ASP/MAGNUM FS400AR Rebuild/Overhaul
Reply
Old 06-21-2010, 06:40 PM
  #226
Kmot
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: ASP/MAGNUM FS400AR Rebuild/Overhaul
Thank you very much Doc Marvin!!
Kmot is offline
Old 06-21-2010, 06:45 PM
  #227
summerwind
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i'm waiting in hopes of the OS 7 cycl someday, but this thread has been the most interesting i've read yet.
Kmot, you are my hero.......beautiful work on this engine
summerwind is offline
Old 06-21-2010, 07:45 PM
  #228
Kmot
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you summerwind!
Kmot is offline
Old 06-22-2010, 02:13 AM
  #229
Radial power
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: MarvinE255
Kmot , I finally tried the OS FR%-300 carb on the asp 400. It is not a plug and play swap. Here are the #
Os carb barrel ID .2750 ASP .2775
OD of rt. angle ASP carb mount .3930 ID of the OS carb .3440 above the o-ring.
All the screw holes line up and are even the same tread and length. The os spacer is identical to the ASP spacer. There might be a slight interference between the OS throttle stop screw and the right angle housing be this can easily be solved. It boils down to needing to enlarge the OS carb case bore about .050. This would probably destroy the o-ring groove on the OS carb. Perhaps .025 off the right angle adaptor and .025 out of the carb. bore. May try this soon and let you know. The other alternative is to see if the carb mount off the FR%-300 would mount right up. I will research this and see what I can find.
Well, at least the .3440" measure more or less match with the 9mm I took on my OS in the other thread
Radial.
Radial power is offline
Old 06-22-2010, 10:34 AM
  #230
Kmot
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Close enough for gub'mint work!
Kmot is offline
Old 06-26-2010, 06:35 PM
  #231
Kmot
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I wanted to show off my new glow plug harness.
The stock plug wires have a rubber boot that starts to split and eventually come apart into pieces. The spring mechanism for attaching to the glow plug is a cheaply constructed affair and the brass tube frequently collapses. I suppose this would not be an issue if you attached the plug harness and boot one time and then left it for eternity. But I put mine on and take it off every run. So they have started to fall apart.
The OS harness is a nice looking, well made item. But it will only fit an OS glow plug stem. I am currently using Fox plugs and needed a good harness that would fit the Fox plugs as well as any other including OS.
I made a harness today. It works great. The collars lock onto the plug stem with a set screw. I soldered the other ends of the wires into a 3.5mm gold plug which is a perfect fit for the Microsens connector.
It's pretty slick if I do say so myself. [8D]
ID:	1458761   Click image for larger version
ID:	1458762   Click image for larger version
ID:	1458763   Click image for larger version
Kmot is offline
Old 06-26-2010, 09:10 PM
  #232
Dad_Roman
Dad_Roman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What did you use? wheel collars?
Pretty good lookin rig!
Dad_Roman is offline
Old 06-26-2010, 10:26 PM
  #233
Kmot
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, wheel collars.
Kmot is offline
Old 06-27-2010, 10:54 PM
  #234
Jazzy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice job Tom! I love that trick! I'm not sure why people don't believe it works so well...
You know, a coating of liquid wire insulation would help to insulate the outside of the collars as well as give them a 'finished' professional look.
I think I managed to slip some heat shrink over the whole collar and just poked a hole on one side for the plug. The allen wrench for the set screw just poked right through.
Either way looks good!
Jeff
Jazzy is offline
Old 06-27-2010, 11:22 PM
  #235
Kmot
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jeff, got a pic or two of your version?
Kmot is offline
Old 06-28-2010, 07:53 PM
  #236
Jazzy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No, sorry. I'm over a thousand miles away from my RC gear I haven't enjoyed my favorite hobby in a couple years but seeing these images and talking about modifications and craftsmanship brings forth great memories! Hopefully I won't have to wait too terribly much longer for that wonderful smell of burning exhaust gases and the sound of engines roaring to life...
Jazzy is offline
Old 07-23-2010, 05:55 PM
  #237
Carosel43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i have a quick question about the bearing in the master conrod. i have the sc version of this engine and its in bits as the bearings are dead after about 10 tanks of fuel (they are all cheap unbranded bearings in mine) anyway in your engine is there any play in the master rod needle bearing and if not how do i get the old one out? many thanks
Carosel43 is offline
Old 07-23-2010, 07:03 PM
  #238
Kmot
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There is no play in the caged needle bearing. It should fit over the crank journal and not rock back and forth.
You need a small arbor press to push the old bearing out and the new bearing in.
