How critical is front bearing seat on OS120AX?
NJ
I think I shifted the front bearing on my brand new OS120AX ; I started to tighten the prop nut without the spacer installed between the front bearing and the keyed drive hub. I felt a slight loosening of the nut before I realized the mistake. The bearing now looks about .010-.020" proud of the housing (can anyone tell me if it's normally flush?), although the hub fully covers the bearing when installed. The engine turns freely. I haven't started it yet. Should I reseat the bearing? Is this as simple as rapping the outerrace at opposing points? Anyone think anything worse happened?
Thanks!
Thanks!
SC
RE: How critical is front bearing seat on OS120AX?
"Should I reseat the bearing? Is this as simple as rapping the outerrace at opposing points? Anyone think anything worse happened?"
It won't hurt to give it a couple of light raps. Remove the crankshaft. Place the rear of the crankcase on a piece of wood. Use another piece of wood between the hammer and bearing face. Align it level and strike the wood in the center with a couple of firm (not hard) raps with the hammer. Do not hit it side-to-side, that may skew the bearing. The hammer doesn't need to be a 20 oz. framer. A small ball peen or claw hammer will work well. The fit of the bearing in the case is a tight push fit.
Dr.1
Dr.1
