If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 60 of 86 FirstFirst ... 1050585960616270 ... LastLast
Results 1,476 to 1,500 of 2144
  1. #1476
    jeffie8696's Avatar
    Join Date
    May 2007
    Muscatine, IA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: *** CLUB SUPER TIGRE ***
    Some people are just ignorant, not on purpose mind you just uninformed. Then there are others. LOL
    Club Saito # 677-Team Boca Bearings-Star Collectibles Muscatine-Glowhead Brotherhood #19
  2. #1477
    Join Date
    Feb 2007
    Dearborn, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Since we are on the subject of Bowman piston ring. I have a 4-stroke glow engine (Magmum) that seems a bit weak. Has about 2 gallons through it. Should I consider a Bowman ring? Compression seems low.
    Content, but not Complacent.
  3. #1478
    Join Date
    Aug 2008
    Keizer, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    not all rings are created equal!!!!!!!! some just buckle under heat and some are made of inferior material to start with!!!!!!! learned that the hard way when i was in the auto repair bez. it ALWAYS pays to buy a high quality ring (or parts) to correct a problem. 2 gals. of fuel should not have in it's self caused your problem. not knowing what conditions you fly in i can't say for sure exactly what problems you are encountering. has the eng. been overheated? is the ring STUCK in the ring land by varnish etc? are you running a premium fuel? has the eng. ingested sand or other trash? if you suspect the ring is just bad then remove the head and inspect the ring end. gap. if in doubt go with the bowman ring, you can't go wrong with his ring!!!! 1 more thing, did you buy this eng. new?????
  4. #1479
    Join Date
    Feb 2007
    Dearborn, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: fujiman
    bought it new and broke it in according to instructions. But I had trouble with it not putting enough power from the start. I did have a couple of sort lean runs while tuning it (2 seconds max). Always used good fuel. I put it in a lighter airplane and lowered my expectations. Starts real easy, idles ok, max rpm is 9000 with a 12x6 (.52 c.i.)
  5. #1480
    jeffie8696's Avatar
    Join Date
    May 2007
    Muscatine, IA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Send it in for warranty , Idid. (twice)
  6. #1481
    Join Date
    Feb 2007
    Dearborn, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: jeffie8696
    Send it in for warranty , IĀ*did. (twice)
    unfortunately, warranty expired a long time ago. But I guess I can try the Bowman ring to see if it helps. Everything else with the engine seems good. Only the top end seems weak.
  7. #1482
    1QwkSport2.5r's Avatar
    Join Date
    Oct 2006
    Cottage Grove, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: hsukaria
    I'd put a bowman ring in it without batting an eye. His ring gaps are a lot tighter than stock rings so the compression should be vastly better. Even if I had an engine warranty, the cost of the ring would be cheaper than sending the engine in for warranty service IMHO.
    GlowHead Brotherhood #3
    Real engines use glow plugs.
    R.i.P Jacob Wetterling #11 10/22/1989
  8. #1483
    jeffie8696's Avatar
    Join Date
    May 2007
    Muscatine, IA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Mine had issues with leaky valves and a broken cam gear, its replacement is much better.
  9. #1484
    Join Date
    Oct 2006
    Cottage Grove, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Of course that's a totally different story. In that case, I'd send it back. A piston ring I wouldn't.
  10. #1485
    Join Date
    Feb 2007
    Dearborn, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    the valvetrain is good, based on just limited experience and good behaving starting, idle, and throttle transitions. It's top end is weak only. So, I figured I'll try the ring change. Thanks for the advice, fellas.
  11. #1486
    Join Date
    Jul 2002
    Brockton, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I've never heard of Bowman rings. Can you tell me a little bit more about them and send a link??
    Bob
    Club Saito #61 - Cub Brotherhood #107
    Spitfire Brotherhood #143 - Kadet Brotherhood #3
    Glowhead Brotherhood #95 - Balsa USA Brotherhood #137
  12. #1487
    earlwb's Avatar
    Join Date
    Aug 2009
    Grapevine, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Frank Bowman is very popular for piston rings, he makes them for just about any engine out there. If he doesn't have the specs for it, you can send him the cylinder and piston and he will custom make the rings for it. He'll do it also for anominal fee if you don't want to take the engine apart too.
