os 70 surpass II
os 70 surpass II
I am looking for help with my OS 70 Surpass II. It Idles like a champ and will go to full throttle with no problem on the ground. The problem arises in flight when I go to full throttle for any length of time it starts to bog or sputter and genuinly sound like it is going to die. If I throttle back to 3/4 or less it runs just fine. It is in a cub at the moment and I don't use full throttle very often with that plane except during touch and goes and take off climb. Could it be over heating? I am using 10% nitro with 18% lubrication. Any help would be appreciated.
Scott
Moderator changed 71 to 70 in two places.
Scott
RE: os 71 surpass II
I think it's overpropped. 13-6 (or equiv) is about right for this engine. 10-15% nitro is all this engine needs, and the 18% oil seems to be about right. I've been using the OS70's since they first appeared on the market, and have seen this sort of behaviour when the motor has a little more prop than it can deal with.
CA
Well, I've been flying mine since the beginning of the year in a Venus 40 with a 14x6 master airscrew prop and 15% powermaster. It runs like a champ and pulls the Venus straight up for ever - seriously. I'm quite surprised at the performance as it is on par with my 91s with the same prop.
Regarding your problems - check the valves to ensure they are not out of whack - also ensure that there is no foaming of your fuel happening. If that happens it could cause a lean condition also causing you to over heat. Lastly - I doubt it is the problem since you say it runs fine on the ground but for good measure check the timing.
My Feedback: (14)
ORIGINAL: naval flight officer
I am looking for help with my OS 71 Surpass II. It Idles like a champ and will go to full throttle with no problem on the ground. The problem arises in flight when I go to full throttle for any length of time it starts to bog or sputter and genuinly sound like it is going to die. If I throttle back to 3/4 or less it runs just fine. It is in a cub at the moment and I don't use full throttle very often with that plane except during touch and goes and take off climb. Could it be over heating? I am using 10% nitro with 18% lubrication. Any help would be appreciated.
Scott
Scott
Have you tried richening the high speed needle to see if that helps? Yeah, stupid question - but I have to ask. <G>
Assuming that you have tried the above with no relief, the first thing that I would check for is a kink in either the fuel or the fuel tank vent line. Air has to get in to let the fuel get out. A kink in either will limit the amount of fuel available for running.
Next, check the spraybar in the carburetor for blockages. I had a piece (long thread) of nylon from a Hayes fuel tank get into the carb of my engine at a pattern contest. I couldn't raise the throttle above half throttle without the engine threatening to quit and I couldn't find the problem during the contest. Obviously, I did find the problem when I got home, but it nearly cost me a contest.
Have you changed the glow plug? Yep, sometimes a less than perfect glow plug can manifest itself in such a fashion. Not often, but sometimes. Good luck finding the solution.
Ed Cregger
I will check on the kink and the debri in the intake. I changed glow plugs on Sat. to see if that would help to no effect.
I have it running much better now. I removed all of the exess fuel tubeing so that the lines are as short as possible and it runs much much smoother now. Still bogs a bit during throttle increases but runs at a constant rpm at high speeds. Thank you all for your imput.
LA
NFO? Jim AFFO [8D]
