ASP/MAGNUM FS400AR Rebuild/Overhaul
Reply
Old 09-21-2012, 04:12 AM
  #1101
Carosel43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: ASP/MAGNUM FS400AR Rebuild/Overhaul
i assumed as much but wanted to check :P
Carosel43 is offline
Old 09-21-2012, 08:33 AM
  #1102
Kmot
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, sorry. Fluid Ounces. The metric system is easier, but it takes genius's to use the archaic, convoluted ounces system.
j/k
Kmot is offline
Old 09-21-2012, 10:07 AM
  #1103
Carosel43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ha! if it takes genius's then why are americans using it? lol. Anyway, if i were you i would do as you suggest. im going to work it in metric as it makes more sense, but:
1 litre (1000ml) of fuel with 15% nitro and 18% oil gives
180ml of oil
150ml of nitro
670ml of methanol
if you double the methanol to 1340ml then you should be running 7.5% nitro and 9% oil.. sounds ok to me or do you want less oil?
or, give up, buy some klotz oil and some nitro and make it yourself :P
Old 09-21-2012, 12:53 PM
  #1104
SrTelemaster150
SrTelemaster150's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Kmot
Now, by my calculations, if I add 30 oz of pure methanol to the 16 oz of this Powermaster fuel, I will have:
46 oz of 7% oil by volume, fuel.
Which would be:
40.725 oz of methanol
2.875 oz of oil
2.4 oz of nitromethane
Does anyone see anything wrong with my math?
Your math works out to .0625, 6.3% oil. Pretty close.
Up the oil to 3.2 fl oz & reduce the methanol to 40.4. 3.2oz/46oz = .0695, 7% oil.
2.4oz/46oz = .052, 5% nitro
SrTelemaster150 is offline
Old 09-21-2012, 01:16 PM
  #1105
SrTelemaster150
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Carosel43
ha! if it takes genius's then why are americans using it? 1 litre (1000ml) of fuel with 15% nitro and 18% oil gives
180ml of oil
150ml of nitro
670ml of methanol
That's a question I've been asking everyone over on this side of the pond for years. Why didn't we convert to metric in 1972 like we had planned? I learned the metric system in 1968 during my senior year because we were supposed to convert.
Furthermore, being a pipefitter, it would make some aspects of my job much easier. For example, the wieght of 1 liter of water = 1 kilogram.
A pipe has an internal volume of 700,000cc, therefore it contains 700 liters of water. When considering the weight that the structure that I hang my pipe from must bear the weight (of the pipe + the water) all I need do is add 700 KG to the weight of the pipe. No calculator needed.
Now, W/the "Imperial" system, I must calculate cu in of volume, divide by 231, (cu in to gallons) then multiply by 8.35 (weight of a gallon of water) to get the weight of the water in the pipe.
Here we go, same pipe. 42,700 cu in/231 = 184.8484848484848484 gal X 8.35 = 1,543.48484848484848# Nothing to it, I did that all in my head, honest!
Old 09-21-2012, 04:47 PM
  #1106
Kmot
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
See? Genius!
Kmot is offline
Old 09-21-2012, 07:18 PM
  #1107
SrTelemaster150
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Kmot
See? Genius!
Tom, I just realized that my math was wrong. I'll recalculate & edit my post in RED.
3.2oz oil (3 1/4?)
40.4oz Methanol (40 1/2?)
2.4oz Nitro.(2 1/2?)
Rounding up to the nearest 1/4oz would yield 46 1/4 oz of 7% oil, 87.6% Meth, 5.4% Nitro.
Old 09-21-2012, 07:35 PM
  #1108
SrTelemaster150
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Delete double post.
Old 09-24-2012, 11:16 PM
  #1109
Reverend
Reverend's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gentlemen,
not much prgress here in Austria due to a business trip to Switzerland.
I have, however, picked up the new 50-80cc testbed. Its a well flown in Staufenbiel Stearman (known in the States as the Aeroworks Stearman). First test candidate will be the FS400.
My little helper immediatly fell in love with the pilot. I rather like the passenger and his opinion on female airmen (airwomen?!)...
Hope to put the engine in this week and fly her on the coming weekend.
If she proves to fly as well as the previous owner claims, I will recover her with oratex this winter and scale her up a bit. We will see. For now she has some work to do.
FS 400AR, FA-450R3 and the Laser 300V are waiting for aerial RPM tests [8D] Hope I find my telemetry stuff in my mess...
Rev
@Carousel, the race is on: lets see who brings his 400 in the air first [>:]
ID:	1804718   Click image for larger version
ID:	1804719   Click image for larger version
Reverend is offline
Old 09-24-2012, 11:28 PM
  #1110
Carosel43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ha! i might have you beaten rev as mine would have flown last weekend if it were not for this bloody glow driver battery problem! im currently looking at options to test and see if it is this battery. Also have you let your 'helper' loose with a model yet?
Old 09-25-2012, 03:42 AM
  #1111
SrTelemaster150
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Reverend
Gentlemen,
Rev
Hey Reverend, I'm using the same 2 pilots in my 1/5 scale CUB.
It looks like the student "Pamela" is giving "Goose" an anxiety attack W/her piloting skills!
Old 09-25-2012, 07:49 PM
  #1112
Reverend
Reverend's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, they are a great couple.
