OS 120 ax "F" plug?
RE: OS 120 ax "F" plug?
ORIGINAL: earl williams
Has any one tried an F plug in the 120 ax? I remember it helping the mid range in the OS 160fx I had a few years ago.
G'day Earl,
The Type "F" glug is a hot plug, & if you use nitro in your fuel, it will cause preignition, & could damage your engine, go with a #8 OS plug, it is a medium plug.
Also if your 120AX is not run in properly, it will have mixture issues.
I like the OS-F better than the OS8. IMO the 8 is too cold and maybe good for smaller twostrokes operating at a much higher rpm. These big twostrokes work in the same rpm band as fourstroke and benefit from a hotter plug like OSF, Enya3 .......it ables you to run the engine slightly rich and still gives smoother midrange.
ORIGINAL: Flyer95
G'day Mate,
You will notice, I mentioned nitro, if you run FAI fuel, no nitro, then the Type "F" plug is good, RPM has nothing to do with glow plug heat range, the amount of nitomethane is what governs a plugs heat range, more nitro "Colder" plug, 0 to 5% warm plug, like a A3 or Type "F", 10% & up to 20%, cooler plug, like a OS #8, above 20% maybe a A5.
Nowadays I run 10% nitro and 20% oil in everything I have. The OS-F gives very low idle on 2 or 4-stroke engines and as soon as you move the stick the engine has instant throttle response, just like a fourstroke engine.
With the OSF the engine becomes less finicky to setup and more reliable, also perfect for cold weather. OS8 is a more durable plug for running high nitro or high rpm. I did run OS8 in many of my twostrokes for a few years so I am not saying it will not work, but the OSF is simply better for the bigger 2-stroke engines. The only important thing is to set the main needle slightly rich.
