If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 14 of 128 FirstFirst ... 412131415162464114 ... LastLast
Results 326 to 350 of 3179
  1. #326
    Kmot's Avatar
    Join Date
    Jun 2003
    Northridge, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: ASP/MAGNUM FS400AR Rebuild/Overhaul
    Yes, you can run FAI fuel. It will just have a little less power, and might not idle as nice. But if you have glow plug heat on at low throttle it will still idle just fine.
    ~Tom~
  2. #327
    Join Date
    Sep 2010
    Branchburg, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just another quesiton. When Itook my engine for a checkup, I noticed some sludge around the bearing at the very nose of the engine. Ihad spread Mobil 1 Synthetic oil on the internals while it was not being run, and upon reassemblyI coated it again. Is using Synthetic motor oil bad for the internals of this engine? Does it sludge up, or only in certain conditions? Any help would be appreciated.
  3. #328
    Join Date
    Mar 2002
    Boynton Beach, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    What seems to be the best combination of on-board glow system, fuel, glow plug type and prop size that gives consistent in flight performance without dropping cylinders? Doc
    DOC
  4. #329
    Dad_Roman's Avatar
    Join Date
    May 2007
    Teague, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Since these are general questions more so than being specific to this engine I will try to help out.
    ORIGINAL: asp400oswankel
    I noticed some sludge around the bearing at the very nose of the engine. Im going to step out on a limb and say this is grease that it was prelubed with at the factory. If you hava run a lot of fuel through it then it might possibly be a build up of castor.
    Is using Synthetic motor oil bad for the internals of this engine? Bad? No. Doesnt hurt a thing. However, using Synth does not accomplish the protection you are trying to accomplish. Synth has great shear qualities (when engine is running) and great heat resistant qualities (as far as breaking down) but it has poor "wetting" qualities. (aka: "break free" properties) You can compare this to water running off, or beading up, on a waxed car. Synth does the same thing inside while the engine is at rest. This is where castor really shines, it has wonderful wetting properties, and if left for years, forms a hard water tight shell that protects your internals. These engines are usually called "gummed up" which is actually a good thing. Normally a heat gun and a tank of fuel restores the engine to its full glory.
    This is the protection you are looking for while inspecting and reassembling. For the proper lube/wetting qualities you need to switch to ATF. (Not the ford type though because it has grit in it. Use Dexron)
    Does it sludge up, or only in certain conditions? No, not in the way you are thinking (normal running) It can be burned up to a sludge but it takes so much heat your motor would be long since dead.
    Tom will be along with his thoughts shortly
    AMA# 134406
  5. #330
    Dad_Roman's Avatar
    Join Date
    May 2007
    Teague, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Im in the market for one of these for Christmas. (ASP or Magnum)
    They are on sale for 777 but if anyone has one they want to get rid of let me know
    Shane
    AMA# 134406
  6. #331
    Kmot's Avatar
    Join Date
    Jun 2003
    Northridge, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Personally, I would not use automotive engine oil in my model airplane engines. That's just my preference.
    Marvin, I have never flown my ASP400. I have only run it on an engine test stand. I use a Microsens glow driver and it works well. Never have dropped a cylinder with it connected. I use Powermaster 15% Sport Fuel, and a Master Airscrew wood 18x10 prop has run the best on my engine. With the Microsens connected, the engine will idle until I get bored with it.
    ~Tom~
  7. #332
    Join Date
    Sep 2010
    Branchburg, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Is there a charger included with the battery?
    I am in desperate need of an ignition system for my magnum radial, and heres what im planning to buy:
    1 X GLOW5LP
    1 X Battery LiPo DesirePower 1S/3P 3900 mAh 22C
    1X Ground cable
    1X GLOW BALANCER
    all for 151 Euro.
  8. #333
    Join Date
    Sep 2002
    Copenhagen, DENMARK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    For what it does, it is too expensive, but it works.
    For a fraction of the price, you could easily make a servo operated switch mixed on the throttle channel....just activate golw from 0-50% throttle.
    4 C size nimh batts in parrallel, and it will last for ages.
    Sonnich Johannesen
  9. #334
    Join Date
    Aug 2008
    Broome, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ok Guys. has any one thought about converting the engine to spark ignition. The ignition will be the biggeset pain.
    Right after a spectacular crash, the pilot yelled out \'\'Channel 35 clear!
