Saito 82 muffler placement options?
Reply
Old 04-23-2007, 12:42 AM
Ernie Misner
Ernie Misner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Saito 82 muffler placement options?
On an inverted Saito 82, I am looking at ways to make the muffler come out right down behind the engine rather than sticking out to the side. I have the Right Angle Adapter ordered and that will come in when they get caught up on production.
A short curved pipe to screw into that right angle adaptor, and then the muffler into that would help, but the 82 only comes with a short straight piece of pipe. Does anyone know of a short curved pipe anywhere? I can't seem to locate one on Horizon's website.
Thanks!
Ernie
Ernie Misner is offline
Old 04-23-2007, 01:47 PM
Vallhala
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Saito 82 muffler placement options?
http://www.saito-mfg.com/parts-files...ine-mount.html
Hi Ernie
Loock at Saitos website.
Lars Lindström
Vallhala is offline
Old 04-23-2007, 02:01 PM
onewasp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ernie Misner
Order Saito part # SAI8075A.
It is the angle "header" that used to come with the 72----fits and works just fine for your purposes.
It happens to be what I've been using in a similar application together with the 90* you already have.
onewasp is offline
Old 04-23-2007, 02:06 PM
Ernie Misner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's just the info I was looking for guys. I thought I rememberd the 72 having that curved pipe.
Thanks again!
Ernie
Old 04-24-2007, 06:50 PM
jcw111
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ernie
Had the same problem and ordered the RT angle header. It is made of aluminum and machined improperly. Thr thread portion that screws into the head is threaded right up to the aluminum bloc that makes up the right angle There is no fillet to relieve the stress caused by the weight of whatever you hang on it. That plus heat and vibration caused mine to break after two flights.
My Saito is the 100. I hope they have changed the design but I doubt it.I should have sent mine back but it sits on the bench. You might give some thought about using the flexible extensions that they offer. I gave up and cut a hole in the cowl
Jim Whitney
jcw111 is offline
Old 05-13-2007, 05:56 PM
Ernie Misner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Jim, thanks for the heads up. Is your 100 12mm exhaust size like the 82?
Well on mine, there is about 3/8" of threads and then about 1/16" curved fillet part that gives some strength to the unit. We'll see how it goes in a couple of weeks.
Thanks again,
Ernie
Old 05-13-2007, 06:05 PM
Hobbsy
My Feedback: (101)
Hobbsy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ernie, here is RVM's .82 with a TurboHeader on it. That one is a prototype, that's why it's only half anodized.
Hobbsy is online now
Old 05-13-2007, 06:07 PM
Ernie Misner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well ain't that 82GK pretty. Do you still think the Turbo Header is adding a few hundred rpm's?
Thanks Dave,
Ernie
Old 05-13-2007, 06:30 PM
Hobbsy
My Feedback: (101)
Hobbsy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ernie, it typically adds about 200 to 300, it has an especially neat sound on the .82.
