Best prop for Magnum 61 four stroke in 6.5 lb warbird?
CA
The manual recommends pretty much anything from 11x8 to 13x7 prop sizes, with 12x6 used for break-in. I want to use this for a 6.5lb Kyosho Zero. I'm looking for good power for loops and simple aerobatics, but I don't need blazing speed or unlimited vertical. What's a good prop size for my application?
TX
RE: Best prop for Magnum 61 four stroke in 6.5 lb warbird?
ORIGINAL: DaveInLA
CR
CA
Ok, newbie question. I know what the numbers of a propeller's specs mean in a physical sense, but how do they affect flight? For example, I know that larger diameter typically means fewer revs for any given engine, but if you increase the thrust of the prop (ie, 12x6 vs. 13x5), does that make up for it? For example, how would a 12x6 prop fly with this engine compared to a 13x5? Thanks
MB, CANADA
Download "Aero Design Prop Selector" on google. My tests show it to be very accurate. Safe download.
My Feedback: (14)
Very nice, thanks for the tip and the web page.
My Magnum .61 was not what I would call a super strong performer. It was acceptable with a 12x6 or 13x5, but anything with more load would be straining it a bit. Maybe others samples are different (everyone) from mine. On a small warbird, I too would be tempted to run a 10x8 or 11x7.
Ed Cregger
Ed Cregger
ORIGINAL: DaveInLA
Theorycrafting the best prop for the job depends on a lot of factors:
1) How aerodynamic (slippery) is the airframe? Does it need more thrust (more diameter/less pitch) to drag it through the air or is it aerodynamically clean enough to benefit from more prop pitch?
2) Is the airframe better when doing higher speed aerobatics (like the pattern guys do) or is it better when doing lower speed, higher thrust work, more like the 3D guys do?
3) Does the engine like to unload once in the air?
4) Just what exactly constitutes acceptable vertical performance and an acceptable speed envelope. Each individual will tend to have his own preferences for each of his models.
I recommend you buy a set of props in the size ranges above and just try them out. It's easy to get mired deeply into theories about which one will work best but at the end of the day, just going to the field with a range of props and trying them out can reveal many surprises and perhaps bust a few myths.
Start with a 12x6 and try other stuff out. Let us know how it goes.
My Feedback: (21)
I submit that you won't be happy with the performance of the Magnum .61 FS....
no matter what prop you put on it. In my original post I thought () we were
talking about the .61 Magnum two cycle....( my bad )....
....put more motor in it.
FBD.
FBD.
Using ThrustHP
12x6 @ 10000, 6.2 thrust, 57 mph
13x5 @ 9500, 7.7 thrust, 45 mph
11x7 @ 10500, 4.8 thrust, 70 mph
My brother has a magnum 61 four stroke. Using 15% nitro he gets a little over 10000 with a 12x6. I'm guessing the +/- 500 rpm going to the other sizes.
My Feedback: (21)
....thank you carrellh ....
....I don't have any fancy charts, programs....or "Theorycrafting"....
....what ever that is.
Your examples:
Using ThrustHP
11x7 @ 10500, 4.8 thrust, 70 mph ....
....this averages out to 57.3 MPH, which is....in a word....pathetic. []
FBD.
Your examples:
Using ThrustHP
FBD.
Theorycrafting: The process of tossing around arcane calculations based on real or imagined assumptions, often resulting in conclusions that are erroneous or contrary to those observed in actual tests.
Here's a good example:
ORIGINAL: Flyboy Dave
Your examples:
Using ThrustHP
FBD.
Your examples:
Using ThrustHP
FBD.
My Feedback: (21)
http://www.google.com/search?hl=en&q...=Google+Search
Hey, Harry....I didn't give the silly example of "Theorycrafting"....
....You don't have a Magnum .61, do you ?
Hey Dave,
So you think an aircraft with a 12x6, pulling 10k on the ground, will do no more than 57 mph, do you?
I just want to confirm this before my next post...
My Feedback: (21)
[quote]ORIGINAL: Flyboy Dave
/quote]
....I didn't hink so.
CA
Yeah, the 61 RFS is not a speed demon motor by any stretch of the imagination. My spitfire is not fast but it certainly is cool.
In the end I think it will end up with an old OS 61 SF I have laying around not doing anything. This is what I used in the first one of these I had.