    His email address is ringmaster46@msn.com
    My last ring list from him was in 2011 so it may be out of date now.
    Frank Bowman
    1211 N Allen Ave.
    Farmington, N.M. 87401-3568
    505-327-0696
     Email: ringmaster46@msn.com
    Reproduction Model Engine Rings
    Quality at a fair honest price. Making a good ring is a Skill. Making a fine ring is an Art!
    Last Revised 1 - 7 -11
    I will reproduce nearly any model engine ring. If not available, I’ll need a good piston and cylinder to measure, or send motor. Send return postage, insurance is extra. For orders outside of USA, ask for shipping costs? Priority postage is extra. An order of 10 rings or more, discount of $1.00 off per ring, mixed orders are fine! Ring cost & shipping charges for USA listed below.
    Please Note:
    If you send me an engine for new rings that I don't currently make there will be No labor charge to do this.
    If you send me the stripped down engine block ( Block, piston liner and rod assy.) for rings, that I Do currently make No extra charge.
    If you send me a complete engine to disassemble, clean, and install the ring(s) and reassemble there will be a minimum charge of $25.00 per hour. My buisness is making Piston Rings and $25.00 is the minimum amount I would be losing by not making rings and working on your engine insted.
    ATTENTION : NEW MEXICO CUSTOMERS WE HAVE TO CHARGE YOU 7.125% TAX, please add the extra tax to your orders.
    Standard ring up to .65 engines: $9.00 ea.(1) shipped $13.00, (2) shipped $22.00 (1) .64 (2) $1.28
    Standard ring from .66 & up: $10.00 ea.(1) shipped $14.00,(2) shipped $24.00      (1) .71 (2) $1.43
    Dykes ring up to .65 engine: $10.00 ea.(1) shipped $14.00,(2) shipped $24.00      (1) .71 (2) $1.43
    Dykes ring from .66 & up: $11.00 ea.(1) shipped $15.00,(2) shipped $26.00          (1) .78 (2) $1.57
    ** I also make special rings to order, ask for prices.**
    Ace Twin .64
    Aero .35
    Aerrow 100 (pin) Quadra
    Aerrow 200 (pin) Quadra
    Aerovat 65 CC (pin)
    Aircom M61 (pin)
    Air-O .45
    Anderson Spitfire .65
    Area 51CC (pin)
    Asp .52 4C, .61 (pin), .65 4/C, .80 4/C, .91 4/C
    Atomic 60 Don Sohr
    Atwood .49, .51, .63
    Avion Mercury 1.609
    Avistar .60 (pin)
    Bantam .16
    Bat .19
    Bennelli 65 CC (pin) motorcycle
    Berilli 36 CC (Pin)
    BME 3.5 Twin (pin), 105 (pin), 110 twin (pin)
    Brillelli 60 CC (pin)
    Brison 2.4 (pin), 3.2 (pin)
    Brown Jr. .60 cylinder sizes vary (send Piston & cylinder for proper fit & correct ring)
    Brownie .29
    Bushwacker 37.7 CC (pin) Sears
    Bunch .45, .49
    Cameron .15, .19
    Cave Cobra
    Chung Yang 29CC (pin)
    Cleveland Tom Thumb .45
    Comer 50CC (pin)
    Como .29 (pin), .40 (pin), .51 (pin), .90 (pin)
    Contestor D.60
    CRRC Pro 26CC (pin), 40 CC (pin), 45 CC (pin)
    CS .53 (pin)
    Cub Cadet 25CC (pin)
    DA 50 CC (pin) (2) different 1.678 Bore, & 1.681 Bore
    DL 50 CC (pin)
    DLE 20 CC (pin), 30 CC (pin), 55 CC (pin),110 Twin (pin), 170 Twin (pin), 222 4 cylinder (pin)
    DME 100 Twin (pin)
    Dooling .29, .61, Yellow Jacket
    DZY 48 CC Twin (Pin)
    Echo 16CC (pin), 21CC (pin), 21.2 CC (pin), 24.4 CC (pin), 30 CC (pin), CS-3000 (pin), 50 CC (pin)
    Edco Sky Devil .64 Old or New (RJL) state which one?
