ASP/MAGNUM FS400AR Rebuild/Overhaul
Reply
Old 10-02-2012, 11:39 PM
  #1201
Carosel43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: ASP/MAGNUM FS400AR Rebuild/Overhaul
oh, and regarding clips i reused the old ones on my engine and when test running it after the rebuild i ran it up to 8200rpm to really give it a blast and nothing fell off. i have since flown it 3 times and had quite a bit of ground running. When i removed the clips i was very careful and upon replacement they were not loose or anything. heres hopeing im ok!
Carosel43 is offline
Old 10-03-2012, 07:00 AM
  #1202
Kmot
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I concur with everything you said Phillip.
If someone is comfortable with disassembling their engine then I agree it is worth a look inside when brand new to check for swarf, and in the case of the FS400 to maybe change the e-clips.
Let us not forget however, that the original impetus for this thread was that one of my link pins failed, not the e-clip. A shoulder broke away on one of the link pins, and the clip was still attached.
So, for anyone contemplating changing the e-clips on their new engine, just use caution when pryinig them off so that you do not snap a shoulder off of the link pin. [X(]
Kmot is offline
Old 10-03-2012, 07:06 AM
  #1203
Kmot
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
BTW: Olivier Rogeau has created a series of videos that shows the disassembly of the FS400. It is in French language but the images are what matters:
Here is Part 1, and then you can look for parts 2-17 as you go along:
http://www.youtube.com/watch?v=IzOqBrbWPEA&feature=plcp
Kmot is offline
Old 10-03-2012, 08:55 AM
  #1204
retransit
retransit's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I looked at all the videos. One thing I didn't see was the disassembly of the e-clips from the link pins.
Bob
retransit is offline
Old 10-03-2012, 09:00 AM
  #1205
Kmot
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
lol!!!
Kmot is offline
Old 10-03-2012, 08:15 PM
  #1206
Kmot
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I installed the new C-E-Circlips-Rotor Clips-Retaining Rings tonight.
I do not have a special tool, so I used a combination of a seal hook and a ball head socket screw driver. Three of the e-clips came off fairly easily. But one was a bit*h to get off. My hook kept slipping under pressure and I made a lot of scratch marks on the master rod. They look bad but are superficial and of no consequence. There is no way 3.3 or even 7 lbs is going to toss these clips!
I did notice that the old clips were slightly stretched. But then, these have been installed, removed, installed, and finally removed again.
Interestingly, from the photo's posted in this thread, not all clips used by Sanye are the same. Some clips from Sanye, are black phosphate coated. Some clips, like mine, look like they are stainless steel. I ordered black phosphate coated clips as replacements.
Well, I feel like it was a worthwhile preventative maintenance to perform. Thanks to Rev77 and his insight. Although, Phillip, I did not recall that you had lots of local fellows having their clips fall off. [X(]
The weather in my area has been brutally hot, for what seems like months now. We are supposed to finally get some cooling over the next few days and I hope to get my FS400 mounted and tested with the new Rogeau Intake Manifold (RIM) during this time.
My wife loves it when I work on the dining table.
The motor opened up, the stock clips stayed in place during all those video taped runs a couple of years ago:
This clip was a beeee-yatch!! [:@]
The tools:
Old and new e-clips:
Old clip is now slightly stretched:
Kmot is offline
Old 10-03-2012, 08:53 PM
  #1207
jmmt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
KMot
Do you prefer the Black-finish steel rings than the Stainless steel rings (from McMaster)? which one is stronger or which do you recommend?.
jmmt is offline
Old 10-03-2012, 10:10 PM
  #1208
frets24
frets24's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Kmot
LMAO!!!
I had been given grief over that same thing for years. Then came the day that the head on her car's engine needed to be rebuilt. Coldest, windiest, wettest winter we've had for years and the shop/shed just would not get, nor stay warm. I told her I would do the messiest parts out there but when it came time for assembly I was going to throw a blanket and a board on the kitchen table. All went well, the car ran great and it was only a few days days instead of weeks that she had to drive one of "the land yachts" which she hates to drive.(my Explorer or one of the boys' Jeeps)
She was happy, I was happy and not a word since when I cover up the dining table and "play tools and stuff" or build.
frets24 is offline
Old 10-03-2012, 11:20 PM
  #1209
Kmot
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
jmmt: Technically, stainless steel is not quite as strong as plain steel. But I would not have any qualms about using SS inside the engine. I bought the black ones because it came in a order of 100 pieces versus the SS which was double the price and 1/4 as many pieces.