  10. #335
    Join Date
    Sep 2010
    Branchburg, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Actually, yes I have thought of it. Ihave located 1/4 32 spark plugs:http://sparkplugs.morrisonandmarvin....ex.cfm?menu=v3
    And some sort or ignition module, good luck if you can figure out how it works (page includes 3,5,7,and 9 cylinder ignition modules): http://www.becker-fm.de/shop/group/Z...f_Sternmotoren
  11. #336
    Join Date
    Jan 2002
    Bennington, NE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    what would be the advantage of this?
  12. #337
    Join Date
    Nov 2006
    Townsville, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Ram-bro
    ..Welll...if you didn't already have enough headache trying to maintain and tune a 5 cyl. glow he figures you might like to try turning totally grey getting a non genuine spark system to work to work on a glow motor!!! LOL
  13. #338
    ZAGNUT's Avatar
    Join Date
    Feb 2003
    tel-aviv, ISRAEL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Ram-bro
    that the ignition timing no longer relies on a delicate balance between nitro content, needle setting, compression ratio and plug type.
    with spark ignition you could run on 0% nitro and get a lower and more reliable idle, better transition and (depending on the engine) maybe even more power.
    \"I\'ll take the money- and you can have the rope\"
  14. #339
    Join Date
    Aug 2008
    Broome, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I was thinking more along the line of better fuel consumption and a clean air frame and that low slow idle rumble.
    Yes the C/R will have to be lowered, 1 or 2 head shims.
    For the time being Id be using std Rexel ignition modules.
    Yes a bit more weight but I think it will be worth it..
    he plane its going into is a scale 30s mono so its a slow bird.
    Chop down 5 hall effect sensors and mount them on a ring on the crank...
    Still playing on the idea. as I have a few spare ignition floating around...
  15. #340
    Join Date
    Aug 2008
    Broome, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Setting the 5 hall sencors will be a pain..Nice to fit a scale dizzy. http://www.cncengines.com/snowengine.html
    Just have to find some head shims..Or make some. Will have to do a dummy set up..
  16. #341
    Join Date
    Aug 2008
    Broome, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ok guys,
    What sounds better.
    Exhaust ring, hand made from copper or the Keleo alloy made unit??
  17. #342
    Join Date
    Sep 2002
    Copenhagen, DENMARK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I doubt that the material which it is made from will change the sound.
    But changing the shape an dimensions will probably make a difference......
    Sonnich Johannesen
  18. #343
    Kmot's Avatar
    Join Date
    Jun 2003
    Northridge, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The MOKI radial engines have THE BEST sound of all current radials in my opinion. Notice that the MOKI engines have an enormous diameter exhaust ring in comparison to all the others out there.
    ~Tom~
  19. #344
    Join Date
    Jan 2002
    Carrollton, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have read somewhere that to get good sound from a Moki, the exhaust must not only be large, but ever expanding in size(diameter) from the exhaust port to the exit stack. It has something to do with slowing the gas flow down.
  20. #345
    Join Date
    Aug 2008
    Broome, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I wish I could afford a MOKI!! just for the sound..
  21. #346
    Join Date
    Aug 2008
    Broome, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I just remember in my younger days we used to fit a copper tail pipe on the Holden ute to give it some bark. the copper pipe resonated louder than the steel.
  22. #347
    Join Date
    Aug 2008
    Broome, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just been watching Kmot's #4 vid, Love the low idle..Oh and thanks for showing the fuel tank...Flying cost just for the fuel $12 a run!!!
    Know they drank the fuel, but not that fast..
  23. #348
    Join Date
    Sep 2010
    Branchburg, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ello gents..
    Just got my microsens glow driver and it works like a charm with the high quality leads they sell. I just have two questions if anyone can answer them. They are:
    What thread is the crankshaft of the FS400ar?
    Does anyone know of a clutch that would fit this crank? I've seen it done on other airplane engines but I have no experience with clutches whatsoever.
    Join Date
    Aug 2008
    Broome, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    No more run ups untill I finish the exhaust!!! Every thing covered in oil...
  25. #350
    Join Date
    Aug 2008
    Broome, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Any one droped the oil %? Reading in one of the Mags doing a review on the new OS 7 cly they were using 8-10% oil...It makes sense having a multi cyl basicaly having 5/7 cly blowing oil into the crank case
    The Mag Was Airbourne (Aust) # 235 12/2010 page 29
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
