Glow Plug worries
#101
RE: Glow Plug worries
Are you happy with the header length and pipe dimensions on that engine? What are you using? What rpm range are you operating it in? Is it in a standard DF installation or are you running a prop on it? It seems that you are getting a lot of detonation at your normal operating rpm, based on the plug destruction going on.
#102
It is a standard DF set up. Airframe is a Grumman Panther. I am unsure of what the pipe is. The engine does not seem to be pre-igniting although I am not experienced with DF set ups.