Kmot is offline
Old 10-03-2012, 11:41 PM
  #1210
Carosel43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking at the photos of my engine on page 10 (when it killed itself) mine are stainless i think. And im sure i gave them a little squese to remove the stretch. time will tell
Old 10-03-2012, 11:42 PM
  #1211
Reverend
Reverend's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
To be honest, the new black clips even LOOK tougher...
Anyways, I had 40 Minutes last night so I started piecing the engine together again. Three cylinders are on, two to go.
fwiw, If you are not a friend of decorative tatoos on your main conrod, you can use two wooden chopsticks to push the clips off. The sandblasted aluminium surface really scratches very easily.
Rev
Reverend is offline
Old 10-03-2012, 11:59 PM
  #1212
Reverend
Reverend's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Kmot
Tom,
I know of at least four engines here in austria where one of these clips has come off on engines that had not been opened. All of them where SS btw. I still think that they are of inferior quality and if not enough care is taken assembling them, they will be so stressed that they may not be up to the job anymore.
Lets be honest, these Engines are not being assembled with tlc by engine specialists/enthusiasts as for example is done at AGC with the Laser engines but by some underpayed chinese bloke or girl who probably doesn't even know (or care) what this chunk of metal is for and is doing so for 12 hours a day.
To be honest, at the end of the day I would probably be yelling "zhū" at every ring while hammering it in with a large blunt mallet...
Rev
Reverend is offline
Old 10-04-2012, 05:55 AM
  #1213
retransit
retransit's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tom, good pics showing the dimentional disparity of the stock vs. replacement e-clips.
I have a question about the intake gaskets. Since things do not always go well when I attempt them, what material would you use to replace intake gaskets that may be ripped or torn upon disassembly?
Bob
Old 10-04-2012, 06:23 AM
  #1214
Reverend
Reverend's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Right, to prove I am not just hot air (well at least not all the time) my club prez Klaus Heiss (thanks Klaus!) has sent me the pictures he took.
Stearman airborne with the 400
Yes tom, I know... the Prop. Wanted to test the APC as well and that was the flight that was put on ccd...
ID:	1807751   Click image for larger version
ID:	1807752   Click image for larger version
Reverend is offline
Old 10-04-2012, 07:13 AM
  #1215
retransit
retransit's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Love your cap to keep the prop wash out of your hair.
Bpb
Old 10-04-2012, 07:35 AM
  #1216
retransit
retransit's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I haven't tested any props, but this one is my favorite for looks.
Bob
Old 10-04-2012, 07:49 AM
  #1217
Kmot
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Phillip, love the cap and goggles!
Bob, at your LHS or online you can buy small pieces of green gasket paper sold by "Perfect":
http://www3.towerhobbies.com/cgi-bin...&I=LXDF10&P=ML
Kmot is offline
Old 10-04-2012, 09:09 AM
  #1218
Carosel43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Woop AGC Engineering! Ok im done :P
Although i agree, we all need to get those hats!
Also, Rev and Tom i have a present for you..check your pms
Old 10-04-2012, 10:33 AM
  #1219
retransit
retransit's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK, Tom. Thanks for the link.
Bob
Old 10-04-2012, 02:00 PM
  #1220
Kmot
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is a little 'artistic' FS400 porn for everyone.
Click on the link and it will take you to the full size image. It can be printed up to 30x40 inches if you so desire.
http://www.fototime.com/38F737E1AB39526/orig.jpg
Kmot is offline
Old 10-04-2012, 02:02 PM
  #1221
retransit
retransit's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You have to mount that on one of those wing thingys and fly it..
Bob
Old 10-04-2012, 02:14 PM
  #1222
Heli-NuBee
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
AHhhh - to change clips or not to change clips - that my friends, is the question!
Roger the radial rabbit
Heli-NuBee is offline
Old 10-04-2012, 02:24 PM
  #1223
Heli-NuBee
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey frets24, I haven't been able to find that 80" Zero build forum. Please give me the link if you can. I can tell you that the engine is a very tight fit in the cowl though. I just may have to cut some holes to clear the valve covers.
Roger the radial rabbit.
Old 10-04-2012, 02:28 PM
  #1224
Reverend
Reverend's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
oh joy of joys! my engine lives yet again! finished assembly, hooked everything up, two turns priming and she roared like before! Did take an hour longer than anticipated due to a lost cam follower. turned the whole bl00dy shop over looking for it. finally found it in the front casing o_O. Now the weekend can come
that hat: Its my lucky hat for maidens. I got it from my grandfather (and best friend) before he passed. used to be his motorcycle cap in the thirties. No maiden without it...
Reverend is offline
Old 10-04-2012, 02:29 PM
  #1225
Reverend
Reverend's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Kmot
cant print that poster size, its missing the tom custom badge!
Reverend is offline
Reply
Display Modes
