Anyone?
THANKS.
RichardGee is offline
Old 03-12-2018, 02:47 PM
  #779
N1EDM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can you get a reading/label off of the carb? That is, is it a separate carb, such as an A3, etc. (I used that model just for the sake of argument)?? Then you might be able to look up the Carb instead of the engine to get the parts. I realize that this is a rear carb that might have its body built into the engine crankcase but it's worth a shot.
Just my $.02
Bob
N1EDM is offline
Old 03-12-2018, 03:09 PM
  #780
Hobbsy
My Feedback: (101)
Hobbsy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anyone?
THANKS.
OS Max-H 80
http://www.rcuniverse.com/forum/golden-age-vintage-antique-rc-196/6868002-os-max-h80-r-c-1970-stuff-i-need-manual.html
Hobbsy is online now
Old 04-05-2018, 02:56 PM
  #781
r ward
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default .61SF muffler
OS club,.....great!,..... this might be the right place to ask. does anyone have a stock muffler for a .61 SF engine they would part with? it's got a number 744 (model number) on it, at the mounting flange, where the exhaust runner meets the engine's exhaust port. the two mounting holes in the muffler flange, are threaded and spaced 42mm. on center. mine is suffering from a cracked, (and now broken off) flange and there is no shop around me, willing to TIG it up claiming the broken off "ear" part, is too small and will turn into a molten blob when welded.
it's a bit harder to find a muffler for this engine on line than I thought it would be.
thanks for looking.
r ward.
r ward is offline
Old 04-07-2018, 05:10 AM
  #782
aspeed
aspeed's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Untitled Document You could try an aftermarket pipe and header, or some other brand like the Magnum, Webra, or whatever may fit. Some are bolt on, some bolt through.which could be a problem. Nuts on the back may work. An adaptor may be made up for some other setups.
aspeed is offline
Old 04-07-2018, 05:24 AM
  #783
N1EDM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
When I saw those headers from aspeed, it made me think of those old mousse-can mufflers. Remember them??
Bob
N1EDM is offline
Old 04-07-2018, 08:13 AM
  #784
aspeed
aspeed's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sure, pay less than a muffler, and get more power than an open exhaust, and way more power than a muffler. Not quite the overall power of a real pipe, but a broader range. Gives some metalworking part of the hobby a bit of exercise too. The RTV silicone is kind of crude though.
aspeed is offline
Old 04-07-2018, 02:55 PM
  #785
blw
blw's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Designing mufflers can be very interesting with good payoffs in extra power. I would say go for it.
blw is offline
Old 04-09-2018, 03:32 AM
  #786
N1EDM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I never heard about how quiet a Mousse Can Muffler was compared to standard mufflers??? Does anyone have any experience with them?
N1EDM is offline
Old 04-09-2018, 06:25 PM
  #787
the Wasp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mousses,
I found these on Google Images, I didn't read them so some of them may over lap on each other
Making A Mousse Can Muffler With Alumiweld
Mousse Can Muffler
Mousse can logic?
Mousse can logic?
My Mousse Can Pipe..Please add yours - Page 2 - RCCanada - Canada Radio Controlled Hobby Forum
DLE 20 & Mousse Can Muffler - Need Some Help Here.
Jim
the Wasp is offline
Old 04-10-2018, 04:05 PM
  #788
prewarvtwin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default OS FS 91s Valve spring
Anyone help with any leads to find a OS FS 91s Valve spring. Seems they are discontinued and nobody has any. Can you use a substitute ? from other engine or buy spring lengths and make your own? Cheers
prewarvtwin is offline
Old 04-11-2018, 01:47 AM
  #789
Hobbsy
My Feedback: (101)
Hobbsy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
https://www.towerhobbies.com/cgi-bin/wti0001p?&I=LXWY25&P=ML
O.S. Valve Spring FS-70 91SII
Tower Stock# LXWY25 • Manufacturer Stock# 45960210
A possibility, the OS FS 70 through 91 S II all take the same springs.
Old 04-14-2018, 03:32 PM
  #790
smkrcflyer
smkrcflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I recently got two OS FT-160s, one is on a Great Planes PT17 and the other one is on a Sig Rascal 110. I haven't started either one yet. So far I checked the valves to make sure there working properly and the carb.
I read that the piston rods are pron to braking. Anything I can check on them or do to reduce the chance of this?
What fuel works good? The manual says 18% oil and nito of 5-20%.
What about prop size? Manual says 16x8, 18x6 or 20x6.