In lieu of that, you could get creative with some wrench sockets and a bench vise.
http://www.amazon.com/Arbor-Press-1-Ton/dp/B00077KLIW
Kmot is offline
Old 07-23-2010, 07:55 PM
  #239
w8ye
Moderator
w8ye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I bought a press identical to that one at the local junk store for $24.95. It was new and made in China. It has worked very well on model engines.
w8ye is offline
Old 07-24-2010, 01:06 PM
  #240
Carosel43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for that, i have at least .6mm play in the bearing and that means you can turn the prop 5 or 6 degrees without it moving the pistons, pretty bad. also both crankshaft bearings are in a poor state and it looks like the front one has been spinning in its housing but its hard to tell, either way its a shame, at least my link pins are ok!
Old 07-24-2010, 01:47 PM
  #241
Carosel43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
got the bearing out and found the problem, its shattered, cracks both round it and along it, see image (sorry the flash is so bright)
Old 08-08-2010, 07:37 PM
  #242
jmmt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Kmot
Guess what.
Your thread inspired me to buy my first radial.
Here you have a picture.
Regards
ID:	1481097   Click image for larger version
ID:	1481098   Click image for larger version
jmmt is offline
Old 08-08-2010, 11:33 PM
  #243
Kmot
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Carosel43
Yikes! [X(]
I wonder how that happened?
jmmt: Congratulations on your new radial engine! [sm=thumbup.gif]
Kmot is offline
Old 08-09-2010, 04:31 PM
  #244
Dad_Roman
Dad_Roman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Kmot
Quote:
ORIGINAL: Carosel43
Yikes! [X(]
Im going to spread it around and see if we can find out what happened.....
jmmt....niiiiice!!!
Old 08-10-2010, 05:21 PM
  #245
Kmot
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A little update to my custom FS-400.
I made a brass badge, to replace the stock ASP badge. But I was really skeptical about trying to put some writing in it myself, and I also thought it too small and thin for standard engraving.
Doing some research on the internet, I learned there is a new method (to me anyway) called "laser engraving". And a laser engraver can do letters incredibly small. So small that you would need a jeweler's loupe to read them.
Well I found a local business that does laser engraving, and I contacted them. I have a logo I designed for myself back in the 80's. I have even had the logo made into stickers for fun. So I inquired if my logo could be copied and then engraved onto my brass tag. Well, the answer was yes, and no. Can't do color, and the image I had needed to be turned into something called "vector line art". Buggha!
Well, I futzed around with my image using Photoshop and eventually got the color removed and something that I thought might be usable. But one was a jpeg, and one was a png. All I could figure out. Never could figure out what vector line art was. Anyway, I put it on a CD and then went to the laser engraver's shop with it and the brass tag. They were able to celan up the image, smooth it out, etc and make a vector line thing that they could use. Sweet!
So I had them engrave the tag. It looks great! Can't make the letters black, but they stand out well enough. The holes got elongated and my little screws were now too small. So I had some button heads that were a little bigger and able to work but I had to use the original tag as a spacer so there is a slight double line. But I think I can locate some 00 size washers and just use them later.
It's kind of neat to have a custom tag on my customized radial engine. [sm=thumbup.gif]
The website for the laser engraver, if anyone is interested:
http://byfridayengraving.com/
Pictures of the tag now on the engine:
Kmot is offline
Old 08-10-2010, 07:22 PM
  #246
Dad_Roman
Dad_Roman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tom...a thing of beauty my friend! That touch of red really sets it off!
Carousel.....I spread the word around and most of the feedback I have seen has been focused on poor hardening from the heat treating.
I would have to agree.
Old 08-10-2010, 10:09 PM
  #247
Aluminum Overcast
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Tom very nice work, as always.
Regarding the black letters: Try just brushing a little fuel proof paint on and then softly buffing with a cloth as it begins to dry. The paint will sink into the laser etching and the buffing will take it off the high spots. Voila, black letters and logo if you wish.
Aluminum Overcast is offline
Old 08-10-2010, 11:26 PM
  #248
Kmot
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the tip AO. I just might give that a try.
Kmot is offline
Old 08-11-2010, 04:54 PM
  #249
Carosel43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hi guys, sorry for my absence, been busy. anyway the saga of the SC400 continues, i gott the engine all fixed up with the new bearings, ran great no problems. i have put over a gallon through since the rebuild and have been checking bolts for tightness etc with no problems found, today however when flying at half throttle the engine stopped, and that is to say stoppeddead, witha bang, got the model down ok and stripped the engine (pic below) the bolt that holds the cap on the master rod needle bearing had fallen out, it, the brass cap, and the spring washer were then eaten by the engine damaging all of the conrods and destroying the bearing. the master rod and at least one of the other ones are beyond repair, i think i can polish out the damage to the others but would like some input from you guys, i will post pics of the other rods asap
Old 08-11-2010, 05:07 PM
  #250
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ouch [:@]
SJN is offline
Reply
Display Modes
