OS 46AX - Tower 46 GASKET compatibility
I need to change the back cover O ring and head shim of my old & damaged 46ax.
as the original gasket set for 46ax is about 7.30$ where as tower 46 gasket set is 1.8$.
are these sets compatible with each other?
RE: OS 46AX - Tower 46 GASKET compatibility
My Magnum 52 uses a gasket instead of an o-ring on the back cover and I guess the Magnum 46 is the same. Why bother? it`s only 5.5$ you know
Oooops, I thought you referred to the Magnum 46 and now I see you meant the Tower 46, but still, why bother?
