Cleaning Engines in a crockpot w/antifreeze...
Wow...some of the local guys turned my on to this technique, and it works great. Take an old (or new) dedicated crockpot, about 2/3 full of cheap antifreeze, remove the rubber parts (I disassembled my engine), cook for about 12 hours, clean lightly with a wire brush, wash clean with water, lightly oil, and look like new!
Keep this stuff from any children or critters, don't breathe the fumes. Works like a charm. Might not be a "green earth" kinda process, but the result is fabulous.
You can see one of my 20 year old SuperTigre engines in the slideshow at:
http://www.scootworks.net/dave/upsid...pslideshow.php
Dave
AMA 119484
Dave
AMA 119484
RE: Cleaning Engines in a crockpot w/antifreeze...
Dave, I knew I liked the looks of that airplane.
It looks a lot (finished) like one I just built, a modification of a Ruperst Dad from an English Magazine. RC world I think. I didn't like the looks of the open cockpit so I did a slight mod there. Power is a Magnum 52 four stroke. It flew Saturday for the first time. I got to watch as I have yet to pilot a plane. The test pilot said it flew well, only needing one click on the elevator to balance it out. Then he dropped the bomb, "it isn't a trainer though". Got a Lancer ARF trainer on the way. Hope I can try it out this weekend. I need to tune up an old Super Tigre 40 that I have for power, I don't want to pull the 52 four stroke off the Ruperts.
ORIGINAL: barracudahockey
Crock pot thing has been around a while. Works best with true ethelene glycol antifreeze like Prestone.
I do it before every swap meet!
You know, I see these tips in model magazines getting published and people getting subscriptions and that for stuff I've been doing for years, I'm going to have to start sending some of this stuff in.
No joke! Hey, no one knows everything. No matter how long you're in this stuff, you'll still learn a trick that's new to you, but old to someone else. Send those goodies in!
One thing is make sure no one ever cooks food in the crockpot again. The porcelain absorbs the antifreeze which will contaminate the food.
ORIGINAL: Plane_Nuts
My Feedback: (9)
CA
Steve,
I use the current Prestone and it works quite well. Just needs a longer "cook" time. Just did an old 120R - 24 hours! but it looks like new!
Phil
Phil
IL
Since I am thrifty (or cheap as my wife says...), I use water in the crock pot and have a glass jar filled with a lesser amount of anti-freeze. That way I can use less AF and it is easier to get at small parts.
Sandy T
Sandy T
I have used this method for a while and have noticed that cooking things too long, and/or too hot, seemed to leach out the aluminum and give it a very dull chalky look.
Has anyone else had this trouble?
I have limited the cooking to about 6 hrs. things have been great.
I'm wondering if cooking too hot, and/or too long really did hurt the metal or did I have a bad batch of aluminum from which the engine was made from?
MR Flyer57
MR Flyer57
ID
No you haven't harmed the metal in your engines by using a crockpot to clean them ,the pot wont get hot enough to do that ,but it will get hot enough to boil causing a oxidation which makes the engines turn darker,A low heat works fine and I have seen 2-4 hrs of heating is all thats needed to get the required results in most cases .
The old saying when its brown its cooking and when its black its done does not apply in this case *LOL*
Happy Flying
Happy Flying
For a quicker (environmentally safer ) method, just pour 3 or three tablespoons of deishwasher liquid on a pot and bring it to boil, put your engine in and either cook on very loww for a couple of hours or just dunk it when its boiling and take out when its cool.... then use a wire brush to remove the deposits.
No use of lots of antifreeze and your wife's crockpot is safe
NE
OMG, I just used this technique and it brought tears to my eyes... I worked so very wonderfully! Thank you thank you thank you!!!
ORIGINAL: driedjello
AZ
I was using this method to clean up some old engines to sell. One is a McCoy .29 Redhead, rear rotor. I thought the "Red" was anodized, Wrong! I cooked it obviuosly too long and the red wipes off like chalk. I was going to repaint the thing to sell, but I think I will advertize it as is. Can you still get ethylene glycol?
Dick Schenz
in Sunny Tucson
Dick Schenz
in Sunny Tucson
