Piston/liner fit help please!!!
Hello,
I am in the process of putting new hard chrome on the liner of one of my ABC engines for which parts are not available.
I know that the top of the liner should be slightly smaller than the piston, but how much? Does anyone knows what the tolerances should be?
FL
RE: Piston/liner fit help please!!!
i don't know the tolerances, but in car engines, i usually notice that the top of the sleeve is about 4mm smaller than the bottom of the sleeve in inner diameter. hope this helps
Speed:
You have your decimal point wrong. 4 mm is more than 1/8" - you might mean 0.04 mm, that's a little more than 0.0015"
Bill.
Bill.
It is not a good answer but most of the engine tuners I know would prefer the chrome to be piston size and then hand lap to fit.
You might want carry your micrometers to the LHS and measure a new piston sleeve set. You could also check the taper.
Bill
Bill
I would like to have a good pinch at TDC like a new ABC engine. Any ideas?
If the liner is 0,01mm smaller than the piston would it be too much?
Flyer95:
The fit at the top of the bore should be zero clearance. Any interference fit would force you to heat the cylinder just to get the engine to turn through.
Also, if you have gauges of sufficient accuracy you will find the piston is not a true cylinder - it's more a barrel shape. very slightly larger diameter at the center than the top and bottom while the cylinder sleeve bore is a straight taper.
Hope this is some help.
Bill.
Bill.
Hi Guys,
A few more questions
Is the brass in the liner for ABC engines just brass? or a "special" brass alloy?
How thick do you think the hard chrome plating should be? for long life and good expanding capabilities. Any suggestions? Thanks
ORIGINAL: Flyer95
Hi Guys,
Hi Guys,
Thickness in chrome shall be 0.05-0.08 mm and lap to mirrorlike surface then thickness will be 0.02-0.03 mm after the sleeve are lapped.
When you are lapping the sleeve, you need a ready made piston to test taper in sleeve between lapping. In bottom are piston loose and before 1-1.5 mm to top the piston will be tight. It must be tapered to keep compression when the engine are cold.
Very important! Wash parts in petrol or kerosene before piston are entered to sleeve.
Jens Eirik
