Sacha 5.2 & Lanier Giles 202
My Feedback: (56)
NC
A Sachs 5.2 & Lanier Giles 202 35% is this a good combo? Im getting a good
deal on the sachs. the plane is being built now. if any one has any sugestions
please help.
charles
please help.
charles
My Feedback: (15)
35% giles
I would consider a zdz 80rv with the pitts muffler, it puts out 57lbs of thrust and weighs only ~4 1/2 lbs, I was going to use a Brison 5.8 and it was going to be too heavy on the nose, but you still could use that engine, plenty of power as well, later.
My Feedback: (15)
g-202
no, the way Lanier kits are built they are kinda heavy, but if you do some cutting on the wing cores and lighten the fuse a little its ok, the sachs 5.2 probably dont weigh as much as my 5.8 did, the true weight of the zdz80rv is 4.29 lbs but I think that is without the muffler and ignition, probably closer to 5 lbs with battery, ignition and muffler.. , you will be ok with the sachs if using four servos in the tail and keep the nose light with lightning holes in firewall and use a zn carbon spinner?, maybe this helps your decision, I wanted to use the brison but I got so many other opinions from other sources, I will see if the zdz truly lives up to the reputation it is getting now, later.
