View Poll Results: A poll
Voters: 24. You may not vote on this poll
H9 .60 Size P-47 Engine?
FL
Hi,
I've already started a thread on the subject [link=http://www.rcuniverse.com/forum/m_4388015/tm.htm]HERE[/link], but have narrowed my choices down and would like to see everyone's opinion in a poll. I know there are many other excellent choices, but these fall in my price range and I actually prefer a 2 stroke to a 4 stroke for right now. Thanks for the input.
Dave
Dave
My Feedback: (79)
RE: H9 .60 Size P-47 Engine?
I just picked up the H9 Hell Cat tonight. I fully intend to put a TH .75 in it. I have been flying a TH .75 in my GP Shoestring, and love it. I have never ever "knock on wood" had a dead stick, and I am on my 4th gallon through it this year. It still has the same used #8 plug that I put in it to break it in.
I suggest you consider a Saito engine for your P-47 also. You will be pleased with its performance, and quality of product. Maybe the FA 125 would work well depending on the models final weight.
My Feedback: (79)
There is nothing wrong with the Tower Hobbies .75 It is a real stump puller of an engine, and they run extremely reliable. They are every bit as reliable as a Saito. I am on my 4th gallon this summer with not one flame out or dead stick, and my engine cost 1/3rd of a Saito.
You need a four stroke for a scale model. A two stroke just won't sound right. A Saito 1.00 would be good. Or if you need the nose weight a TT .91 FS.
FL
I appreciate that the Saito is a great engine, but it is a little too expensive for me. These are the engines I am considering buying. If you would like to offer an opinion on one of them, please do.
Dave
Dave
Then buy a used TT .91, they sell cheap because they are not popular, but they run good if you know their quirk's. Those quirk's are pretty minor and well documented here. Course they are heavy so, unless the model is going to need some weight up front, it will add a few ounces. Though not much more than a ST. 90.
My Feedback: (79)
How much more power does the ST .90 have over the Tower .75. My old Tower .75 is on the 4th gallon and I have never had a dead stick. The throttle transition is so smooth. I hate to go to a .90 and have crappy transition.I have just ordered another Tower .75 last night for my H9 Hell Cat, and I could still change the order this moring.
My Feedback: (79)
Bax at Great planes says the benchmark rpm for a .75 w/13-8 is 10,000+ or 12,000 with a 12-7. I have only flown with 12-7's and 12-8's (Shoestring). I ran it with a 13-6 at the tail end of the break in and it was pretty strong. I did not tach it. This engine runs like a Swiss watch, and I am scared to try something with questionable midrange. I have tached mine in the Shoestring running a 12-8 APC & True turn 3" @ 11,400 on 10% WC with a Bisson Pitts. I have also tached the 12-7 with the same setup @ 11,900 richened for flight. I do not push the engine very hard sine it is only pulling a 7lb "Shoestring".
My Feedback: (21)
ORIGINAL: MOTORMAN37
FBD,
I thought you really liked the TH .75. Howcome you picked the ST .90 over the TH .75. Does the .90 run as sweet as the .75. I hear nothing but crap about the ST's midrange. My towers midrange is real sweet.
FBD,
to turn bigger props is the better set-up for War-birds in MHO.
The Tower .75 is a screamer....more suitable to speed planes.
Again....the Tower .75 is not suitable for 3D, or helicopter use.
FBD.
My Feedback: (79)
Well, I hope I made the right decision. The Tower .75 will be here tomorrow. Mine is going in the Hell Cat not the P-47 but I would assume they fly about the same. I am hoping to run a 13-6 or 13-8 like Bax from GP said. I could return the TH .75 and Bission and get the ST .90 though.
Here is a post from Bax @ GP
With an APC 13 x 8 propeller, we'd expect to see the Tower Hobbies .75 engine to turn in the high-10,000's. Any idle below about 2,600 RPM is considered 'good'.
We've also run them with an APC 12 x 7 prop and seen 12,000 RPM at peak.
We generally use the 13 x 8 propeller when we run the engine on our test stand. It tunes quite well when using that prop with a 10% nitro fuel.
< Message edited by Bax -- 3/3/2006 10:55:23 AM >
ORIGINAL: rainedav
Are Tower's weight figures for the engines they sell totally inaccurate? According to their figures: G90 - 27oz; TT .91 - 25.7oz; TH .75 - 23oz. Why is the TT .91 considered a brick and the G90 deemed lighter?
FL
I just wanted to thank everyone for their input. I just placed my order for a ST G90...if it doesn't run well I will e-mail everyone who voted for it everyday until they block my e-mail address
Dave
Dave
