OS .61 FX OR Saito .91 - Kadet Senior
#53
RE: OS .61 FX OR Saito .91 - Kadet Senior
Once again,
This is a .29-.40 plane.
The [link=http://sigmfg.com/cgi-bin/dpsmart.exe/ProductsV5.html?L+Sig+mvuh5392+_Ddp_5fSearch1_02a0 1RCSigKadetSenior_01Search_02Index_01SubMenu_02Non e_01Menu_02CatProd_01Thumb_02Kits_20_2d_20Trainers _01]Kadet[/link] doesn't fly nicely with too strong an engine.
#55
My Feedback: (14)
ORIGINAL: whatwheel
Just read an old post about a kadet senior with a .91 4 stroke for power, I got a older sig kit from a sale and the only small engine I have is a older enya 40 ss. that Idont think is going to hack it.
The next smallest I have is a .91 4 stroke, how are the guys with the .91 s. using the 14,15 low pitch props and still have ground clearance? I have a trike. gear. Thanks for any help.
Glenn.
Glenn.
My RJL/HP .49VT rotary drum four-stroke engine flew the kit built Kadet Senior with ease. I'm willing to bet that your Enya .40SS will pull a big prop at a higher rpm than my .49VT. In the end, that's all that matters.
Ed Cregger
#56
My Feedback: (16)
I've never seen one with a prop bigger than 12". They just used more pitch with the big engines.
I've seen more Kadet Seniors with 61 size 2 stroke engines than any other size. Beside the one with the 35 FP, a guy at another field had one with a Saito 80. It was real nice power wise.
#61
I've got some tall gear on the plane so the 15 inch blade has plenty of clearance. I think that the OS .91 4-stroke with this prop is THE BEST combination for this plane. My opinion, but, I feel that it does fly very nicely Dar. Not arguing, just saying that it is probably one of the BEST flying planes I've got. I did modify the wing for a little more wing surface but not much. Weight has never been an issue.