My Feedback: (21)
....I hear ya' on the power thing. I have a couple Magnum .52's, and they are sweet
runners for sure, but not very powerful....the 61's don't make noticeably more power
than the 52's....in fact the same 12-6 prop is used. Now, my buddy had a .61 in an
40 sized Ultimate bipe, and he pulled the engine out after a few flights because the
darned thing just didn't have enough power. []
The biggest complaint was the plane would lose altitude like mad in a turn from lack
of speed and power. He put a K&B .61 two stroke in it, and it was fine. I was going to
trade my .52's and get .61's....but the slightly larger engine just doesn't make any more
power.
Now, I do run a YS .63 foustroke....and it made a difference by going from a 12-6 to an
11-8 prop, but that is a horse of a different color....and it runs on 20% nitro.
The little Magnum four strokes are really good running engines....but sadly, they just
don't make much power.
I don't have or use a prop calculator....but 10 thousand RPM on a 6" pitch prop would
probably be about 60 MPH or so....I don't know....it certainly would not be very fast.
FBD.
power.
FBD.
MI
Master Airscrew Classic 12.5x5. It will be the right load for the engine @ 10500 rpm, looks great, and fly scale speed at about 50 mph. For your Zero, you want the prop diameter to be large enough to extend past the cowl and blast enough air.
Richard L has the same airplane with YS 63 w/ Graupner 12x7 @ 12000 rpm, and it flies so fast it's hard to imagine it's a real airplane.
MI
ORIGINAL: DaveInLA
Thrust is proportional to RPM^2
Thrust is proportional to Diameter^3
Thrust is proportional to Pitch^1
Thrust is proportional to Chord^1
Speed is proportional to Pitch^1
Speed is proportional to RPM^1
However, you can't have it all, since for a given engine:
If you go up 1" in diameter, you need to reduce pitch by 2" to maintain the same RPM
The best thing to do is to find the rpm that yields peak power, and prop to allow engine to peak at that RPM.
Magnum 60 4-stroke is a good engine that's also pretty light. I think its peak power is about 10500~11000 rpm.
I don't have this engine, but based on my experience with other engines in this size range, I estimate the 12.5x5 will peak at 10500. It should give about 6.5 lb. of thrust, based on the thrust measurement I've done on similar size props.
The ThrustHP calculator has an error which assumes thrust to be proportional to Diameter^4, but does not account for pitch. chord, or profile. The only thing the ThrustHP does correctly for is speed, which you can easily calculate by hand:
10500 rev/min x 5"/rev x ft/12" x mile/5280inch x 60min/hour = 49.7159 mile/hour, about 50 MPH.
If you want the airspeed to be faster, figure out what MPH you want, and back calculate the RPM and pitch you need. Based on the RPM and pitch required, estimate what diameter you need to drop to to achieve the RPM.
CA
57 mph might be "pathetic" to sport fliers, but it's certainly more than scale, and that's good enough for me. I'll try 12x6 first and see how that goes.
Anyway, re: the 12.5x5 prop putting out 6.5 lbs thrust, I know that's all just theory, but wouldn't that mean that theoretically, this engine and that prop would be able to hover this plane?
MI
ORIGINAL: DaveInLA
APC 13x4W @ 11000 rpm = 7.5 lb
Anyway, if the thrust is the same as your weight, you can get to a point of hover, but you will need more to pull out. This little Zero won't hover too well even if you have 2:1 thrust to weight ratio. The key to hovering well is to maintain in hover heading, and you will need very strong pitch and yaw authority. Yaw authority is something warbirds lack.
The 12x6 will be a good choice. I recommend the 12.5x5 MA Classic more because of the look, something that might matter to you.
http://www.masterairscrew.com/index....PROD&ProdID=29
My Feedback: (14)
ORIGINAL: DaveInLA
Keep in mind that the projected airspeeds that folks have mentioned usually do not take into account the "slippage" that occurs in the real world.
Grabbing a number out of the air, that has worked fairly well in the past, we usually (we being my flying buddies and myself) used to factor in fifteen percent slippage when using the purely mathematically derived and projected airspeed. So, one would take the airspeed and multiply it by .85 (this deducts the slippage of minus 15%), providing us with a more realistic projected airspeed. Now you would be closer to 40 mph. Keeping in mind that most warbirds/sport models stall at between 25 and 35 mph, you can see that you only have a very small amount of wiggle room at WOT when running 6" of pitch, at its best.
This is why I agree with Submikester that a 10x8 or 11x7 will give you the necessary wiggle room to keep flying under high G turns, etc.
If you are a really slick pilot (I have no way of knowing), you can mess around just above stall with judicious and minimally applied amounts of rudder for turning near the stall point. But if you are the typical "Yank and Bank" R/Cer, you will promptly stall the model and spiral dive into the ground.
It is early and I'm not quite awake, so pardon me if I'm being too blunt.
Ed Cregger
