Help with a OPS .60
RE: Help with a OPS .60
ORIGINAL: downunder
No, it doesn't .
ORIGINAL: DarZeelon
It seems to have a 24 mm bore and a 22 mm stroke... I.e. it is not a 'Long Stroke' engine and this means high RPM.
This engine is not a .61 cid displacement, but a somewhat older target displacement of .60 cid.
The stroke is still 22 mm, but the bore is a smaller 23.85 mm.
I wrote this before checking. My bad.
It is still intended for higher RPM, however.