Well, engine is in. Me likey.
Only Problem was, that I had to turn it about 5° due to the holes in the firewall from the previous engine(s?).
Tonight the electrics and I am fit to go [8D]
Rev
Reverend is offline
Old 09-25-2012, 09:04 PM
  #1113
Kmot
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rev, that APC prop has got to go! On a classic Stearman it is begging for a prop that looks vintage.
Kmot is offline
Old 09-25-2012, 11:07 PM
  #1114
Reverend
Reverend's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Kmot
Roger that, sir. I have a 20x8 Menz that I will fit.
Reverend is offline
Old 09-25-2012, 11:15 PM
  #1115
Carosel43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
mine swings 21x8 menz at 6650rpm, gonna try it in flight but it might be the ticket for looks
Old 09-26-2012, 10:50 PM
  #1116
Reverend
Reverend's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Right, spent some more nightly hours on the Stearman.
1. I couldn't live with the engine 5° turned so I fixed it. Doubled up the firewall on the inside (what a cr** job...) and put it in dead straight. Makes a hell of a difference.
2. I hate small wheels on RC planes. I got out some literature and figured out how big the wheels would have to be in 1/5th scale. 6" (150mm) is the right size. Well look what I found in a box A pair of low bounce air filled 150mm wheels [8D]
3. Complete Glow electronics are in and workling. Throttle linkage is too and I had to fit a new tank as the last one had started giving up to natural decay
4. On special request the APC is gone...
All I have to do now ist rig her up, programm the radio, check CG and we are ready for (re-)maiden.
Rev
Reverend is offline
Old 09-26-2012, 11:34 PM
  #1117
Carosel43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
whoaa crap, i best get mine in the air this weekend! however with my dead glow battery its not likely
Old 09-26-2012, 11:47 PM
  #1118
Reverend
Reverend's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have 2 x 3.300 1S and 2 x 4.900 1S for glow batteries. Usually I go through at least three on an intense flying day. Especially if I have problems starting an engine
Reverend is offline
Old 09-27-2012, 05:54 AM
  #1119
Carosel43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mine was a pair of 3300mah NiMh cells in parallel. They came with the 3 pot glow unit i have for the saito 450 (which i dont need as it runs well without it) so i may have asked to much from the cells driving 5 plugs. Also i found it was almost impossible to charge as it would never delta peak. As a result i think i might have over charged it once or twice
Old 09-27-2012, 07:48 AM
  #1120
Kmot
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks very good now!
Kmot is offline
Old 09-27-2012, 08:39 PM
  #1121
wherewaldo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey guys
i flew my t28 today with the asp 400 ... sounded nice and all but i was disappointed with the performance!
brought the plane in for a landing because i couldn't get enough height for a roll!
I checked the cylinders and one of them was cool..it was  running on 4
I have a sonic on board glow system 4.8 volt  ..4000 nimh battery...the battery read 5.27 under load ...When i checked it after the flight which lasted all of 5 min!
it read 4.67....will the lack of battery power effect the engine from firing all 5 cylinders at high rpm  ,,because i had no real power...this plane has better performance with a 45 cc gas engine!
Does anyone have any ideas why the lack of performance  ..The plane weighs 26lbs
and where can i get a battery that lasts longer than ! flight
suggestions appreciated, thanks
wherewaldo is offline
Old 09-27-2012, 10:48 PM
  #1122
Reverend
Reverend's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: wherewaldo
hey guys
On 4 Cylinders the ASP Lacks about 40% Power imho. The question is what Glow Driver you have. I am using a Glow5LP Boost and I can boost the glow power for a couple of seconds if I have the feeling one Cylinder is down by moving the stick to WOT and back quickly. Works well.
Depending on your needle setting it is possible that one of your plugs (usually one of the bottom two) is being drowned. Possibly to an extent, where the glow driver canot do its job on that plug.
Is the engine running well on the ground? If not, try to connect a normal 1,2V Pb Battery (about 10Ah) and leave it on all the time. Will the engine run fine now?
What tach readings are you getting?
Rev
Reverend is offline
Old 09-27-2012, 10:53 PM
  #1123
Reverend
Reverend's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It is done. All rigged up, balanced and ready to go. I did not connect the flying wires for the CG test but they will be on or flying.
I really hope this baby flies well because I would love to redo the Stearman in a nice Oratex covering.
Re-Maiden planned for tomorrow morning. Weather looks passable.
Reverend is offline
Old 09-27-2012, 11:58 PM
  #1124
Carosel43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi waldo, if you were a pot down im not suprised you lacked performance. I lost a cylinder on takeoff once and it did sap the engines power big time. The thing i dont understand is why your glow driver went flat so fast, are you running glow power to the plugs all the time? if so then why? the other issue is that the model is pretty heavy so that could be part of it. Also we can get into what prop you had and all the rest of it. In fairness though i think the lost cylinder was the major issue and once above about 2000rpm mine will not drop cylinders, its only a low rpm they go out
Old 09-28-2012, 12:00 AM
  #1125
Carosel43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
oh and rev, she looks ace! i have been working on my P39 as i cant do anything with the 400 right now. I may order a new glow driver but they are £80. as my sea fury has been delayed again (sigh) i might just buy a better driver as my current one is a bit of a bodge
Reply
Display Modes
