Webra 61 (10ccm)
CO
RE: Webra 61 (10ccm)
Well, flyboy, I guess I'll get this post deleted as well.
My comments weren't meant to belittle you or anyone else. They were originally meant to be informative. You don't know what bearings are made of but you misquote a distributor. You don't know that there are two size versions of R6 bearings yet you pronounce that all of them are the same size. ONE bearing supplier uses a non-standard designator for their bearings (against industry standards). You call Stellite a "flashed chrome" surface finish on Japanese motorcycles when it is not used commonly on cams or followers. Industrial hard chrome plating us used there and valve faces are normally welded and machined.
My Feedback: (21)
I personally removed all the flaming out of your post. That was uncalled for.
You are right, I didn't kmow that a plain R6 bearing was smaller in width than
all the other R6 bearings, and there are many. However, instead of jumping
up and down, why don't you study-up on that bearing book a bit more. It
appears you are no expert at bearings either, although bearings are your
business:
If you were to look in the bearing book instead of trying to find fault with
others, you will find plenty of bearings that have the .218 width, and are
sealed.
Oh, look....here's five from Boca Bearing. They must have a better selection
than you do.
P.N. ENK-037HP
Bearing R6N-2RU TH9/C3
Width .2187
Seals (2) Double rubber.
http://www.bocabearings.com/main1.as...N-2RU%20TH9/C3
__________________________________________________ ________
P.N. ENK-037
Bearing R6N-ZZ
Width .2187
Shield Double/steel
http://www.bocabearings.com/main1.as...=1901&n=R6N-ZZ
P.N. ENK-037C-LP
Bearing SR6CN-2YS/C3
Width .2187
Two seals, material YS rubber, contact seals.
http://www.bocabearings.com/main1.as...n=SR6CN-2YS/C3
P.N. ENK-037C-HP
Bearing R6NC-2RU-TH9/C3
Width .2187
Ceramic Hybrid
Rubber seals
http://www.bocabearings.com/main1.as...C-2RU%20TH9/C3
P.N. ENK-037HS
Bearing RN6-Z TH9/C3
Width .2187
Shield single/metal
http://www.bocabearings.com/main1.as...R6N-Z%20TH9/C3
More bad news....Stellite surfacing is used on every camshaft and follower the
Yamaha ever produced, going back to 1970, with their first four stroke offering
the 650 XS1. I was working for Yamaha full time, at the time....I know.
BTW, I offered the same advice you did about the front bearing. I asked the Member
to measure for the front bearing, and added a picture to show him how.
I hope you will continue to enjoy R/C Universe, I see you are new. [sm=thumbup.gif]
FBD.
business:
That engine takes an R6 front bearing and, unfortunately, standard
sealed bearings are not available in that size. I am not familiar with that engine
in particular but if it has a tapered collar prop drive, you MAY be able to use an
R6-2RS bearing in its place.
sealed.
than you do.
P.N. ENK-037HP
Width .2187
P.N. ENK-037
Bearing R6N-ZZ
Width .2187
Shield Double/steel
P.N. ENK-037C-LP
Width .2187
P.N. ENK-037C-HP
Width .2187
Ceramic Hybrid
Rubber seals
P.N. ENK-037HS
Width .2187
Shield single/metal
us used
us used
FBD.
CO
Dave,
IF you would bother to read my posts, you would have seen this:
. I DO know a little about what I speak.
Again, stick to what you know about because bearings isn't one of them.
Oh, and Yamaha is just a bit player. Honda and Suzuki use proprietary hard facing on their bikes and Kawasaki uses plain old ordinary hard chrome. We are having this discussion right now on another site I frequent where industry insiders answer.
You can get the R6 configuration with seals and shields but the designation is R6N-ZZ and is not commonly used because (my supplier tells me) the balls are smaller so they have a lower load limit.
My Feedback: (102)
OK Guys, you two *****ing each other out over totally unrelated motorcycle issues is not helping Jerrbl at all. Just tell him which bearing will solve his problem, that's all he wants to know.
CO
ORIGINAL: torque wrench
#32
My Feedback: (21)
More often than not, the cost of replacing the crankcase and the crankshaft
would be probibitive. Unless the crancase is broken from a crash and not
serviceable the answer to the leaking problem is to use a sealed bearing.
Sometimes even a single sided metal shield bearing will suffice. After all, the
object is to restore proper operation of the engine, not spend a hundred
dollars on it, when it doesn't need anything but a new improved bearing
that effectively cures the leak and fixes the problem.
The problem with open ball bearings is they, for he most part, work OK when
the engine is new. They leak air and fuel like mad, but the engine can be
richened up enough to compensate.
However, when a manufacturer uses the cheap bearings, and you get a little
wear....the engine starts running like poop, or will not run at all, will not idle, or
will not shut off.
In any case, a new rubber sealed bearing will indeed fix the problem, and last
for many, many years. Use a sealed .218 bearing, or if the .280 sealed bearing
will fit....use that. The crank and case do not have to be replaced.
