If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 4 of 128 FirstFirst ... 234561454104 ... LastLast
Results 76 to 100 of 3179
  1. #76
    Kmot's Avatar
    Join Date
    Jun 2003
    Northridge, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: ASP/MAGNUM FS400AR Rebuild/Overhaul
    PM sent.
    ~Tom~
  2. #77
    The Raven's Avatar
    Join Date
    Jan 2005
    Melbourne, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Any chance I can pester for some polishing and painting tips? I have a Magnum 80 that needs some beautification.
  3. #78
    Kmot's Avatar
    Join Date
    Jun 2003
    Northridge, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Have a look inside this thread Raven, "jetpack" is a master of the art:
    http://www.rcuniverse.com/forum/m_7166817/tm.htm
    In this thread I give a 'sort of' tutorial:
    Click Here
    ~Tom~
  4. #79
    Join Date
    Sep 2002
    Copenhagen, DENMARK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey Tom, hows your 400 doing ?
    I just ran 5 liters through mine, and desided to take a look on the internals. Still on the ground......have not finished the plane yet.
    Looks like a battlefield in there, with all the crud, slime, and a few tiny metal particals
    My crank pins look alright, and are not damaged, and none of my C-clips have fallen off either
    Well, the engine starts, and runs great. Running 5 liters of fuel through it deffinatly has made it run smoother.
    My 20/8 prop seems too small. the engine accelereates like a dragster, so i guess it could use some more load.
    Im goung to get a 22/10 for my 400 and stearman.
    The power from this engine is awesome....way too much for my plane
    But thats a good thing i guess, as i can run it at lower rpm, where the engine sounds best.
    Im also ordereing the microsense 5 cylinder glow system.
    It does idle best with the power on the plugs.......but maybe it will improve when the engine has some more time on it.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1122432   Click image for larger version.
ID:	1122433   Click image for larger version.
ID:	1122434   Click image for larger version.
ID:	1122435   Click image for larger version.
ID:	1122437   Click image for larger version.
    Sonnich Johannesen
  5. #80
    Join Date
    Jan 2002
    Bennington, NE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Kmot , did n't realize you had this thread going.....some good info here
  6. #81
    Kmot's Avatar
    Join Date
    Jun 2003
    Northridge, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Sonny!
    Ya know, I get sidetracked on other projects and flit around like a bee from flower to flower, only I go from project to project. I have not gotten going on my radial rebuild since where I left off. In the meantime I have done 4 other engines including a customized Jett 120, and some airplanes and boats and latest a steam engine. I guess I have hobby ADD!
    Is that castor oil crud? Or rust in there? [X(]
    I just chopped the tip of my thumb off in a propeller accident, so I will not be working on anything for a while. But I do plan to get going on the FS400 radial project again later in this year.
    ~Tom~
  7. #82
    Join Date
    Jan 2002
    Bennington, NE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Kmot, I remember PMing you recently about finding a plane...waarbird suitable for the 400,. Well the Jack Devine Bearcat arrived and it is a perfect fit for the radial. I might do a build thread on this.......
  8. #83
    Join Date
    Sep 2002
    Copenhagen, DENMARK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    hehe....I know exactly what you mean about other projects
    Ouch...sorry to hear about your thumb [X(]
    There is always a risk when playing with our toys....
    The crud is caster and rust.
    The first times I ran the 400, It was on 5% nitro, and synth oil.
    Now, ages after, and bringing it out of storage, I bet it rusted up inside [:@]
    But the 5 liters i have run through it now had 5% nitro, 9% Castor and 9% E.D.L.
    But the bearings look fine...as much as I could see, and it still runs great
    Sonnich Johannesen
  9. #84
    Kmot's Avatar
    Join Date
    Jun 2003
    Northridge, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Good to know Sonny, I would hate to see your fine engine suffer from corrosion.
    Ram-bro: You are required to do a build thread on the Bearcat/ASP400 combo!!
    Yeah, my thumb. Wasn't an airplane, it was an airboat with a "safety cage" that forces your hand inside in an awkward way.
    ~Tom~
  10. #85
    Kmot's Avatar
    Join Date
    Jun 2003
    Northridge, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just a quick update, I am starting on the FS400 again and will finish overhauling it and rebuilding it.
    I just did the color buffing on the center section. I need to order some ball bearings for it. I will start on the crankshaft and connecting rods next.
    ~Tom~
  11. #86
    Join Date
    Nov 2006
    Townsville, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Great to see this rebuild still going! Awesome job !
  12. #87
    Join Date
    Oct 2006
    Amadora, PORTUGAL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Tom, you're the man!
    Club Saito member #632
    Once you hear the sound of a multicylinder 4-stroke, you\'\'ll be hooked forever!