Do I need to use On-board glow driver?
smkrcflyer is online now
Old 04-14-2018, 08:49 PM
  #791
the Wasp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
here, if you are sure that your engines are the FT, then this first link should help with picking a Prop,,
as you will see in these links many people that have been flying a long time have come to know that a Loaded engine is a happy engine, the guys I am talking about use larger props, this is because your engine's Peak Torque Point is where your engine is Most Efficient, and an engine's Peak Torque Point is much lower than it's Peak HP Point, remember>, Torque is Twisting Power, and HP is RPM per Time (more on this below),
OS Gemini FT-160
this link is for the older engine,
OS Gemini 160
now note> that most wood props load an engine more than an equal sized APC prop would,,,, EXAMPLE> on my (Long Gone) Magnum 180 4St>, APC 17x8W 8,800) Xoar Sport 17x8 8,200) Zoar Sport 17x6 8,600) (note that the Zoar 17x6 peaked out 200 RPM below the Plastic APC 17x8),, all numbers were Peaked RPM numbers,
so, if you want to use a wood prop you would have to go down in pitch by 2 or 4, or down in diameter by 1 inch when comparing Wood Props to an APC,
Rod Braking,
I haven't read about these engines braking Rods, but you want your engine to run smooth, and this brings us to Glow Plugs, most off-the-shelf Glow Engines run smother when using a Hot Plug, but you most likely will loose some RPM with a Hotter Plug (maybe 300 to 600 RPM), but, a Hotter Plug will help with a larger diameter Prop because the Hotter Plug advances the Timing giving more Torque, so will burn more fuel under load at lower RPM,, remember a larger diameter Prop give more of a "Flywheel Effect", it accelerates slower so the fuel has a better chance to burn all out,
note that a smaller Prop with a lot of Pitch will also load an engine more, but not as well at lower RPM's than the larger diameter Prop will, and your Planes are not Racing Planes,
never-never-never buy cheap Plugs, most cheap plugs use a Coated Coil, they just don't work as well,
I have heard that K&B makes the hottest 4St plug but that is just hearsay for me, yet K&B does make 2 different 4St Plugs (Hot and Hotter),
well they are adjustable to turn on/off at different RPM's, and that can really help at lower RPM when coming off the throttle, and that will also help when using larger Props because they will help by starting the Flame Front sooner and burn more fuel under loads, it will also help when using a lower Nitro percentage like 0% or 5%,,
Note that tuning your engine with the On-Board Glow Driver turned-off (off) is a Must Do thing,
The manual says 18% oil and nitro of 5-20%
myself, with those percentages/and in your Big planes with Big Props I would burn 15%, yet many-many-many others would be just as happy running 10%
good luck ! hope I have helped !
Jim
the Wasp is offline
Old 04-17-2018, 02:27 AM
  #792
smkrcflyer
smkrcflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you, Jim
Old 05-03-2018, 03:55 AM
  #793
controlliner
controlliner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
1 OS Max 15
1 OS Max 20 (exhaust baffle)
1 OS max 30 (exhaust baffle)
1 OS 40 FP (ABN version) looking for iron piston liner set
1 OS 40 LA
1 OS 20 Four Stroke
5 OS .40 Four Stroke (first version)
1 56 FS A (wicked power in a small package)
1 OS 61 Four Stroke
controlliner is offline
Old 05-04-2018, 08:05 PM
  #794
BullardRM
My Feedback: (39)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default OS Max 40 carb needed
I am looking for a carb that fits a OS 40. Please help. Even the rotary valve would work.
BullardRM is offline
Old 05-05-2018, 03:33 PM
  #795
N1EDM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Which one??? OS 40SF, 40FX?? I'm not sure if there was ever an AX
N1EDM is offline
Old 05-19-2018, 07:05 PM
  #796
123Cat
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ive got a crossflow 15 that needs a P/L what is the best bet , will anything else fit , Enya maybe ? Thanks
123Cat is offline
Old 06-12-2018, 02:59 PM
  #797
andernamen
andernamen's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Does anyone know what goes between the piston and the wrist pin? Is it simply an O ring? I have a 61 FX that was cleaned in anti freeze and these swelled up and had to be burned out.
andernamen is offline
Old 06-12-2018, 05:05 PM
  #798
the Wasp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
click on my link, see #4 (Wrist Pin Retainers), they are a simple spring that hold the Wrist Pin in, I don't know what you mean that they swelled up and that you had to burn them out, some engines use a small Teflon Pad that fit's inside the hole, but I don't remember my 61FX having them
https://www.manualslib.com/manual/64...page=31#manual
BTW, want to buy another 61FX
Jim
the Wasp is offline
Old 06-12-2018, 05:48 PM
  #799
the Wasp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
here you go
https://www.towerhobbies.com/cgi-bin...?&I=LXCS91&P=7
Jim
the Wasp is offline
Old 06-13-2018, 11:55 AM
  #800
andernamen
andernamen's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No, I'm sorry, I meant on the inside between the con rod and piston with the wrist pin running through. I think they are O rings?
