getting drive washer back on saito 91
G'day im in the process of replacing the bearings in my saito 91 and have a question.What is the best way to mget the drive washer back on?being a taper should i just use the vise to press it back on? Your help would be great thanks[]
RE: getting drive washer back on saito 91
Thanks for the help fellas will do that.Do you think that sealed front bearings are better than shielded?
G'day Mate,
I generally use stainless bearings, & they come with shields, but I don't think it makes a difference, on the front bearing, & the shields or seals should be removed on the rear bearings anyway.
My Feedback: (19)
It depends on what you want. OS now uses sealed bearings front and rear in the FS. Don't use a sealed rear bearing unless the engine is designed for it, the cam housing might run dry if you do. The sealed front bearing reduces the wet nose syndrome.
