*** CLUB SUPER TIGRE ***
#2178
I cannot offer any assistance on the thread size for the previous post, but I’d suspect it to be an ISO standard metric thread. Probably 2.5mm or 3mm would be my guess.
#2183
My Feedback: (102)
I think you're talking about this Super Tigre spray bar: the threads are 5 mm x .5 pitch.
Woops, I'm on the wrong side of the carb.
#2185
This is for sure my oldest ringed engine, a SuperTigre G-21 .46. it is physically small for the displacement, it has zero leak compression. When flipped slowly you better get your fingers out of the way quickly. My brother in Aurora, Colo. found it in the trunk of a 1963 Ford Falcon Sprint he bought. It was my first RC engine in 198? I still have the engine and my nephew in western Pa. still has the Sprint. It had a exhaust baffle linked to the carb lever but a 40 sized ST Swing Quiet muffler bolted right one.
Best I can do for now of photo of carb if you scroll back to this post and the needle closest in the photo is the one I meed
#2187
#2191
Suer Tigre 75 S,SK or G Piston ringed needed...
I have a 75SK that I need a new piston, even a used one in decent shape. I understand the S, SK and G are all compatible,
Kevin
I love these engines but parts are impossible to find!!!
Kevin
#2192
New Oring Man, took over Bowmans business
Took over Bowman business...
This guy does great work, have purchased several rings from him, the is located in the US..
https://drive.google.com/file/d/0BzG4i1VGb5nXWV9WSTlsdWZOUzlKLTh6ZTJBdU5JTEV3SHNR/view
#2193
GavinCarter makes custom rings as well. He DOES heat treat and lap his rings.Very good quality. Carries a full line of replacement rings.
[email protected]
#2200
is that the weird sized bearing that the S90K uses? I remember having to send the crank housing to you to have a sleeve pressed in to use a smaller more standard bearing.
