OS engines users Club
Old 07-29-2018, 12:51 PM
  #826
Fast Pilot
Originally Posted by Fast Pilot
I'm running the OS 200 with pump engine. This engine vibrates a lot. Is it only because it is new or it will always behave like this?
Please answer with honesty, not to console me. Is it a very bad engine?
Thanks so much
Replay please
Thank you
Old 07-29-2018, 05:14 PM
  #827
the Wasp
to answer this question, yes, but too add to it, using a low Nitro percentage such as 5% can induce vibrations while braking in an engine
Jim
Old 07-30-2018, 01:56 AM
  #828
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
According to the reviews I could find the OS 200-P is a very smooth engine, I also asked an intelligent question that relates directly to big engine shakes. Keeping them below 8,000 rpm is important. Also you need to get the low speed needle set correctly both for a smooth midrange and for economy.
One more thing, how solid is your test stand, if not very solid you are seeing tortional impulses and not vibration. They are the result of a light weight engine coupled with strong power pulses. A heavier prop will help with this.
Old 07-30-2018, 06:08 AM
  #829
Fast Pilot
Thank you, Hobbsy.
What prop should I use? I'm using a 18x6W APC.
My fuel is: 10% nitro, 18% synthetic oil Klotz 200.
I'm waiting for your answer
Thanks again
Old 07-31-2018, 03:48 PM
  #830
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
I keep thinking 18 x 8, that's what I ran on a Saito 2.20.
Old 09-30-2018, 03:47 AM
  #831
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
At 6,000 rpm
OS 56 Alpha modified with rear vent as the OS factory has done to the OS 56 Alpha II, this engine when side mounted surged big time nearly quitting, then blowing a cloud of white smoke revving back up and then repeat.
This is the O.S. Engines FSA-56II Four Stroke Engine with the F-4040 Silencer.
FEATURESBlow-by oil exits through the breather nipple on back plate for more
stable operation
Black rocker cover
40NA carburetor
OS Alpha 56 2.5 hours total run time
Fuel====Wildcat 10% with 18% full synthetic
Prop====Graupner 13 x 6 G-Sonic
Plug====OS-f
Exhaust==Stock
Max rpm peaked==10,230, one click leaner and it slowed about 50 rpm.
Idle 2,070, very smooth
Transition=clean and quick.
Old 09-30-2018, 05:41 AM
  #832
1QwkSport2.5r
1QwkSport2.5r's Avatar
Nice numbers Dave.
If anyone is interested, I’m selling some of my OS engines. I have a well used 15III steel fin, low time 25LA, 25FSR with nearly new piston and liner (with good spare old p/l) - about 1 hr runtime on new P/L, plus a new Davis Diesel head as well. 60FSR ringed with new Boca bearings and Bowman ring - no runtime since rebuild. Formerly a Perry lumped and Perry carb engine. Perry carb was damaged, so I found a 7B carb for it instead. If anyone is interested, send a PM. Need to finance a new r/c project.
Old 09-30-2018, 06:09 AM
  #833
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Thanks Tim, David McIntire and I are comparing notes on the OS 56 Alpha and now on the OS 62-v and 95-v. More later.
Old 09-30-2018, 06:14 AM
  #834
1QwkSport2.5r
FWIW - your numbers are spot on to Enya’s 60-4C.
Seems these engines are all real similar to each other in terms of power despite some 20+ years difference in design and release.
Old 09-30-2018, 08:08 AM
  #835
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
I probably mentioned this before, doing a comparo I did running a Saito 56, an Enya 53 TN and an OS 52 turning a Graupner 12 x 6, 300 rpm separated them in the exact order of their displacement.
Old 10-01-2018, 07:52 AM
  #836
dmrcflyr2
My Feedback: (43)
I pulled the 62V out of the box today during lunch and I have a 13x6 APC strapped to it. I HOPE to get runs of the a56 and 62V done tonight with both FAI and 15% and a 13x6. At minimum I will get an FAI run done on the a56 and 62V both with a 13x6.
Old 10-01-2018, 08:08 AM
  #837
dmrcflyr2
My Feedback: (43)
Latest run of the FS-a56
Old 10-01-2018, 08:29 AM
  #838
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Nice run, and a way good idle. I just ran mine for 30 minutes using a Xoar 12 x 6 and as expected the max rpm was lower than the Graupner 13 x 6. The Graupner G-Sonics are revers, I don't know if that's good or bad.
Lowest idle 2,400, I blame the Xoar, too light.
Old 10-04-2018, 03:08 AM
  #839
AIRHAMMOND
I just put os 40 la on 4lb stick,1st try is that enough power,thank you leh
Old 10-07-2018, 12:57 AM
  #840
dmrcflyr2
My Feedback: (43)
Dave, here is the requested runs for the OS a56, OS 62V and a Saito 56. All ran an APC 13x6 prop, and Omega 10% fuel.
Old 10-07-2018, 01:24 AM
  #841
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Thanks David, I watched those yesterday with great interest. I have my older Saito 56 in the PSP as we speak with a Grauoner G-Sonic 12 x 6. It will probably over rev, but we'll see. I'l do the same with mu OS 56 A
Old 10-08-2018, 04:06 AM
  #842
dmrcflyr2
My Feedback: (43)
Here is my run of the OS FS-95V
Old 10-17-2018, 05:39 AM
  #843
GallopingGhostler
GallopingGhostler's Avatar
Default OS Pet .099
Last iteration of the OS Pet .099, cleaned and restored.
Old 12-16-2018, 05:09 PM
  #844
Jasonwomack
Default .91 df engine
Since I found this o.s engine club I just wanna post that it pisses me off I got two engines and can’t find rebuild parts because o.s decided to stop making them suckssss
Old 12-16-2018, 08:03 PM
  #845
aspeed
aspeed's Avatar
You would need a second mortgage anyway. Our popular hobby retailer wants $210 for an AX .46 and $110 CDN for a piston liner. An LA .15 is $150 now. Both are fine motors, but...
Old 02-17-2019, 07:02 AM
  #846
RC Specialties
Check out this great GF-40 install.
Old 02-17-2019, 07:03 AM
  #847
RC Specialties
Pic didn't upload, sorry
Old 02-19-2019, 04:13 AM
  #848
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
https://www.towerhobbies.com/cgi-bin...&I=LXPUD9&P=ML
Old 02-19-2019, 07:32 AM
  #849
aspeed
aspeed's Avatar
$100 + 35% for our Canadian$ + 3% for the bank fee to convert (+ shipping and border fees) + mark up. Yes welcome to Canada. American prices without even passing through the US.
Old 02-19-2019, 10:10 AM
  #850
the Wasp
aspeed, isn't that OS made in China ??
check these,, most likely better engines in the long run for less money>>
https://www.mecoa.biz/shopdisplayproducts.asp?catalogid=1629
http://www.mecoa.com/kb/88/8801.htm?id=1629
https://www.mecoa.biz/shopdisplaypro...asp?search=yes
Jim