    Elf Andrea Heine Repo
    Enya 3.5 (pin), .30 SS (pin), .35 X (pin), .40 X Dykes (pin), .40 Dykes model 6002, .40 4/C, .45, .45SS (pin), .46 4/C,.49 X (pin), 50SS (pin),.53 4/C, .60 4/C, .60 X (pin), .60 standard, .61 CXLR (pin),  .80 X (pin), .80 4/C, .90 4/C, 120 4/C,  120 R 4/C, 1.55 4/C, 240 4/C Twin
    ETA .29
    EVO 150 Twin (pin)
    EVRA 190
    Forster .29, .31, .88, .99
    Fox 36 Sand Cast (pin), .40 Sch., .45, .50, .59 .047 thick ring and .030, .59 long shaft Ign., .60 Blue Head, .60 Eagle, Fox Hawk
      Red Head .60 (pin), .74, .78, 120 Twin (pin), Gas Bore 1.439 ? (pin)
    GMS .61 (pin), .61 Dykes (pin), .76 Dykes (pin), 1.20 Dykes (pin)
    Hassad Blue Streak .64
    HB .21 Dykes,.25 Dykes, .40 PDP Dykes, .40 Black Head (pin), .50 Dykes, .61 (pin), .61 Dykes
    Hiller (Car)
    Hirobo 36 (pin)
    Homelite 25 CC, 30 CC (pin) old .060 thick pin centered (press in ) , 30 CC newer .030 thick (pin), 30 CC new style Off set pin,  33 CC (pin), 38 CC (pin), 40.6 CC Super EZ Chain Saw, Super Mini Chainsaw Dykes (pin), 45 (pin), 50 CC (pin)
    Horner 3.7 Twin (pin)
    Hornet .19, .60
    Howler .60 (pin)
    HP .21 4/C Dykes ,.40 (pin) ,.61 R.I. Silver Star (pin), .61 Dykes (pin) Blk Case Gold Hd.
    Hurluman 60
    Husqvarna 2100 (pin) Chainsaw Pin needs pressed in 1/2 way
    Irvine .20 Dykes, .25 Dykes, .36, .40 Pylon Dykes (pin), .40 Standard (pin), .46 MKII Q46 Dykes, .61 Dykes, 150 standard non pin.
    JC Evo 28 CC (pin)
    Kavan MK 50
    KDC Kioritz 21.2 CC (pin), 23.6, 25 CC (pin), 30 CC (pin), 58 CC (pin)
    K&B .35 Dykes, .40 Dykes, .40 S Dykes (pin), .61, .61 Dykes (Lee Custom), 1.35 (pin), 1.5 (pin)
    Kometa 29
    Kraft .61 (pin)
    Kratmo 10 CC, 4A Ignition
    Laser 61 4/C
    Lewis 60
    Magnum .52 RFS 4/C, .53 XL 4/C, .61 XL (pin), .61 4/C, 70 4/C, .91 XL 4C, 120 4/C, 120 (pin)
    Maloney 100 (pin), 125 (pin)
    McCoy .09, .19, .19 Dykes B.H., .21 Dykes Car, .29 all versions, .29 Dykes B.H., .35 Dykes B.H., .36, .40 Dykes B.H., .49, .55, .60, .60 Dykes
    McCulloch 15 CC ? (pin) 1.024 Bore, 21 CC (pin), 25 CC (pin) MDB 90 Leaf Blower, 28 CC, 32 CC (pin),
    MDL 28 CC (pin)
    MDS .78 (pin), 1.48 (pin), 2.18 (pin)
    Merco .40, .49, .49 Dykes, .50, .61, .61 Dykes
    Micron 60
    Moki M .51 (pin), .61 (pin), 1.20 (pin), 1.35 (pin), 1.50 (pin), 1.80 (pin), 2.10 (pin)
    MT 42CC (pin), 57 CC (pin)
    O&R Industrial Motor 1 HP
    OPS Maxi .30 (pin)
    OS .20 FS 4C, .26 4C, .28 FH Dykes (pin), .30 fs 4/c, .32 (pin), .37 H (pin), .40 H Dykes, .40H Standard, .40 H (P) Pylon, .40 FS 4/C, .40 SF (pin), .807 bore, .40 SR (pin), .40 FSR .835 Bore (pin), .40SR Dykes (pin), .45 FSR (pin), .45 FSR Dykes (pin),.45 RSR Dykes, .46FX (pin), .46SF (pin), .48 4/C Surpass, Max .50 old, .50 FSR Dykes (pin) ,.50 H (pin), .50 SX & SXH (pin), .52 4/C surpass, .58, Max-H .60, .60 FS 4/C, .60 FSR (pin) .9445 Bore ,.61 SF .9055 Bore (pin), .61 FS 4/C, .61 SX (pin), .61 SXH (pin), .65 RSR (pin), .70 4/C, .75 4/C Surpass, .80 H,.80 Dykes (pin), FS.90 4/C, .91Surpass 4C, .90 FSR (pin), .91 FSR (pin), .91 FX (pin), .91 SX H (pin), 1.08 BX-1 (pin), 120 4/C, 120 twin 4/C, 120 AX (pin), 160 FX (pin), 160 4/C,  BGX-1 3500 (pin)
