Club Laser?
Reply
Old 03-22-2007, 09:15 AM
  #51
jjmretired
My Feedback: (15)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Club Laser?
Dave, Got the 180 yesterday. There is a updated instruction sheet (from the 70). It says max of 10,000 rpm for the 70. you might want to load it a hair more.
jjmretired is offline
Old 03-22-2007, 10:50 AM
  #52
Hobbsy
My Feedback: (100)
Hobbsy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Jay, I was surprised at its power, especially on 5% nitro, most likely I'll run a Bolly 13.5x6, now for a plane. I take it that your 1.80 is a single, mine is a twin, let us know how it goes.
Hobbsy is offline
Old 03-22-2007, 03:08 PM
  #53
Marcol
Marcol's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The carb used on the West 4 strokes is a Webra unit
Marcol is offline
Old 03-22-2007, 03:17 PM
  #54
Marcol
Marcol's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guys,
Don't be afraid to load the Laser up with a big propellor. It's got torque by the bucketfull.
I run a 13 x 8 on my 70, so a 13.5 x 6 will be fine.
Because the Laser doesn't rev it's ass off people assume that it's lacking in power. But as we in the club know this isn't the case.
Marcol is offline
Old 03-22-2007, 03:58 PM
  #55
Hans Meij
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is a recommendation from Laser:
LUBRICATE through the BREATHER NIPPLE on the rear of the crancase before and after the initial running in and after every 3 hours running. Lubricate the engine if it is not to be used for some time and before running again. The breather nipple can be extended with tubing. Oil may come out of the front bearing if the breather is restricted, there is a lot of oil in the crankcase or the engine is left with the nose down. This will not harm the engine.
Have for a laser 150 in operation for two years now. It works great.
Use 15% Aerosave oil and 8% Nitro, engine pointing down.
From time to time I pull the valve cover to check for valve clearance.
No problems, and everything is filled with oil there and no spot of corrosion.
Because the engine is leaking oil everywhere when it is stored after flying I know it must be lubricated well inside, and that is confimed every time when I open up the cover.
A month ago I started using the 200V engine. Filled it with a amount of oil through the breather when used the first time.
After that I did not apply extra lubrication the same way as I did with the 150.
It has a gallon through it and I noticed that it was loosing power when becoming warm, and was not as powerfull as in the beginning.
Today I pulled the valve-covers. It was quite dry inside, and one of the two spaces had the brownish muddy debree of corrosion inside.
So perhaps something to be aware of, it seems that, especially the twin, needs the insertion of oil through the breather before ande after flying sessions.
Hans Meij is offline
Old 03-22-2007, 09:41 PM
  #56
Kmot
My Feedback: (24)
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Marcol
Thank you.
Kmot is offline
Old 03-25-2007, 11:49 AM
  #57
Marcol
Marcol's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hans,
As you are using aerosave oil, as I do, you shouldn't need to use any other corrosion protection.
On the last run of the day I throttle up to full power for about 30 seconds to get the engine hot and then run the engine dry. Either by pinching the fuel line or disconnecting it.
The Aerosave oil offers the best corrosion protection of anything I have tried BUT, you must NOT mix it with a mineral based oil .
This could be some of your problem with your 200V.
Marcol is offline
Old 03-25-2007, 12:56 PM
  #58
Hans Meij
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Marcol
No only Aerosave. What I've mentioned, the V-engine somehouw does not collect oil as a result of normal operation under the valve cover. After a day of flying it is dry there. After a flying day you have to insert a few cc's of oil through the breather. This will enter the room of the valve cover and will give the corrosion protection. This is what I have experienced with the V-200
Old 03-27-2007, 02:08 PM
  #59
Marcol
Marcol's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hans,
Is your 200V mounted inverted or upright ?
Colin
Marcol is offline
Old 03-27-2007, 02:27 PM
  #60
Hans Meij
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Colin,
It is mounted inverted.
ID:	651277   Click image for larger version
Old 03-31-2007, 05:33 PM
  #61
TLH101
My Feedback: (90)
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just picked up a Laser today at an estate sale. I think its a 1.50. It is stamped P-22, on the mount rail. Can anyone tell me for sure?
ID:	653880   Click image for larger version
ID:	653881   Click image for larger version
TLH101 is offline
Old 03-31-2007, 09:29 PM
  #62
Hobbsy
My Feedback: (100)
Hobbsy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www.laserengines.com/
According to the pics here the 1.50 and the 3.00 twin have the purple carbs.