Super Tiger engines come with rubber seals.
ASP engines come with rubber seals.
Flyboy Dave's rebuilds have rubber seals.
Is this a great hobby, or what ?
will not shut off.
#33
My Feedback: (21)
Jerrybl....I forgot to mention, if you were to replace the crankshaft, the crankcase
and use a new cheap bearing like the engine came with....guess what ?
In a short period of time you will have an engine that does the same thing yours
is doing now.
Put a nice rubber sealed bearing in the front and enjoy.
FBD.
is doing now.
FBD.
#34
Also keep in mind that black head engine is over 30 years old. I know Webra engines last almost forever, but is it even worth the price of a rebuild. My guess is it's probably on it's 3rd or 4th set of bearings and was run too long on one of the worn out sets destroying the seal. Normally the steel shaft does not wear and it is only the front case part that wears out.
#35
My Feedback: (21)
Yes, Paul....the engine could be old, or it could have been sitting around for
decades. If the front of the case is worn, you can install a new bearing with
thick CA. It will hold and seal the outer race forever.
Ten years from now, when the bearing might need replacement....heat the case
front with a propane torch for a few seconds, the CA will soften....and the bearing
can be bumped right out.
Real simple. [sm=thumbup.gif]
FBD.
FBD.
#36
My Feedback: (102)
Paul since we're kinda talking about your bearings, I ran my Fox .50 today that I rebuilt about a year ago using your ceramic bearings and a new sleeve, piston and ring. I removed the front seal as Fox doesn't use front seals. Sorry Dave, I was impressed. It turned a 12x5 Graupner at 11,820 peaked but only for about 10 seconds, needs some more time on it. Even with a smallish .247 Perry carb it did good, I think. I need to figure out how to get my camera to take good Tachometer pics.
I may be able to scrounge a crankcase for Jerry, it may take a day or two if I can find it at all..
#37
Dave,
This may be off-subject, but that Perry carburettor is on the Fox with an adapter.
I heard Fox has a carburettor they call the 2600, which is the best thing for this engine since the venturi was invented...
...And it bolts right onto the crankcase.
BTW, is that an MVVS, or a Webra 390 in that Galaxy?
#38
CO
Torque,
That is pretty impressive for an engine design that is at least 20 years old! I don't think you will get much more out of it with a larger carb as the 50 never really did turn a lot of revs compared to the 40s and 45s.
#39
ORIGINAL: DarZeelon
Dave,
Dave,
#40
#41
CO
ORIGINAL: Sport_Pilot
Does 12,800 on a MA 11-6 with 15% nitro qualify as a lot of revs? Don't know where you got that info. I think Fox advertised something in the upper 14's with 5% nitro and a 10-6 prop at one time, which is about the same as the present .46 ABC. Flew my Big Stick .40 fast enough to rip a corner of the covering off, the adhesive was still stuck to the balsa. Climbs straight up with an APC 11-5. Forgot to tach it though.
Also, I don't consider MA props for comparisons. They always showed higher static RPMs than APC. Any time I wanted to impress someone, I would put an MA 10X6 on the 47 and spin it up to 16k!
Just for comparison, the current GMS .47 turns an APC 11X6 over 13K on 5% nitro.
#42
Dar..
The Fox 2600 carb fits only the .40 Std or BB engines...there is no "2600" for the other models.
Sport..
You obviously never used a 2600 carb? It is definitely one of the finest (albeit Fox ugly) carbs ever made.
Sport..
#43
ORIGINAL: RaceCity
Dar..
Sport..
Dar..
Sport..
No I did not.
Nor did I ever actually own a Fox engine.
But I did get a chance to play with a couple of them that showed up here.
Your opinion of this carburettor is why I entered my previous post.
#44
IN
Hey Torque That FOX 50 must be sentimental. New sleave,piston,ring,and ceramic bearings no less. More than engine is worth !!!! Lots of OEM engine bearings are open (no seal) from factory. I'm with Dave , Put in the rubber seal (not metalseal) and go fly. The seal will help air leak and dust protection. I'm surprised the slide rule boys didn't attack on the .218 reference bearing you stated at .2187. That .0007 could get you in trouble...........
#45
My Feedback: (102)
Hey Speeds, I have 3 of the .50s, 2 factory made ones and one I made by putting a .50 sleeve and piston in a .46, this lightens the .46 by about an ounce, the power between the .46 and the .50 is identical though. Bob Davis has been trying to get Charles Thacker at Fox make another run of .50s but so far that hasen't happened. The Fox .50 is one of the best kept secrets in this hobby.
#48
#49
My Feedback: (102)
Jerry, I found this guy in my "stuff", I paid two bucks for this engine and used the needle bearing rod that was in it. Shoot me an address by PM if interested, it's on the house if it will help. It has been victimized by "pliarboy mechanic" but is usable.
