Enya 1.20 question,,, Please help!
Old 09-13-2006, 04:58 PM
William Robison
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Enya 1.20 question,,, Please help!
Ken:
Whether or not you’re running muffler pressure, when at idle the engine is dependent on the carb drawing the fuel – muffler pressure is zilch at idle. What it does is make sure the engine can draw enough fuel at high throttle.
Unless you use a pump or regulated pressure there will always be a mixture change from full tank to empty, the larger the tank the greater the change.
If you always fly around with only shallow climbs and level flight a large tank should work without any pressure, but if you want an aerobat use the smallest tank that will give the flight time you want, and you’ll probably need the pressure.
But will it work the way you want? All I can say is give it a try. Might work fine.
Bill.
William Robison is offline
Old 09-13-2006, 07:02 PM
eclecticant
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The reasone i ask is i baught a enya muffler fot th 120 not r and it has no niple for presure .The startup sheet for bouth from MRC says use no pressure under normal use. one is on a stick 120 size the other on a Precedent large trainor. THANKS FOR YOUR HELP
kEN
eclecticant is offline
Old 04-08-2007, 08:27 PM
thisoneused
My Feedback: (-1)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have one of those older powerhouse 120's for sale....look at the buy sell page for details.
thisoneused is offline
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
