whats this crap
FL
RE: whats this crap
compression is good its brand new it ran fine last weekend. i changed all the lines from the tank after noticing a pin hole in the muffler line. maybe thats what did it but i doubt it.
RE: whats this crap
ORIGINAL: LANNYBOB
my new o.s. 91 fx 2 stroke has been running good but lately the son of a beach dies when throttling back to idle. any ideas why
You might try a different jug of fuel. Good luck,
Dave Olson
RE: whats this crap
G'day Mate, If it's new have you checked the idle mixture with a pinch test, as the motor runs in the fuel suction to the carby increases & you may find you can lean your idle mixture out slightly. Also the plug won't last forever, if the motor slows down a fair bit when you remove the glow driver, suspect your plug especially if it was running fine before.
Good Flyin Mate.
Allan.
Good Flyin Mate.
Allan.
RE: whats this crap
ORIGINAL: LANNYBOB
Problem solved? No?
Changed fuel brand/ mix? -> Adjust the idle mixture.
No, or it makes no difference? -> Replace the plug (with a new one). Deteriorated (worn or damaged) plug is a common cause.
It makes no difference? -> Adjust the idle mixture. When the seasons change, so does the mixture.
No joy, report back.
RE: whats this crap
Brand new engines have a habit of requireing additional tuning as the rings break in. As it breaks in suction improves, especially at idle and thus your idle setting becomes too rich and requires leaning out.
IN
RE: whats this crap
Your engine was probably tuned with pinhole fuel line and now that you replaced it you have to retune low and high speed needle. Your now getting more fuel pressure.