    Poulan 25CC (pin), 25 CC Featherlite (pin), 32CC (pin), 35 CC (pin), 42 CC (pin), 42 CC Wildthing (pin), 46 CC (pin), 54 CC (pin), 60 CC (pin)
    Profi .40 (pin), .61 (pin), .76 (pin)
    Quadra 35 CC , 40 CC (pin), 42 CC (pin), 50 CC (pin), 100CC Aerrow (pin), 150 Twin  (pin) , 200 CC Aerrow Twin (pin)
    Quick Draw CC (pin)
    RCGF 20 CC (pin)
    RCS 1.40 (pin)
    Ross .60 Dykes (pin), .60 opposed twin Dykes (pin), .61 (pin)
    Rossi Speed .60 old, .60 (pin) .021, .61 (pin) .023, .65 (pin) .0235, Speed .65 (pin)
    Royal 40 (pin)
    Ryobi 26 mm Bore EJ 100 (pin), 31CC (pin) older .064 thick, 31 CC (pin) newer .047 thick
    Saito FA .30 4/C, .40 4/C, FA .45 4/C, FA .50 4/C, FA .56 4/C, FA .60 Twin 4/C , FA .65 4/C, 72 4/C, FA .80 4/C, FA 82 4/C, .91 4/C, 100 4/C, 120 4/C, FA125 Golden Knight 4/C, FG 20 125 4/C, 130 TD 4/C Twin, 150 4/C, 180 4/C, 270 4/C Twin, 300 4/C Twin
    Sachs 2.0 (pin), 3.2 (pin) offset, 3.2 (pin) centered, 5.8 (pin)
    Sap-180 HP 1.2 (pin)
    Scott Thunderbird
    Sears Weedeater, Bushwacker,18 CC, 21 CC, 25 CC, 25 CC TWC Leaf Blower, 37.7, all pinned, 1966 Allstate Moter Cycle engine made by Puch (pin)
    Shindiawa 33 CC (pin)
    SIFK 29CC (pin) AKA CY, Chun Yang
    Skil chainsaw (pin)
    Sky Chief .53
    Spe 25.4 (pin), 26 CC (pin), 40CC (pin), 45CC (pin)
    Stihl 25.4 (pin), 028 Chain Saw 44 CC (pin),  Super 45 (pin), 57 CC (pin), MS 440 Chainsaw 70 CC (pin)
    Super Tigre G20.15, G20 .19, G20 X.25, S .29 (pin), G21.29 old, .34 (pin), .40 Bullring, S.40 (pin), G21.40 std., G21 .40 Dykes, G21.46 std. ,S.45 (pin), V.45, X.45 (Pin), G21 .46 wide Dykes, G.46, G .46 Bullring, V 51, G51 (pin) Italian, G51 (pin) China, V.56, V.56 Dykes, V 60 light case .044 or .047 top to bottom measurement, G24 60 Old, G 60 Bluehead, X60 (pin), V.60 wide & narrow Dykes, S.61 (pin), G.71, S.75 (pin), .90 (pin), 2000 (pin), 2300 (pin), 2500 (pin), 3000 (pin) Italian, 3000 (pin) China, 3250 (pin) Italian, 3250 (pin) China, 4500 (pin)
    Syncro B-30, Syncro ACE, Syncro ACE Special
    Tartan 1.34 (pin), Twin .77 (pin)
    Tech 23CC (pin)
    Technipower 7 Cylinder radial, B series, 9 cylinder
    3MM 53 TOC (pin)
    3W 26 CC (pin), 80 CC Boxer Twin (pin)
    Thunder Tiger .39 (pin), Pro .50 H (pin), .53 Red Line Heli (pin), .54 4C, .91 FS 4C, 120 Pro (pin)
    Toki .40 (pin)
    Ueda .45, .61
    US 25 CC (pin)
    Vlvatam 2.5, 5 CC
    Veco .21 Dykes, .50 Dykes, .61, .61 Dykes
    Vega 10CC, 91 4/C
