ST carb. jammed
AL
ST carb. jammed
Was flying my Revolver mon. when the throttle stuck wide open. When the fuel ran out and I got it on the ground I found the barrel in the carb stuck solid even stripped the servo.i had to drive it out,there was a burr that I have no clue how it got there,it was fine before I took off,and during break in,smooth as any.Has anybody had this happen?
RE: ST carb. jammed
This is a common problem with most ST engines. I learn that several years ago. I soon as I get one, I remove the set screw that keeps the barrel aligned and remove the barrel also and make the end of that scre more round and smooth along with the guide that is cut into the barrel. I flew a giant stinger for 20 minutes stuck wide open on a 3250 once Same on as G90. Other than that, great engines
AL
RE: ST carb. jammed
It was smooth as a baby's but before take off,so the theory off screw backing out may be right.........but it seemed to be in place so I don't know.As close of tolerance as it is any kind of burr would lock it up.
RE: ST carb. jammed
The tigres I had, were a bit lacking in deburring the very hard drum. This caused a small burr on the locking screw. This burr caused the drum to lock up. Cleaning and deburring the slot in the drum always cured the problem for good.