  13. #88
    Join Date
    Jan 2002
    Bennington, NE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Kmot, ever consider setting up a business to run and service these engines? I would definietly send mine to you to have it run in and refurbed/upgraded as necessary?
  14. #89
    Join Date
    Sep 2002
    Copenhagen, DENMARK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Tom....looking good.
    I just ordered the Gilmore racer for my ASP 400
    I will never get the stearman flying, because its just too time consuming to transport and assemble at the field.....im too lazy for a bi-plane
    The gilmore has a 2 part wing, and the fuselage is shorter.....ideal fit, for my tiny european car
    I realy want to fly my radial, so I have to get this simple plane.
    The ASP realy sounds great in this video from France
    http://www.youtube.com/watch?v=u56HE...eature=related
    I have seen 1 german planes snap a wing in flight and crashing when flying realy fast with 50cc 2 stroke
    So throttle management, and sensible flying is the key.
    The manual:
    http://www.pitch.dk/pdf/BH62%20manual-Gilmore7[1].pdf
ID:	1434380   Click image for larger version.
ID:	1434381   Click image for larger version.
ID:	1434382   Click image for larger version.
ID:	1434383   Click image for larger version.
ID:	1434385   Click image for larger version.
    Sonnich Johannesen
  15. #90
    Kmot's Avatar
    Join Date
    Jun 2003
    Northridge, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Sonny,
    I love that video of the Gilmore in France! Nice perfect grass to fly from also, a golf course!
    OUCH! That crashed plane hurts! Everything in moderation!
    ~Tom~
  16. #91
    Kmot's Avatar
    Join Date
    Jun 2003
    Northridge, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Check this out!
    [youtube]http://www.youtube.com/watch?v=-1M6jS1SsUc[/youtube]
    ~Tom~
  17. #92
    Join Date
    Sep 2002
    Copenhagen, DENMARK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yea.....great sound too
    Sonnich Johannesen
  18. #93
    Kmot's Avatar
    Join Date
    Jun 2003
    Northridge, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I finished one head today. All heads have previously been polished, but just with the cutting compound. So now they need to be color buffed. Taking a tip from all the responses I got about my questions of cleaning up buffing residue, I washed the cylinder head in mineral spirits after color buffing it. I also had to use cotton swabs as well as mechanical means (Xacto) to get every last bit of compound residue out. For the most part, the solvent worked pretty good.
    The color buffing really makes the polishing pop out! Makes it look brighter than before.
    Here is what a head looks like before cleaning. Compound and buffing wheel fibers get jammed up inside the rocker box as well as in the valve ports, etc.
    Here is a head that is color buffed, and then hand polished with Liquid Luster brand metal polish, on the right. And the head on the left for comparison is one of the initial cutting compound buffed heads. Only four left to do.
    ~Tom~
  19. #94
    Kmot's Avatar
    Join Date
    Jun 2003
    Northridge, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Todays update: I used Q-tips and mineral spirits to clean the nooks and crannies of the nose section. I finished cleaning it and then hand polished it with Liquid Luster metal polish. And then I installed a new 10x26x8 chrome steel ball bearing I had on hand. I inspected all bearings today, and determined I only need to replace three of them. I have to order a rear main bearing and a caged needle bearing for the master rod.
    The nose section turned out pretty good.
    ~Tom~
  20. #95
    Dad_Roman's Avatar
    Join Date
    May 2007
    Teague, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thing of beauty!
    Good work Tom.
    AMA# 134406
  21. #96
    Join Date
    Oct 2006
    Amadora, PORTUGAL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Awesome work you have on that little radial Tom, can't wait to see it assembled. [8D]
  22. #97
    Kmot's Avatar
    Join Date
    Jun 2003
    Northridge, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks fella's.
    I ordered the bearings I needed last night, and in the meantime I will be finish polishing the other heads. Lots more other stuff needed to do as well.
    Now that I am in the rebuild mode and focused on this engine it should not be too long before it is back together, barring any unforeseen circumstances.
    ~Tom~
  23. #98
    Join Date
    Nov 2005
    MedellinAntioquia, COLOMBIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Tom good that you are on this project again!
    Love to see your pics!
    Jorge Andres Estrada
  24. #99
    Join Date
    Sep 2002
    Copenhagen, DENMARK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just opened up my ASP 400 today [:@][:'(]
    And it looks like the Titanic inside..........
    My counterweight is growing rusticals.
    It must be made of old chinese Lifan motorcycle parts that did not pass QC. [&o]
ID:	1435939   Click image for larger version.
    Sonnich Johannesen
  25. #100
    Join Date
    Mar 2003
    New York, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    After run oil
    ProBro #2077
    http://image2-0.rcuniverse.com/e1/forum/upfiles/57402/Nl29490.jpg
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