    Webra .32 Speed Dykes (pin), 35 (pin), 10 ccm, 6.5 (pin), .40, .40 (pin), .40 Dykes (pin), .50 Dykes (pin), 52 (pin), .55C AAR Red Head Heli (pin), .61, .61 (pin), Speed .61 FS (pin), Speed .61 F Dykes (pin), .61 Dykes (pin), Speed 70 (pin), T480 4C, .91 (pin), 91 PS (pin), 120 Dykes (pin), 1.2 LS (pin), 91 (pin) T 4.90, 35 CC? Bully (pin)
    Weedeater 18 CC (pin), 21CC (pin), 25CC (pin) 1.358 Bore, 25CC (pin) 1.380 Bore, 22 CC (pin), 32CC (pin)
    Weedwacker 25CC (pin)
    Westbury Atom III
    Yamaha 50CC (pin)
    YS .61 Long Stroke (pin), .63 4/C, .80 H (pin) 2C, F.91 AC 4C, .91 2C (pin), 110 4/C,  F120 4C
    YW 24CC single & 48CC Twin (pin)
    ZDZ 40 (pin), 50 NG RV (pin), 60 RV (pin), early 80 RV (pin), later 80 - J model (pin)
    ZEN G270 (pin) AKA Chung Yang
    Zenoah G20 (Pin), G23 (pin), G26 (pin), G38 (pin), G45 (pin), G62 (pin), GT-80 Twin (pin)
    Club Saito #722, Sig Kadet Brotherhood #80, GlowHead Brotherhood #14,
    AMA # 928076
  13. #1488
    Join Date
    Jul 2002
    Brockton, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks... I see my engine listed. I thought that he might have a website too where I could get some education on rings. Can a dykes ring be substituted for a common ring or does the piston have to be specially designed for the Dykes?
    Don't mean to hijack the thread. Thanks again for the information,
    Bob
  14. #1489
    jeffie8696's Avatar
    Join Date
    May 2007
    Muscatine, IA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Dykes ring pistons are specifically designed for them, they are recessed at the top.
  15. #1490
    Join Date
    Feb 2007
    Dearborn, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I just ordered a ring from Frank today. First ring from him. I will do a before and after test on the engine sometime in the future.
  16. #1491
    Join Date
    Oct 2006
    Cottage Grove, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I ran my Italian S29 with a new Bowman ring today for 24oz of fuel. Compression is decent but still softer than I'd expect. I haven't checked, but I'm sure the ring is pretty well seated. I'll verify tomorrow. A question I thought of, did the S29 come in ABC form or ringed only? If it did come in ABC configuration, can a ringed version be converted to ABC? Not that I'm in search of an ABC piston and liner, but asking more out of curiosity. I may go looking for a NOS piston and liner for my ringed engine in case the liner is out of round some. Perhaps I may have to see if I could get the bore of my engine hard chrome plated to give it a little tighter fit. It hasn't been peaked with the new ring yet so I don't have any numbers to compare to just yet.
  17. #1492
    Join Date
    Apr 2012
    Laurel, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Reading the Threads to learn what I can, this plane has a 60, funny thing is I just got a 75 and it is the exact same size except it says "75"
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1783522   Click image for larger version.