Hobbsy is offline
Old 04-01-2007, 01:18 PM
  #63
TLH101
My Feedback: (90)
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah, I looked at their website, and that's why I think I have a 1.50. Weight and hieght seem to mach as well, but I notice the newer models have more "rounded" shape than mine, so I just trying to confirm. I also noticed earlier in the thread, someone mentioned a purple carb on a .70, I think it was. This one came from the estate of a local flying buddy, and I'm pretty sure he had it for at least 10 years.
TLH101 is offline
Old 04-22-2007, 04:33 PM
  #64
TLH101
My Feedback: (90)
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well it must be a 1.50. I ran it today and with an old 16x10 Classic prop it turned 8600 rpm. Saw up over 9K with a 16x8 APC, but could not get a good tach reading from the grey prop with the cloudy conditions today. Idle would tick over at 15-1600rpm. I was using Byrons 15% with 16% oil. This has to be the smoothest running four stroke I have ever run.
BTW, the guys at Laser said it was built in '96 or '97, based on the numbers stamped on the mount rail.
I need to get this puppy something to fly soon.
TLH101 is offline
Old 04-22-2007, 07:50 PM
  #65
PlaneKrazee
My Feedback: (14)
PlaneKrazee's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks like Moki is making an exact copy or licensed version of the Laser engines.
http://www.remekmotorok.net/index.htm
PlaneKrazee is offline
Old 04-22-2007, 10:54 PM
  #66
TLH101
My Feedback: (90)
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Skypilot_one
Actually the only similarity is rear push rods.
TLH101 is offline
Old 04-23-2007, 12:08 AM
  #67
Hans Meij
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: TLH101
And all the dimensions and other specs even the text on the website.
Have read on a German forum that it is more a possible future direction than reality.
Old 04-23-2007, 10:28 PM
  #68
proparc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guys,
First off I would like to thank you for getting this Laser forum going. I have been interested in the Laser for a long time. In particular, the Laser 70 is the motor I have had a lot of interest in. Anything you you guys can tell me about the motor including the pictures posted on the site would be very helpful indeed.
Again, thanks for a great forum.
proparc is offline
Old 04-24-2007, 08:15 AM
  #69
TLH101
My Feedback: (90)
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I see on the Laser site, the instructions say to NOT use a wood prop. Anyone know why this is?
TLH101 is offline
Old 07-24-2007, 02:13 AM
  #70
ulrich/Germany
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I ran several Laser engines and made the experience that they run smoother when using "heavy" props.
Usually wood props are not so heavy than plastic ones (like APC or the new Graupner sonic).
But generally speaking this counts for all 4cycle engines.
Ulrich
ulrich/Germany is offline
Old 07-24-2007, 11:20 AM
  #71
mickreeves
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am looking for a cheap Laser 300 V twin. Damaged one considered. Any offers.
There is no problem running lasers on woooden props.
Mick
mickreeves is offline
Old 07-26-2007, 11:24 PM
  #72
PlaneKrazee
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mick,
The word cheap and Laser don't seem to belong together in the same sentence.
Old 07-26-2007, 11:31 PM
  #73
fiery
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mick
Are you THE Mick Reeves of UK modelling fame?
I own a Laser 300V. You don't see them come up for sale very often. Once owned, they are treasured.
I bought mine on the Engine sale forum here at RCU from an old gentleman who got too old to fly.
It was still NIB, he bought it from Proctor Enterprises, the US agent. I recall I could not negotiate as much of a discount on it compared to a new engine, as I normally can with other more run of the mill stuff.
I hope you find one that suits. They are stunning engines.
A new 360 twin is also available, but I have never seen a used one for sale
fiery is offline
Old 07-27-2007, 07:46 AM
  #74
longdan
longdan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've always wanted a Laser engine since I first saw an article on them being developed sometime in te 80's. They looked like a cut above the rest at the time. Seems they still are.
Do they have a website? I've looked, but can only find US distributors.
longdan is offline
Old 07-27-2007, 01:43 PM
  #75
PlaneKrazee
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Laser V twins use one crankpin/crankthrow like the Enya VT-240. I can't see them running as smooth as a boxer with a double throw crank.
fiery,
Have you run the engine? Also, he is "the" Mick Reeves, model builder/musician/business owner, overall very nice guy. Unfortunately, I bought not one but two of his 1/6th scale glass Spitfire fuselages before the moulds were repaired to correct an alignment issue[]. I understand the new fuselages being produced are perfect now. The ones I purchased had great detail, too bad the nose was crooked opposite the required engine thrust. []