  18. #1493
    Join Date
    Mar 2009
    Guilford, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Tom.in.Maryland
    Reading the Threads to learn what I can, this plane has a 60, funny thing is I just got a 75 and it is the exact same size except it says ''75''
    I am not sure about the G series that yours appears to be, but my S90 is the same case size as the 60 and 75 of that series (round machined head with dished top).
  19. #1494
    Join Date
    Oct 2006
    Cottage Grove, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: spaceworm
    The SuperTigre 60/61, 75, and 90 both G and S series engines are 60 sized cases. If the front housing bolts on, the pictured engine is a S61K, a non bolt-on front housing is a G series engine. K suffix engines use the same head as the G series.
  20. #1495
    Join Date
    Apr 2012
    Laurel, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Pictured above is a G61 ABC the 75I am talking about is a Ringed G75, Thanks.
  21. #1496
    Join Date
    Feb 2007
    Dearborn, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The same applies to the G40/45/51. Even though the 45 is ABC. You get the displacement increase by making the cylinder liner thinner and with a stronger metal, hopefully.
    That's why the higher displacement versions are lighter than the lower displacement ones. So the 90 is listed as lighter than the 60 and the 51 is lighter than the 40. That is because the heavy cylinder liners are thinner in the bigger displacement versions (less metal, more air).
  22. #1497
    Join Date
    Sep 2003
    Port Allen, LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Okay all you Super Tigre afficionados out there.
    I need help with some specific information on the Super Tigre engine in the photos. On the exhaust side of the cylinder it says "Series X G.60". On the other side it says "Made in Italy by Super Tigre". It has a crankcase vent but it is plugged and not being used in the old Aeromaster Biplane in which it is mounted. I can recall years ago that it hauled that old "heavy" Aeromaster around the sky with quite a lot of authority. I would like to get some idea as to the vintage of the engine and whether it is anything special as Super Tigre engines of that vintage go. I have looked on-line but all of the similar looking "Super Tiger .60 Bluehead" engines I could find had a large, rather conspicuous bypass port running up the side of the cylinder. This one has nothing of the sort. Since this one has a bolt-on front end, I would like to get it running, rotate the front end 90 degrees so it will run in "reverse" and use it in a pusher aircraft. What kind of performance can I expect from this engine? Any information you guys can give will be greatly appreciated.
    Attached Images Attached Images
  23. #1498
    Join Date
    Oct 2007
    East Bernard, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have a NIB ST-6000 that I will never get around to using - never mounted, never run, new as they come, in case anybody is interested. Too many Toys, not enough Time! I paid $600 plus Shipping on eBay. Photos available if anyone is interested.
    Matagordababy
    helisales@aol.com
ID:	1790528   Click image for larger version.
ID:	1790529   Click image for larger version.
  24. #1499
    Join Date
    Feb 2007
    Dearborn, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I need advice tuning my ST G51. The past year or so I noticed that the midrange transition is very rich and I get a stumble, sometimes big surges (engine cuttng) while transitioning from idle to WOT while flying. It acts like it is very rich in the midrange. Sometime ago I loosened the 2 throttle barrel screws and rotated the throttle assembly very slightly clockwise to help lean it a bit. The low speed needle valve is set as lean as I can get it without sacrificing a good idle, the high speed needle is set just a bit rich from peak. So, should I rotate the throttle barrel clockwise some more?
    I am running 15% nitro with a medium plug, 11x7 prop and a MACs one-piece muffler. Performance is excellent except for the throttle transition.
    Thanks.
  25. #1500
    Join Date
    Oct 2006
    Cottage Grove, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: hsukaria
    Thanks.
    I'd drop the nitro some first. They may tolerate higher nitro when breaking in since they're ran rich but when broke in and run leaner, act up. If 5-10% nitro does the same thing, then rotate the spraybar. I rotate mine so the fuel inlet fitting is pointing at the engine mount lug.
    I noticed on my Tigres, during the first couple gallons of fuel, the spraybar needed to be rotated a lot to get a good transition. After they have some run time, the spraybar has to be returned to its original "straight in" position which gives a superb transition. Stock out of the box it would blubber like a sloppy pig like this, but broke in good it runs great.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
